Question about Kitchen Ranges
Digital display very dim
What is the name of the part that you changed to resolve your problem?
The control board???
Thanks
  • 19 Answers
If you can't get a free replacement, try replacing the capacitors in the clock module. It solved the problem for me for a similar clock module. More information here:
http://www.badcaps.net/forum/showthread.php?t=7902
Posted on Feb 04, 2010
It's called an "Oven Clock Control" Board; for my model of Jennaire, it was part # 71003401.  Do a Google search on that part number and you'll see what it is.  HOWEVER:  it totally depends on your specific model, as that control board is different across different models.  If you call Jennaire and tell them what you need, they should be able to get the right part for you.  And, as I noted in my last posting, tell them that this problem is rampantly posted all over the internet (which is true), so it's clear that this is a defect and you want a free replacement.  I was successful with that approach even though I was outside the warranty.
And, you can replace this part fairly easily yourself.  Takes a few minutes to figure out how to open up the panel, but once you do it it's pretty easy.
Hope that helps.
Posted on Apr 22, 2008
Dim display panel
Hi. The service manual is here - perhaps your solution is here too:
GE JVM1790SK Service Manual
Jul 13, 2016 | GE JVM1790 Convection / Microwave Oven
Digital readout on one side is dim
Display beginning to dim from the left towards center ... - iFixit
https://www.ifixit.com/.../Display+beginning+to+dim+from+the+left...
iFixitApr 15, 2011 - The display on my brother's MacBook Pro 17" 2.5 GHZ (early 2008) has begun to dim, but just on the left side, as though one column of lights ...
lcd/led tv one side dark video screen display problem fix ...
? 2:28
https://www.youtube.com/watch?v=dYHPKxijz1A
Dec 14, 2013 - Uploaded by lcdmasters.net
The video shows the process involved in repairing the following lcd & led tv screen display problems ...Missing: digital
C5 Climate Control dim/dark display fix - Corvette Forum
www.corvetteforum.com/.../1583758-c5-climate-control-...
CorvetteForumDec 28, 2006 - C5 Climate Control dim/dark display fix C5 Tech. ... 4 screws total, size 15 torx screws, two on the top, one on each side towards the bottom. ..... WoW I have a digital display that works, I have been driving around guessing ...
Cheap Fix for a Dim Display on an Oven Control Panel ...
fixitnow.com/.../cheap-fix-for-a-dim-display-on-an-oven-control-panel/
Jan 28, 2009 - A common problem on ovens and ranges with the digital display is that the display ... 1. Replace the electronic control board, typical cost: $250.
Dec 13, 2015 | Image 15.5s TREADMILL Console
Sharp Carousel II (R-9H83) loses clock, digital display dims
I think there are some electrolytic capacitors in the power supply to be replaced.Because there are relatively few, it would be good to change them all for more safety
Jun 02, 2014 | Microwave Ovens
316080102 dim
Oven control board is not working # 316080102. You would need to get it repaired as it is no longer available for purchase.
I would recommend a fast, easy and affordable vendor named Partsimple.com. Partsimple has high level of expertise in control board repairing. many vendors do purchase from them then sell as if their own product.
I have also attached a direct link for reference.
http://www.partsimple.com/316080102-frg-r-12.html
Frigidaire Kenmore Tappan Range Control Board Repair Service 316080102
Jan 27, 2014 | Ovens
Digital display not working
Do you know if your display is the VFD type (usually lights-up greenish-blue or amber on black,) or LCD (usually has a backlit backdrop with either black or colored digits)? Most are the VFD type and can dim over-time due to a resistor gradually changing value. Look on the board near the display, and see if a resistor appears to have gotten too-hot. I've repaired many displays on VCRs that have exhibited the same symptom. Hope it helps!
Apr 07, 2013 | Audio Players & Recorders
Just replaced ite control board on my microwave and got all my buttons to work, but now the clock display is dim in the middle only.
please follow the troubleshooting chart attached and proceed with common sense: God bless you
Jul 19, 2012 | Microwave Ovens
Oven digital lighted display is dim
You need to replace the C3 capacitor on the control board
http://fixitnow.com/wp/2009/01/28/cheap-fix-for-a-dim-display-on-an-oven-control-panel/
You can replace only the C3 - it is 68uF / 35V and you can go to Radio Shack and get their part # 272-1028 - 100uF/35V one. It takes all but 10 minutes to re-solder the new one in place
May 31, 2009 | Jenn-Air JJW8530C Expressions Collection...
Dim control panel unable to read
Removed the amber glass which obscures the display enough to remove the wiring from view. This also allows you to see the characters much more clearly. You now can see the inidvidual light elements.
It's not too bad, people don't even notice, but they do notice you can now tell the time and see what the oven is doing.
Nov 10, 2008 | Frigidaire Microwave Ovens
Thermador model sc272t oven 2 doors have dim display
there is a dispay kit you can order from bosch to fix this problem. it will come with a new display board and power control which is located behind control panel as well
Nov 18, 2007 | Thermador SC272T Electric Double Oven
Kitchen Ranges Logo
329 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
