Question about Dryers
Do you have a diagram on to fit a new belt to a tumble dryer
  • dj22 Apr 22, 2008
    Unable to find model on the site
  • 5,911 Answers
Go to repairclinic.com and click on "Repair Help". Locate the "Dryer Belt Diagrams" link at the bottom left hand side of the screen and locate your Dryer Brand name. You should be able to find your diagram there.
Posted on Apr 21, 2008
  • Jeff Rockwell
    Jeff Rockwell Apr 23, 2008
    What is the model number and brand name of your dryer?
SOURCE: Replacing the Drive Belt
I am not an expert but I do have a Hotpoint 9334 Tumble Dryer which I guess is similar to the 9314.
To replace belt or heater element you must remove the front panel complete with door.
Screws are different sizes in different places so note where they belong as you remove them.
1. Remove 2 screws at rear top which go through the brackets holding the top panel, slide back the top panel a little and lift it off.
2. Pull off the rotary timer knob and remove 2 screws beneath.
3. This is the tricky bit! Remove the the plastic panel which covers the switches etc.. This panel has 5 plastic fingers which secure it to the metal plate behind, locate the ends of the fingers where they pass through the metal plate. Using a metal rod or punch and a hammer, tap the ends of the fingers to push them back through the holes easing each in turn a little at a time to avoid distorting the plastic unduly. (This is a bit scary as you have to hit them quite hard and the fingers look fragile)
4. Open the door and remove the 4 screws then remove 3 screws at the top and 3 screws at the bottom of the front panel. Lift and ease forward the front panel, unhook the door catch release wire, pull off the electrical connectors and put the front panel aside.
5. Lay the machine on its back and remove 1 screw holding the element housing to the top plate and pull off the electrical connectors.
6. Fit the belt around the drum, through the idler pulleys and over the motor spindle.
7. Put it all back together.
Posted on Feb 03, 2008
  • 178 Answers
SOURCE: fitting tumble dryer drive belt
If the belt you are replacing is the same length as the one you took off, it shouldn't be too hard to do. There should be a tensionor pulley attached to a spring that pulls the slack out. Typically, the belt will run on top of the tesnioner pulley, then under the motor drive pulley. Look at the dryer itself and make sure the spring didn't pop loose and fall in the bottom.
Posted on Mar 28, 2008
AlmostBob
  • 550 Answers
SOURCE: how to fit a belt on a tumble dryer
unplug the dryer,
220v is not fun
dryers are generic inside, regardless of maker
while you got it apart to replace the belt is a good time to clean out exhaust vent pipes and the squirrel cage fan, no lint, better air flow, less $$ to run
3cd9043.jpg the tensioner may push Up on the lower run.
  • open case, most front panels are removed including door, remember to disconnect door switch wires, set panel aside
  • pull drum out
  • check drum support rollers
  • check drum felts, bushes guides
  • locate tensioner pulley, belts have been known to pull them out of the mounting when it breaks, check , reinstall if out
  • pick up broken belt off floor of case
  • take belt to parts store and match it, despite the huge number of dryer models there are very few belts.
  • If any felts or rollers are worn,stuck,damaged take them too to the parts store, and replace in pairs, despite the huge number of dryer models there are very few rollers or felts
  • after ensuring rollers anf felts and bearings are serviceable, loop new belt around drum at the wear mark from prior installation, reinsert drum
  • loop new belt around motor pulley.
  • pull tensioner pulley against spring to end of motion
  • loop belt around tensioner pulley
  • allow tensioner to slowly move back by spring tension till the belt is taut
put front panel back on, plugging in door switch
plug in mains
dry clothes
takes longer to type than to do
Posted on Aug 29, 2008
  • 417 Answers
SOURCE: Zanussi Tumble dryer belt replacement
Yes, that sounds about right.
Posted on Oct 11, 2008
SOURCE: How do I fit a new belt to a Whirlpool AWZ650?
Found this dead easy, take top off and back off. Inside undo the star shaped screws, there are also a few screws that are a different shape when removed, these secure the back to an air inlet. Suggest you take note of where the screws come from, even write a number next to the hole with a marker pen and note which screws and in what order. There is also an earth attached to the drum, this is the only wire I removed. Take this back section off. You should then be able to remove the drum by wiggling it out and turning it sideways in the dryer casing.Then remove the fan bottom left, 4 screws and a clip in the centre, the clip was difficult to remove without spreading it so you may need to squeeze it back into shaped before putting it back on. The tensioners will probably have come out of their locators so put them back into place, this is easy to see when you look at them. This is proabably a good time to vacum any dust out. Spread the tensioners hook the belt over the drive shaft only, not the tensioners, and let them spring back, these will then spread when the belt stretches around the drum. Put the drum back on and pull the belt around it, make sure its lined up with the original belt markings otherwise it will just pull the belt off of the drive shaft. Put all the screws back in attache the earth to the drum and put the back on then the top on. I'm not a technician and haven't done this before, it took about 1 1/2hrs.
Posted on Jul 28, 2009
How do I replace a belt on a tricity bendix TM221W tumble dryer - a video of this would help. thanks.
no video
unplug it
you have to take the top and back panel off
take photos of how the belt is fitted before removal
see what holds the belt on or stops it from coming off
undo what is required and fit the new belt
then reverse all the take apart steps till it is fitted
Tricity Bendix TM221W 91609308601 Tumble Dryer Functional parts Spare...
Dec 26, 2014 | Tricity Bendix Dryers
How to fit belt on Creda Reversair 37643 Tumble dryer
New belt is very tight, so you have to use more strength. Put it on motor and all other on "drum". Spin it easily and slowly but with strength until its done.
Be carefully, use gloves.
Apr 13, 2013 | Indesit Hotpoint Creda Tumble Dryer Belt...
How to fit a drive belt to a indesit g511v tumble dryer
http://www.apart4u.co.uk/video-tutorials/tumble-dryer-repairs/how-to-replace-a-belt-on-a-tumble-dryer-stretch-type.html
Hi the above web page is a good general instruction video on how to change a tumble dryer belt, should help, if it does please remember to rate me
Feb 24, 2011 | Dryers
White knight tumble dryer CL432WV wiring diagram please
This has lots of diagrams on white knight http://www.apart4u.co.uk/news/category/questions-and-answers/diagrams/
How to Replace A White Knight Tumble Dryer Heating Element Heater and Thermostat
For a full list of appliance Video Repair help see our video section
White knight tumble dryer not heating this video show you how to change and fit a new heating element and thermostats can be used on Ariston, Electrolux, Ignis, Neutral, Tricity Bendix, Whirlpool,
Here is the element in this video
For all you tumble dryer spare parts click here
The easiest way to find you part is put your model number into our search bar at http://www.apart4u.co.uk/ TEL 08455218000
Apr 19, 2010 | Dryers
How to change a belt on hotpoint tdl54 tumble dryer
The belt goes around the pulley of the motor after fitting it around the drum first.
Mar 23, 2010 | Hotpoint Dryers
Fit new drive belt to tumble dryer
I need to know more. like how to instal belt or how to find what belt fits your dryer . need more info like mod # there 5 different belts for hotpoint . and several different ways to install them so model # ______________ needed . **** . pls .
Jan 02, 2010 | Dryers
Dryers Logo
119 people viewed this question
Top Dryers Experts
