Question about Toshiba Computers & Internet
My toshiba calmee titan cannot be read modified with Mac
The hard drive says it's compatible with Mac 10.1 and higher. I'm running on Mac 10.4 and it does not allow me to create new folders and transfer files to the hard drive. The mac reads the HD and you can open it, but you can't do anything else with it.
The hard drive needs to be either a) reformatted with a file system the Mac can manipulate (HFS+ would be ideal) or b) install MacFUSE NTFS-3G.
HTH
Posted on Aug 13, 2010
Undetected in mac
The interface in the case would seem to have failed. They are usually not the same standard as those used in a computer.
May 01, 2013 | Toshiba Computers & Internet
ON my Toshiba Satellite M-45 S355 I got a blue screen with a message; STOP: c000021a (Fatal System Error) The session manager initialization system process terminated unexpectedely with a status of...
do not believe you need replace the hard drive
i think you may have a registry error
you may have a application conflict or surface error
try booting in either step mode or safe mode
step mode will let you know where in the boot process the error occures
in safe mode you can run a registry utility like iolo system / registry mechanic
& run error checking
if you need neer to remove & backup your drive you can get a hard drive usb adapter cable set $10-$20 - less work
Nov 04, 2010 | Toshiba Satellite M45-S355 (PSM40U073001)...
I have my smartdisk modified to a pc...and when i try to download things off of a mac it won't let me. How do i switch between modifying to a pc and modifying to a mac
The problem is that your smartdisk drive operates using the NTFS (New Technology File System) under USB which is the standard file system of Windows. Apple mac is not interopable with native NTFS therefore you need to install a read-write NTFS file-system driver on your mac if you wish to use it via the USB connection.
An excellent free mac NTFS driver can be found here-
http://mac.softpedia.com/get/System-Utilities/NTFS-3G.shtml
Download and install the software then restart your mac.
//javaftper
Aug 03, 2010 | SmartDisk (DHXF250F) 250 GB Hard Drive
I bought a Verbatim Clon USB Portable HardDrive to back up files from my Mac Computer. When I click and drag, I get this pop up " items can't be move because verbatim can't be modified." It says the hard...
You have to partition your Verbatim Drive to work on a Mac. Go to Macintosh HD / Applications / Utilities / Disk Utility. When in Disk Utility select the 232.9 GB SAMSUNG HM250HI Media to the left.
Dec 19, 2009 | Verbatim 500GB USB Desktop 500 GB Hard...
External hardrive 'cant be modified' on mac
since the windows and mac has different file format , u need to convert for support to mac systems
Oct 29, 2009 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
IOMEGA eGo portable hard drive won't copy files from mac
Format your hardrive for Mac OS:
Go to Disk Utilities under the go menu in your finder. Select the external drive and click on the erase tab. Clikc erase again and it formats the drive. You can now copy files onto the drive.
Oct 29, 2008 | Iomega (33090) 250 GB Hard Drive
DOES THE VERBATIM HARD DRIVE NEED TO BE FORMATED?
Many Verbatim hard drive models with a FireWire interface come “Mac formatted” – pre-formatted for immediate use with Apple Macintosh computers running Mac OS. They are formatted as HFS+, the preferred format when using the drive exclusively with Mac OS computers.
Note: A Mac-formatted drive will not mount on a Windows PC.
If you plan to use a Mac-formatted hard drive only with computers running Mac OS, you can leave it formatted as it comes from the factory. However, if you plan to use your hard drive with computers running Windows, or with both Mac OS and Windows computers, you should reformat your Verbatim hard drive before saving data to it. Generally, for use with both Mac OS and Windows you should format to FAT32, and for use strictly with Windows you should format to NTFS. More information about these two format types is given below.
FAT32 FAT32 is compatible with the following Windows operating systems: Windows 98, Windows 98 SE, Windows Me, Windows 2000, Windows XP, Windows Vista. FAT32 can also be read by Apple Macintosh computers running Mac OS.
Limitations: Maximum file size is limited to 4TB. Furthermore, using the formatting tools included with Windows 2000, Windows XP, and Windows Vista users will not be able to create partition sizes larger than 32GB (though they can access these larger partitions). This limitation does not apply to other supported operating systems. Furthermore, Verbatim provides a FAT32 format utility (see further below for download instructions) that eliminates the 32GB partition limitation.
FAT32 is a good choice if you’ll be using your Verbatim hard drive with older computers running Windows 98, Windows 98 SE, or Windows Me, or if you’ll be using it with both Windows and Mac OS computers.
NTFS NTFS is compatible with the following Windows operating systems: Windows NT, Windows 2000, Windows XP and Windows Vista. NTFS usually results in higher performance than FAT32, and will permit users to create partition sizes larger than 32GB, and file sizes larger than 4TB.
Limitations: NTFS is not compatible with Windows 98, Windows 98 SE, Windows Me, or Apple Macintosh computers running Mac OS.
NTFS is a good choice if you will be using your Verbatim hard drive only with one or more computers running Windows XP, Windows 2000 or Windows Vista. This is also a good choice if you plan to store files larger than 4TB, such as digital video files.
Per: http://www.verbatim.com/downloads/format.cfm
Good Luck
cbinny1
Oct 20, 2008 | SimpleTech SimpleDrive Portable USB 2.0...
Maxtor External Hard drive not compatible with Mac
I would check Maxtors website to see if there is compatibility issue using that particular drive on a Mac.
Jun 08, 2008 | Maxtor Personal Storage 3200 (U01E200) 200...
Can't seem to find usb
Here is compatibility information:
Compatibility
  • Windows 98SE/2000/ME & XP
  • Mac OS 8.6 to 9.2 & 10(X) or higher
  • USB 2.0 or 1.1 compatible
Looks like it might not be compatible. Sorry!
Jan 06, 2008 | Computers & Internet
FreeAgent Drive cannot be Modified?
The problem with the compatibility between your external drive and your mac is that freeagent drives are formatted in NTFS and the Mac uses FAT32. Mac's can read from NTFS drives but cannot write to them. I'm afraid that the only solution is to re-format the drive in FAT32 format if you want to be able to write to it.
Jun 06, 2007 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Computers & Internet Logo
610 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
