Question about Bosch Nexxt 500 WFMC3301 Front Load Washer
The front spring wire (round) that holds the rubber gasket in place came off . I have been trying to put it back on . Any suggestions?
    President:
  • 1,430 Answers
They are a little tricky but try this link you will get it. http://appliancehelponline.com/washerdoorseal.html
Posted on Jul 18, 2010
Whirlpool Front load washer - the grey round rubber came out. I put it back on and now all th water leaked out of the machine all over the floor
I don't know what model you have, but mine has a big spring that goes all the way around the rubber gasket. If that is not in place it will leak. I wonder if the spring in yours is under the gasket and didn't get put back on properly.
Dec 14, 2016 | Whirlpool Washing Machines
Wire that holds the rubber gasket came off
can usually take to people if you are not familiar.the spring does down towrds the bottom of the boot in the middle of the boot start with the ring at the top and go down both sides the have someone hold it in place about the 10 and 2 o clock positions while you use your hands or small screw driver and finish putting the ring in place
Jun 10, 2010 | Bosch Nexxt 500 WFMC3301 Front Load Washer
The rubber has come of the washingmachine door and their is a round wire with spring attached and i am not sure where this goes i know it holds rubber onto door but not sure how.
toput it back on you thred it round the door and you put the wire with a spring insine the rubber there should be a notch all the way round you thred it round the door to hold it so it dosent come off the wire is a restaining clip to hold it on when you done this make sure the rubber dosent move hope this helped
Aug 31, 2009 | Indesit W 123 Front Load Washer
Wire ring that holds rubber seal on next 100 washer has come off
Bosch Nexxt 100 Series WFMC1001UC Front Load Washer how to put back on wire ring, with a spring for tension, that holds the inner rubber seal in place.
This video will show you how to change a door seal on this Bosch front loader washing machine and also how to get back on, the metal ring around the seal.
we have all bosch repairs in our channel.
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 24, 2009 | Bosch Nexxt 100 Series WFMC1001UC Front...
Large rubber door seal came apart
Yes it can be put back on without taking the drum apart. The larger end goes on the drum side. Fit larger end around drum lip make sure it seals all the way around, install spring around seal. Smaller end goes around door opening. Install seal around outter lip and install spring around seal.
Mar 05, 2009 | Kenmore 44102 Front Load Washer
Kenmore washer need to put rubber gasket retaining spring back on. Any tricks, seems impossible. Peter
I assume that you're talking about the inner spring. It's very tight, so you have to get the rubber gasket (bellows) fitted on the its frame, then push the bellows inside out in toward the tub. Start with placing the spring in its groove at 12 o'clock. Wedge something between the bellows and the white colored weight ring of the tub. You'll need something approx 3/4" in diameter to wedge the top of the spring in place. (I've used a 1/2"X90 degree copper elbow I had laying around that had an approx outside diameter of 3/4"). This will hold the spring in place as you work it around. It is still very difficult and you may have to stretch the spring ever so slightly to get it back into the groove. Once the spring is back on, remove the wedge, fold the bellows back out and attach the fill hose and attach bellows back to front panel.
Jan 02, 2009 | Kenmore 44072 Front Load Washer
Seal on fron loader
there is a wire clamp and spring that holds the gasket on, loosen the spring and reset the gasket then refit the gasket and spring.
Dec 28, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Bosch wfm3200 rubber gasket
You need to turn the seal back in on iteself at the front, then starting at the 12-o clock position, start feeding the spring round into the recess you will feel at the rear edge of the seal, it is a goove and that is where the spring fits.
As you progrees round with the spring you will find it harder and harder to get it to stay in the groove, this where you could do with some assistance.
You need to have some one hold the spring in place as you progreeively fit the spring.
You may find you will have to have more than attempt.
As a last resort, you can stretch the spring, which will make it easyier to fit., but do not stretch it too much, or it will not stay on.
Plz leave feed back for this solution.
Dec 11, 2008 | Bosch WFMC 3200 Front Load Washer
Spring For Rubber Ring Around the Front
it is a knack. get an extra pair of hands if it helps. put wire in groove as far round as you can. put small screwdrivers in position to hold it there and lever the rest on with another scdrewdriver
Oct 13, 2008 | Bosch Nexxt 100 Series WFMC1001UC Front...
Rubber gasket around opening
Iserial #15616047cc i want to know how to repair it my self
have a ANANA washer machine model alw 480daw
Jan 27, 2008 | Bosch WFMC 3200 Front Load Washer
Bosch Nexxt 500 WFMC3301 Front Load Washer Logo
155 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
