Question about Remington Precision HC-8017 Hair Trimmer
Where do i but the oil
Trying to find where you oil the trimmer
  • Remington Master
  • 1,614 Answers
Put one drop of clipper oil on the teeth of the blades before each use
Posted on Jul 23, 2010
Smoke coming from edger muffler
Check to see if you overloaded with the oil when mixing your oil and gas...if it is a 2 cycle.
If it is a 4 cycle then you may have over filled the oil tank, drain some out and try to run again
Please rate me
Sep 18, 2010 | Echo Rapid Loader, Trimmer Head
Homelite gas trimmer ut20602 from 1998 need oil mix ratio...is it 40:1 or 50:1
Use the 50:1 ratio oil mix.the oil bottle will tell you how much oil that you will need to mix with how much gas you have,40:1 will make the trimmer smoke too much and it will foul plugs prematurely but won't hurt the machine.
Jul 30, 2010 | Homelite Mighty Lite Lawn Trimmer
I have a gas operated 31cc Craftsman model number 316.798221 weedwacker trimmer 17 I mixed fuel with 2 cycle engine oil using a 4 to 1 ratio. The trimmer no longer starts. It seems as if it is about to...
If you have mixed your gas and oil to a 4 to one mix you have way too much oil in your gasoline. Drain out your fuel tank and carburetor. ----------------------------------------------------------------------------- Remove the spark plug and clean if necessary. Mix your fuel in a fuel container at 40 to one. Some sites even recommend a 50 to one mixture. (50 to one mixture is one pint of oil to 6 gallons of gasoline) Refill your fuel tank on the trimmer and try to crank, if it does not want to crank within 4-5 pulls then you may want to give it a very small shot of starting ether in the carburetor intake and try to crank again. Good Luck, I hope this helped, Please rate me, Thanks
Dec 30, 2009 | Garden
Gas/oil ratio for homelite lawn trimmer
A good gas/oil ratio is one ounce of oil per quart or four ounces of oil per gallon of unleaded gasoline. Hope this helped and best wishes.
Oct 05, 2009 | Homelite Mighty Lite Lawn Trimmer
What is the correct ratio gas to oil for my stihl fs 66 trimmer
Use a quality 2 cycle oil and mix it to the oil manufacturer's recommended ratio. Today it is usually 50:1.
Fuel in the USA contains ethanol; try to use up your mix in a month or less. HTH
Lou
Jul 28, 2009 | Garden
Correct gas to oil ratio for Homelite Mighty String Trimmer Model
most trimmers are 50:1. or 40:1. i would use synthetic 2 cycle oil and use the 50:1 ratio. i know guys with trimmers that require 50:1, and they use synthetic at 80:1 with no problems for years. they say the engine runs cleaner. i am a part-time lawn care operator.
Jun 18, 2009 | Homelite Mighty Lite Lawn Trimmer
I can get it started but, when i give it gas it starts to sputter then shuts down ????????
Sounds like too much oil, try letting it idle if you can for a while, and try it once it has warmed up. If there is a terrible amount of smoke, probably too much oil.
Jun 04, 2009 | Husqvarna 28cc Gas Line Trimmer
Troy Built 4-cycle engine Trimmer
there should be a label stating the oil type somewhere on the engine or cap or owners manual, if not most manufacturers recomend a 30 weight oil. be sure to drain out the old stuff first.
Sep 21, 2008 | Troy Bilt 17 Inch 29 Cc Gas Powered...
Ryobi string trimmer 32.1 what do mix gas and oil or just gas?
Ryobi trimmers I have had use a 32:1 oil mix. Just pick up a little bottle of Ryobi 2-cycle oil and read it to see that it will give a 32:1 mix in a gallon of gas. Pour it into a gallon of gas, and maybe a little fuel stabilizer too, shake it up and you should be good for the season.
May 28, 2008 | Ryobi 15" Electric Factory Reconditioned...
Remington Precision HC-8017 Hair Trimmer Logo
112 people viewed this question
Top Remington Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Jerry Greenberg
Jerry Greenberg
Are you a Remington Health and Beauty Expert? Answer questions, earn points and help others
