Question about Kodak Carousel 4400 Slide Projector
4400 35mm 140 slides rotaqry carousel problem...brought it from America to Europe....mistankenly pluged it to a 220V outlet....lamp was blown and projector does not work anymore....need replacement parts.....which parts?....where can I get them and have them sent to me.....i'm in Lisbon Portugal......thanks
    President:
  • Kodak Master
  • 412 Answers
You are looking at a major re-build, I'm sorry to say. For starters, you will need the power motor & a lamp thermal fuse assembly. Kodak will not sell repair parts to you direct. The website below still has some repair parts for KODAK projectors. I recommend you contact them directly.
http://www.micro-tools.com/
Posted on Nov 09, 2010
Honda h22 5 speed
stalls. ( ever tune it up,at the 60k service points? )
what year, no year , no joy, 1978 to 2001 , lots huh?
and what engine option, displacement (size)
over 10 engines
Third-generation Honda Prelude engines:
B20A/B20A1 - 2.0L DOHC PGM-FI 143/160 hp (Japan/Europe)
B20A3 - 2.0L SOHC 12v carb 104 hp North America
B20A4 - 2.0L SOHC 12v carb Global, except North America
B20A5 - 2.0L DOHC PGM-FI 135 hp (101 kW) North America
B20A6 - 2.0L DOHC PGM-FI 142 hp (106 kW) Oceania
B20A7 - 2.0L DOHC PGM-FI 150 hp (110 kW) Europe
B20A8 - 2.0L DOHC PGM-FI 133 hp (99 kW) Europe
B20A9 - 2.0L DOHC PGM-FI 140 hp (100 kW) Europe
B21A - 2.1L DOHC PGM-FI 145 hp (108 kW) Japan (SI States)
B21A1 - 2.1L DOHC PGM-FI 140 hp (100 kW) North America
Jan 11, 2014 | Honda Prelude Cars & Trucks
Lift gate tray
No. The slide tray should rotate when the forward or reverse buttons are pushed. Slides are not required for correct actuation of the tray. Before attempting any adjustment, try a few different trays (it may be a tray issue!). A 140-slide tray will be much tougher to get correct movement from than with a 80-slide tray on an older slide projector.... The 140 tray pushes the interface specification between a tray & a projector to the max.
Oct 13, 2013 | Kodak Carousel 4400 Slide Projector
Kodak 140 slide carousel trays jam
The 140 tray with older slides and an older projector is a gamble with slide jams every time!! Slides have a natural curve that gets bigger over time. In addition, as slides age, the corners will begin to de-laminate (aka: "dog-eared" slide). Because the slide slot in a 140-tray is SO NARROW, the least little deformation of the slide from normal will cause the slides not to drop. My recommendation, given the age of the projector, trays and slides, is to get rid of those 140 trays and stick with 80-slide trays. Good Luck !! Jim
Sep 16, 2013 | Kodak Carousel 4400 Slide Projector
Need a replacement dek lamp with a asa code
DEK Lamps for Kodak Slide Projectors are almost always in stock at "Batteries PLUS Bulbs" retail outlets. If you don't have one of these stores in your area, try: www.bulbman.com
Jan 28, 2013 | Kodak Carousel 600 Slide Projector
Got projector out after several years of non use. Lamp would not light. We purchased a new bulb and installed it. Still doesn't work. Fan runs and all, but bulb will not light.
Check the internal power and lamp fuse. Sometimes, when a projector is stored, an area of corrosion develops around the lamp pins and lamp holder. If you carefully clean both the holder and the pins on the original lamp you may find it works OK!
May 21, 2011 | Kodak Ektagraphic III-E-Plus 35mm 140...
The lever that drops the slides gets stuck in the 'up' position when the carousel is on the projector but it works fine when there is no carousel attached. When it gets stuck you have to take the carousel...
If you are using a 140 tray with older slides, that's very logical! Over time, slides develop a "side-to-side curve". Because the Carousel 140 tray stretches the design limits of the projector to be able to accurately return the slide to the tray, the slightest bend or "dog-ear"(the fraying of the corner of the slide) will cause exactly the problem you're having. If you have a Kodak 80-Slide tray, try it. Chances are that it will work fine. If it does work fine, then you have 2 options: 1. Move all your slides into Carousel 80 Trays.
2. Have your slides re-mounted (that is, have the paper mounts replaced).
I hope this helps !!
Feb 14, 2011 | Kodak Carousel 4600 Slide Projector
What is the correct carousel for a kodak 760 H projector?
A KODAK Carousel 760H is designed to be used with either KODAK 140 or KODAK 80 Slide Trays. The KODAK 80 Slide Tray has wider slide compartments, which tend to be more forgiving for older, slightly warped slides.
Oct 02, 2010 | Kodak Office Equipment & Supplies
Problems with using a 140 carousel on a Kodak 4600
There is nothing wrong with your slide trays. Your projector needs an adjustment to the cycle contact assembly. The constant cycle mode is a dead-giveaway. You need to take the projector to an Authorized Repair Dealer for this adjustment. Should be relatively quick - - it takes longer to get the case apart than to make the repair!
May 25, 2010 | Kodak Carousel 4600 Slide Projector
Can 140 trays work? anyone tried?
The 140-trays do not work smoothly. They advance differntly and the slides jam. I had to transfer more than 2000 slides from 140-carousels to 80 carousels in order to finish the job. You might try transvie trays, which work more smoothly, but you risk damaging the mechanism.
Aug 06, 2008 | Elmo Projectors TRV-35H Slide Projector
Kodak Carousel 4400 Slide Projector Logo
75 people viewed this question
Top Kodak Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
