Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
Freezer working with slight amount of frost and refrigerator side is hot
  • GE Master
  • 1,606 Answers
This is how I would check your refrig if I came out to do a repair based on your problem .
Pull the refrig out and remove the 8 " x 10 " panel . Behind this panel , is the main control board . Unplug the refrig . Remove the BLUE plug from the board , with 3 larger wires going to it . Looking at the blue plug , the sequence will be wire1,wire2,space,wire3 . Get a short piece of insulated wire , and strip about 1/4 inch from each end . Insert 1 end into wire2 , and the other into wire3 . Plug the refrig back in . After about 3 min , look in the freezer , at the bottom , behind the crisper , look for a red glow . If no red glow , unplug the refrig , and reassemble the plug and cover . This no glow , indicates a shorted defrost heater WR51X10055 . It is also advisable to replace the defrost thermostat ( pt. number WR50X10068 ) when replacing the heater . To access these parts , you will have to remove the inside rear wall of the freezer . The heater , is at the bottom of the coils , held on with 2 screws , and the thermostat , is the 1 " cylinder , with a blue and pink wire going to it , clipped on the top left of the coils .
If you do get a red glow , then the # 4 thermistor is bad . This tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp and when to cycle off due to selected temperature .
Posted on Jul 18, 2010
I have a Whirlpool Refrig. model GX5FHDXVY04. The freezer is working properly but the refrigerator is not cooling. I noticed frost on the inside back panel of the freezer. I turned the temp down in the...
Many of frost-free fridges use fans to move a controlled amount of air into the upper or side cooling chamber, check for non-working fan or a stuck or malfunctioning damper control. Keith L.
Mar 02, 2012 | Whirlpool 24.8 Cu. Ft. Side-by-Side...
Frost Buildup in Frost Free unit.
You will have to check the defrost timer to make sure it is turning if it is working properly and you are getting power to the defrost heating element below the freezer coil it should get hot if you have a 115volts or so to the element and it does not get hot then you have a bad element
Jun 10, 2010 | Kenmore 57029 Side by Side Refrigerator
I have a GE GSS25XSRSS Side By Side refrigerator
no defrost taking place
a clock
b heater element/hot gas valve
defrost terminator or safety fuse
Mar 17, 2010 | GE GSS25XSRSS 36" 25.4 Cu. Ft....
MSD2656GEQ The coils on the freezer side ices up, then does not cool the refridgerator side
Hi, It's a common problem with no-frost refrigerators, you have a defrost problems, two scenarios. (1) hot air entering freezer/refrigerator, examples. hot summer days, regular openings, high room temperatures, hot foods and broken door gasket, leaving freezer/refrigerator doors slightly open overnight, could cause your evaporator (coils) to freeze/ice up. cases like this, unplug/disconnect your refrigerator, remove produce, clean and let it defrost, for an hour, make sure all ice melted. plug or reconnect your refrigerator let it work/ run empty for another hour, then put back your produce. sure it will work perfect for the next 3-4 days. (2) next type of defrost problem could be faulty defrost heater, defrost thermostat, you will have to open back panel on freezer side to check. check your defrost heaters, defrost thermostat and defrost timer, it's better to change defrost timer and defrost thermostat together, or change faulty ones independently. but before you change any parts, clean and defrost refrigerator first, could just be regular openings, hot days, etc. if after 3-4 days it started to ice up, then check following parts. defrost heater. defrost thermostat and defrost timer, let me know if icing occurs after 3-4 days then we can check those parts i suggested. remember to always disconnect/unplug your refrigerator, before attempting any repairs. good luck
Aug 21, 2009 | Maytag MSD2656G Side by Side Refrigerator
Freezer stays cold, but the fridge side does not
A small amount of frost on the back usually means lots more behind it on the evaporator coil indicating a defrost problem. check defrost heater, defrost thermostat.
If the heater and thermostat are ok it’ll be the motherboard.
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Part 801 on this diagram is your motherboard.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=GSS25JFMBCC&productCategoryId=0165000&brandId=0432&modelName=REFRIGERATOR-M-SERIES&diagramPageId=00002&componentDescription=SEALED%20SYSTEM%20&%20MOTHER%20BOARD&documentId=G0311228&backToLink=Return%20to%20Sub%20Components%20list
Aug 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
My refrigerator isn't cooling but the freezer works fine.
Hello and welcome.
Check the defrost terminator thermostat and the defrost heater. One or the other has likely failed.They are located behind the freezer panel.
Dec 14, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
GE Monogram freezer side working but refrigerator side is not.
Did you clean the condenser?  Is the unit FULLY defrosted?   Defrost fully!!!!!!
Did he check the amount of gas in the unit?  If your unit has low gas...it is in need of more.  R12 is expensive.
Check gas level:  Shut unit for at least one hour.  View compressor.  Several pipes...we're looking at the largest.  Start the unit.  This pipe will begin to frost.  If it does not clear to dry, ice or wet...stays frosted...it is low.  Get the repair guy back ... but ask how much he'll charge first.
Dec 12, 2008 | Refrigerators
Icemaker making too much ice & Freezer frosting up.
Hi gpss,
It sounds like you are getting large amounts of warm moist air into the freezer. This can be caused by the door being left cracked open or the door seal not sealing properly. Check your door gaskets on both sides of the refrigerator. One other possible is the ice chute. If it is not closing all the way it will cause the same problem. You will get alot of frost forming in the freezer then it will melt when the refrigerator defrosts. Let me know if this helps, and if you have anymore questions.
Mike
Sep 30, 2008 | GE GSH25JSTSS Stainless Steel Side by Side...
Frigidaire model # FRS26ZNHB2 side by side not cooling
T
From your description, you have a bad evaporator fan motor. The part number for a replacement motor is #5304445861.This is not a direct replacement but is more reliable.Remove everything in the freezer, take off the back panels and you will see the fan.
If there is a large frost buildup on the coils and the fan is turning you have a defrost problem. If that is the case, please call me at 334-347-0000 and I will walk you through it.
Jan 14, 2008 | Refrigerators
Refrigerator warm, frost in freezer
take back panel off freezer and check for ice build up which will block air flow and temps will rise. melt off carefully with a hairdryer.make sure drain is also clear and use hot water and patience if blocked with ice. if fault re-occurs, you have a fault with defrost system
Apr 24, 2007 | Hotpoint 21.7 cu. ft. Side-by-Side...
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
180 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
