Question about Arris SURFboard SBG900 (49402201900) Modem
Software Can I get internet access using the USB connection in my computer? , because I want to use the ethernet connection for an access point
  • 19,396 Answers
Yes you can use USb modem, you need to uninstall modem software, disconnect modem and reinstall software configuring it as usb. Start installation with modem disconnected and follow User Guide SBG900
Note: usb modem is much slower than ethernet modem (even if you use same machine) . Instead of using modem as usb I suggest using an external Usb Network adapter.
Regards
Posted on Apr 21, 2008
I cannot connect to internet because my computer was remastered and trhe computer does not recognise my router and is telling me to install a driver
I Figure your using a USB lead from your router to your computer. You will need to download the USB interface driver from the Belkin web site. Otherwise, if the router has a ethernet jack, then use a patch cable to your computer (ethernet port) eliminating the need for a driver
Feb 15, 2011 | Belkin (F5D7132)
I got a NETGEAR router and I have been trying to get my Motorola SURFboard to recognize it. I had the USB connection installed and the NETGEAR uses ethernet, so I tried to install the ethernet but my...
The Cable modem must be disconnected from the computer. You cannot use USB and Ethernet at the same time.
1. Turn off power to the Cable Modem and the Netgear Router. Do the same with the computer.
2. Connect an ethernet cable from the modem to the router's WAN (Internet) port.
3. Connect another ethernet cable from one of the remaining 4 LAN ports on the router to the computer's ethernet port.
4. Now power on the Cable Modem ONLY. Wait for the modem to sync up with your service provider
5. After about 2-5 minutes power up the router and wait about 1-2 minutes.
6. Now power on your PC.
Check and see if you have internet access. If not you may have to uninstall any cable modem software related to USB connection. if this is the case, then you may have to repeat steps 4-6.
Since most cable internet providers do not use proprietary connection settings, your internet connection should be up and running without changing any settings in the router or modem.
If this does not resolve your issues, we can continue to work with you.
Nov 29, 2010 | Arris SURFboard® SB5101 Cable Modem
I don't know how to reinstall the linksys access point!!! Our wireless network that we made simply disappeared, so I'm trying to re-make one. However, when I tried that with a flash drive, it couldn't work...
T
o access the Access Points Setup, and the LAN IP address has not changed, then computer must have an IP address of 192.168.1.XXX. If the Access Point is plugged in via Ethernet to a Linksys Router and the computer is also connected a Linksys router via Ethernet, then the PC should already have a correct IP address (unless the LAN IP Address of the Router has been changed). If unsure, please assign the computer a Static IP Address so it will have an IP address in the same range as the Access Points IP Address.
If the Access Point is being connected to a hub/switch/router via Ethernet, then use the cable that was provided with Access Point. If the Access Point is being connected to the computer directly, then a Cross Over cable must be used. Cross over cables can be purchased at most electronic stores.
    Remember: When ever a change is made in the Setup of the Access Point, the Apply button must be used to save the settings to the Access Point.
  1. Open a web browser (such as Internet Explorer or Netscape)
  2. When the browser opens, go to the "Address" bar and input the IP address of the Access Point.
      Default IP addresses:
    • WAP11 v2.8 - 192.168.1.251
    • WAP54G v1.1 - 192.168.1.245
  3. A "User Name" and "Password" prompt will appear, leave the "User Name" field blank and input the Access Points password (The default password of a Linksys Access Point is admin) into the "Password" field.
May 14, 2010 | Linksys Wireless-G WAP54G 802.11g/b...
C5180 all in one is not connecting via ethernet.
Before you begin: Check requirements Make sure you have the following items:
  • One of the following types of wired access points or routers: Ethernet router, switch, hub, or wireless router with Ethernet ports
  • A computer that connects to the wired access point or router
  • A Category 5 Ethernet cable to use for the HP product. (Do not use a standard telephone cable.) Figure 2: Cable comparisonc01710115.gif 1 - Ethernet cable 2 - Telephone cable (do not use) Although an Ethernet cable looks similar to standard telephone cable, each has a different plug and a different number of wires. The plug on an Ethernet cable (also called an RJ-45 connector) is wide, thick, and always has eight wires. The plug on a telephone cable is narrower and has between two and six wires.
Are you changing from USB connection to Ethernet connection?If you previously installed the software for a USB connection and now want to change to an Ethernet connection, follow these instructions to remove the USB installation before continuing.
