My GE WBXR1060TAWW clothes washer is leaking significant amounts of water. It seems to be draining correctly, but there is still some water left in the machine after running. Please advise. Thanks.
  • coupland Apr 21, 2008
    I've done this but can't actually see or feel anything. Do I need to take the machine apart?
  • 101 Answers
You have something stuck inside the Washing machine pump assembly,you could tip over the machine disconnect the drain holes and look in the pump and clear what ever is jammed inside. <<<Remember to disconnect the power cord first>>
Posted on Apr 21, 2008
GE WBXR1060TAWW, Top loading high capacity washer. I need the specs, capacity and number of speeds?
The (X) in the model number stands for extra large (2.7cu ft) capacity. The 1 stands for single speed. The 6 stands for 6 cycles. It should have a white plastic clothes basket. More expensive models had a stainless basket. Hope this helps you.
Apr 15, 2015 | GE Washing Machines
Rumbling noise during draining
i know with my fridgeadair it was the pump going out of mine , it would take me 3 spins to get the clothes wrung out enough to put in the dryer.
Dec 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Intermittent water on floor
Check the inlet valve hoses, even if inlet is at the back, the water may drip down and flow on the front part on the machine. There you also have the PUMP, a faulty pump may leak intermittently.
Here you get all diagrams and parts for your appliance.
Sep 25, 2009 | GE WJSR2070B Top Load Washer
Intermittent water observed under machine
Difficult if not seen. Most common water on the floor senario is a drain pump leaking:or a perrished pipe from friction.or sometimes, water backs up from the house drainage system due to a restriction.
Water still in bottom of tub after drain/spin cycle
I removed the drain hose from the bottom left rear corner of the washer & cleaned a large amount of gooey sludge from the bottom of the drain inside the washing machine.
Feb 14, 2009 | Kenmore 12502 Top Load Washer
Ge WASE4220A0ww will not drain or spin
hI!!! You seem to have a bad transmission or a bad motor they are all expensive to repair..Good luck..
Jan 03, 2009 | GE Profile WPRE6100G Top Load Washer
Clothes are soaking wet at end of rinse cycle
Awesome website, fixed my problem. Thank you, especially in these times where I can't afford to just call the repair man:)
Jul 09, 2008 | GE Energy Star WCVH6260F Front Load Washer
Fixn my GE washer spin cycle
It sounds like it could be the lid switch, check to make sure the lid switch is clicking when you close the lid.
Jun 27, 2008 | GE WHRE5260E Top Load Washer
Washer leaking water from bottom
looks like you have to replace the RUBBER SEAL thats inside the tub at the center post , try this , remove the panel so you can see inside , put the washer to fill w/ water , and watch closely underneath the tub wheres the transmision is connected , and watch for LEAKS . hope this info helps
Apr 22, 2008 | GE WBSR3140DW Top Load Washer
Leak problem
Ours did same thing after nearly same amount of time.
Run a couple of sanitary cycles without any cloths.
Only use HE detergent.
Problem stopped after this
Oct 08, 2007 | LG WM1815CS Front Load Washer
Washing Machines Logo
174 people viewed this question
Top Washing Machines Experts
