SOURCE: Built-in DVD player
Are you trying to play DVD's you've made or copied yourself or new one's you buy from an actual distributor? Because sometimes self-ripped Cd's & DVD's won't play on a LOT of DVD players. Otherwise it's bad DVD player and you should go get it swapped out if it's not too late.
SOURCE: DVD plays only in black and white
Hey, I had this problem on Thanksgiving Day, trying to watch a dvd on my mother's HDTV. You should be able to hook up most standard dvd players to hdtvs. First you have 3 cords, mine were red, yellow, and white. The connections go as follows:
HDTV:
Audio| Component. The white cord should be in a white audio slot. The yellow cord should be in a yellow component slot (video) and the red cord should be in a red video component slot labeled Pr/Cr. Make sure you match the component numbers. For instance, if you want to use component one, then hook all of the cords into the slots for component one. Most hdtvs have multiple component hookups ( think multiple "channels" for your game system, dvd player, etc) so it's important that the corresponding cords go to the correct component slots.
DVD:
Match the yellow and white cords to the appropriately colored slots. The red cord should go into the slot labeled component video out Cr/Pr. Not the red audio out. This worked for me. Hope this helps.
SOURCE: built in DVD player on my Polaroid flat screen quit working!
Unfortunately if you tried to remove just the dvd player it would void your warranty under most agreements. the only thing you can do is call the manufacture as for a repair authorization number and take it or send it to an approved repair station.
SOURCE: 32lg40 built in dvd player disk error
There definatley could be a firmware issue with that TV's DVD player if the model has just been released. My suggestion would be to bring a couple of known to be working DVD's back to the store and try their floor model as well. This will be easier than bringing back the TV for the second time. If this is a problem with the DVD player's firmware, LG should be able to fix it under warranty so I would call them or swap out the TV for another brand instead.
SOURCE: There is a DVD stuck in the built in DVD player in
try unpluging set while tv is on and plug it back in it should come out
Testimonial: "Thanks a lot! It worked. Now I'm afraid to use the DVD player. Maybe I'll put in an old kid movie that we don't watch anymore and see if it works. "
