Question about Dryers
Im getting a f40 signal on my kenmore elite oasis dryer, and i need to know how to fix it
  • e4mccann Jul 18, 2010
    Thank U very much. Your answer worked well.
    President:
  • 1,554 Answers
Fault code F40 is a communication error between the machine control and the motor control. Disconnect power then remove three screws from the rear of the console assembly and pull console towards the front of the dryer to hinge open and remove console. You'll see three electronic assemblies; the machine control electronics, the motor control electronics, and the user interface electronics.
Visually check the communication harness, the three-wire harness that connects between the machine control electronics and the motor control electronics. Make sure it is fully inserted into both electronic controls and the terminal connections are clean. Reseating the connections several times will help clean off dirt and corrosion build up.
Do the same with the the wire harnesses connected to the motor control electronic assembly. Make sure they are clean and fully inserted into the control. It is a good idea to do the same thing with all other wire harnesses in all of the electronic assemblies.
Please indicate the exact model number of the dryer should you need further assistance or if the procedure outlined above does not address the issue. You don't have to accept or reject and rate this post to add information or post comments and follow-up questions. Accepting a solution does not stop you from communicating with an expert. You can continue communicating with the expert as long as you need assistance regarding the issue stated herein.
Posted on Jul 18, 2010
Kenmore elite oasis st flashing f40 , wont stay on??
If you wish to get some details; check the site linked here. Pull up older posts.
Aug 02, 2016 | Kenmore Dryers
What does the code F40 mean
I know that it can be very frustrating to have issues with your dryer. In the console there are two control boards. One is the machine control and the other is the motor control and the F40 error indicates a communication error. That means the two controls are not talking to each other. There is a test that you can perform to determine what is causing the issue. The image below will provide these instructions for you. Once you have determined this, then you can replace the correct part.
Oct 18, 2012 | Kenmore Elite Oasis ST 6807 Dryer
I've got a Kenmore Elite Oasis gas dryer, model #110.77082600 with an F40 code. Followed troubleshooting instructions on the tech sheet: Snugged connectors on wiring harness Measured resistance on the MC2...
Common to find loose connection on control panel. Unplug machine access control panel area and squeeze the connectors slightly to inside good contact. If not then c. Panel is shot.
I’m happy to assist further over the phone at https://www.6ya.com/expert/howard_977676954994c5b2
Mar 02, 2017 | Kenmore Elite Oasis 7808 Gas Dryer
Model 110.78082701 F40 error code what does it tell is bad?
F40 is a error that appears between the machine control and the motor control when communication becomes lost. I had this same issue. My dryer would run and heat up but then stop and give me the f40. I measured all thermisters and everything was in range. The tech sheet stated that I needed to buy a new control board and I did. Same problem.
The solution was a loose connection on for p4. I took needle nose pliers and squeezed the connector to make it fit tight on the board and everything is working now.
Bottom line, expensive dryer with cheap connectors.
May 11, 2010 | Kenmore Elite Oasis 7808 Gas Dryer
Kenmore elite oasis dryer model #110.6708 will not operate. flashes f-40. what does f-40 mean?
F40 = thermal fuse blown.
If the fuse is OK the error points to a communication problem between the machine control board and motor control board (check connectors).
Mar 19, 2010 | Kenmore Elite Oasis 6809 Electric Dryer
I need the installation manual for a Kenmore Elite Oasis gas dryer. Specifically I need to know what water line attaches to the dryer (for steam), the hot or the cold?
Hello, Here's the link to view the owners manual and exploded view of the parts for your model. Once there, click on the exact model # you have (it's listed on your dryer's data plate) so you get the right one.
http://www.managemylife.com/mmh/owner_manuals/search?query=kenmore+oasis+elite+dryer+7808
Mar 09, 2010 | Kenmore Elite Oasis 7808 Gas Dryer
Kenmore oasis elite
If it's not listed in the rear of your manual??? Then you will need a Technician. Let me know if you find the solution in your book.
Dec 27, 2007 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
23 people viewed this question
Top Dryers Experts
Marvin
Marvin
