Question about Horizon Fitness Merit Fitness 715T Treadmill
When you plug in the tredmill it usually beeps twice and is ready to go. Now when you plug it in it wither keeps beeping or does a really fast out of control beep and the computer lights blink randomly
There is a wire going from the right support post to a connector behind a small door underneath the console. Remove the door and make sure that the connector is properly plugged into the slot. It has probably worked loose due to vibration.
Posted on Jan 19, 2011
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 218 Answers
Console is malfunctioning and needs replaced
Posted on Aug 14, 2010
Why does kenmore dryer model 417.8804277 keep beeping when not in use?
If you have the 417.88042700 dryer, this is often a symptom of a control panel failure. First though, try resetting the dryer. Unplug the unit (or flip the circuit breaker to off). After 30 seconds to one minute, plug the dryer back in. Press Cancel twice to clear the PF message. Try running a short cycle and see if the unit beeps after the cycle is over.
Also check if you are getting brief power failures. Really short ones might cause beeping without the PF message on the display.
If neither of the above explain the issue, you probably need to check the control board or wiring for a short. A replacement control board is available here: http://www.repairclinic.com/PartDetail/b6p8/Kenmore-Dryer-Main-Control-Board/137008010/1472768?modelNumber=417.88042700 .
I hope this helps.
Aug 09, 2014 | Kenmore Dryers
Proform tredmill starts runs 10 sec and beeps twice and stops
I would suggest unplugging the unit from the wall and waiting 30 second and plugging it back in. Then go to where the AC cord enters the machine and look for a reset button or switch. Put it in the reset position and see if this solves the problem. Depending on model the reset may be on the bottom of console.
Dec 15, 2013 | Proform 520 Trainer Folding Treadmill...
I have a proform tredmill it will start and run for about 10 sec, beep twice and stop, you can start it again and it will do the same, i have replaced the reed switch already
hi there,
I do suggest ringing Icon Fitness and organizing a tech to come out and fix. The reed switch is rarely the problem with any treadmill.
2000 stratus beeps twice, flashes twice, repeats untill stopped, but it drives
This is usually a good situation to bring to alarm shop and have them take it out and see if you can just keep the remote start or it might need a new brain on the alarm system
Dec 10, 2013 | 2002 Dodge Ram 3500 Truck
Beeps twice then pauses and beeps twice again(repeats) and wont boot
When your computer emits beeps when you power on the computer, it's usually means that you have a memory issue. Try re-seating the memory modules and power on the computer. If you have more the one module, insert one at a time and power on the computer.
Dec 31, 2012 | Dell Inspiron 530s Desktop Computer
Scooter does not move either direction. when i insert the key i get 10 fast beeps and the 9 slower beeps
This scooter has an S drive controller. The beep code will begin with 10 very fast beeps followed by a number of slower beeps. The number of slower beeps indicates the actual code. It will do this only once. To repeat the beep code, remove and reinsert the key.
Beep code #9 is a possible controller trip.
Diagnosis:
The key may have been inserted during battery box installation.
The controller may be overheated.
The brake is dragging or pulling too much current.
Solution:
Remove the key from the key switch before installing the battery box.
If the problem persists shut down the scooter for 10-15 minutes and allow the controller to cool down.
Bottom line is that you may need a new controller or brake. Keep in mind these may be warranty items. A qualified technician may be needed to diagnose and repair the problem. Hope this helps.
Apr 16, 2011 | Pride Go-Go Ultra X 3-Wheel Travel Scooter
Left turn signal beeps very fast and signal light not working, now is working fine and so is signal light
When your turn signal goes out it tends to blink VERY rapidly before burning out, It's a nice way to let you know before hand that you need to replace the bulb soon.
Apr 27, 2009 | 2005 Hyundai Elantra
Horizon Fitness Merit Fitness 715T Treadmill Logo
459 people viewed this question
Top Horizon Fitness Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Craig Butler
Craig Butler
wtdash
Are you a Horizon Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