  1. Click Start , click Printers and Faxes , and then right-click the icon for HP product.
  2. Click Delete to remove the product.
  3. Disconnect the USB cable from the product and the computer.
Step one: Connect the HP All-in-One to the network
  1. Remove any plug or protective cover from the Ethernet port on the back of the product. Figure 3: Remove plugc01710117.gif
  2. Connect the Ethernet cable to the Ethernet port on the product, and then connect the other end of the cable to an available port on the wired access point or router. Figure 4: Connect the Ethernet cablec01710118.gif
  3. Connect the power cord to the product, and then plug it into an electrical outlet.
  4. Turn the product on.
Step two: Decide whether to install with the product CD or download the software Don’t worry if you don’t have the product CD! You can download the most current software available for your product from the HP Web site at no cost. The following information might help you decide which installation method to use:
CD Download For a new product: CD installation is a quick and easy method. If you do not have a CD, you can download the software you need. For an older product: CD installation might not work if you are installing the product on a computer running a newer operating system that released AFTER the HP product released. Downloading the software provides the best results for your older product. Even though it takes more time than using the CD, downloading the latest software can help you avoid installation issues.
Downloading is the recommended method if your computer operating system released after the HP product released. About the software: The software on the CD is current to the date of the product release. The software that you can download from the HP Web site is the most current software available for your product. HP often updates software and drivers AFTER the product and CD release to the market.Step three: Install the software
Jan 16, 2010 | HP Photosmart C5180 All-In-One InkJet...
I can't hook my computer up to my phone line for internet. I have my router and another desktop hooked up to the phone line through the router.
That modem is in itself a router. However it only has one Ethernet port and no means of broadcasting a wireless Internet Signal which makes its function of a Router somewhat useless. What you need a(n) (wireless) access point. The Access Point will give you more Ethernet slots allowing more computers to be connected to the modem/router via CAT5 (Ethernet) cables. Depending on if you get a Wireless access point or not you might also be capable of using a wireless adapter to connect to the 2wire and get Internet access.
Let me know if I need to clarify any of the points above or if I can assist you further.
Mar 16, 2009 | 2wire 1800HG Router (RG1800HG00)
1 modem connected to 2 computers
Wireless is not the best thing to do heavy online gamming with. He he wants to keep a solid connection wile playing, ethernet is the way to go.
Feb 18, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
Connecting a wireless router to Tiscalli broadband connection
  1. USB modem is connecting a PC USB port with a DSL phone line: CANNOT be connected to a ROUTER LAN (ethernet NOT USB port).
  2. Wireless ROUTER is NOT a modem and it CANNOT connect the Internet (or WAN) LAN port to any "phone line"
  3. Connect the Router Internet (WAN) port to Modem (you need a LAN MODEM = a modem with a LAN/ETHERNET port)
  4. Be sure your internet is running before strting ROUTER configuration with Router Company CD
Jan 05, 2009 | 3Com 7760 (3CRWE776075US) 802.11a/b/g...
Wireless Network working on laptop, lost internet on desktop.
If you disconnect the desktop from the modem, were you able to get an Internet connection in your laptop?
In order to get Internet connectivity on your desktop at the same time with the laptop, then the desktop needs to be connected to the router. It should be connected to one of the Ethernet ports at the back of the router. Since, your desktop doesn't have an Ethernet port, then you need to connect a USB to Ethernet adapter to your desktop. Then from that adapter, you will connect to it an Ethernet cable going to the router.
You may check the following models:
Linksys USB200M
Linksys USB100TX
Belkin Gigabit USB 2.0 Network Adapter(F5D5055)
D-Link DUB-E100
There are other brands that offer USB to Ethernet adapters that you can check.
Hope this helps!
Nov 22, 2008 | Linksys Wireless-G Broadband Router
Connecting my wii to the internet
to connect your wii to the internet connect to the following link or read the following instructions
http://systemsetup.nintendo.com.au/Connecting_Online
to connect your wii to the internet you will need to provide a wireless internet access point for it to find. you will need:
a computer connected to broadband internet
a wireless router OR Nintendo Wi-Fi USB Connector OR Wii LAN Adapter
your wii console to be nearby all of the above
If you are using the LAN Adapter you must plug the USB connection into the back of your wii console and the other end to your internet modems ethernet port. (follow steps below)
if you are using a wireless connection follow steps below.
Turn on your wii and on the main menu select 'wii' in the bottom left hand corner
On the next screen, select 'wii settings'
In the 'Wii System Settings', click on the blue arrow on the right to reach the second screen of options. On this screen, click the 'Internet' button.
Select 'connection settings'
select an open connection indicated by 'none'
select the corresponding option, Wired or Wireless connection
Wired:
Wireless:
Select the corresponding option, Search for an access point or Nintendo Wi-Fi USB Connector
the wii will search for an access point, select the access point you wish to connect to, and save the settings
The wii will now do a test connection and do a system update, the wii will now use that connection point to acces the online services
hope i helped!!
Sep 19, 2008 | Video Game Consoles & Games
Arris SURFboard SBG900 (49402201900) Modem Logo
262 people viewed this question
Top Arris Computers & Internet Experts
Jerry
Jerry
bobkoure
Level 1 Expert
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
