Question about AOpen AX34-U Motherboard
Cracking noise My Sisters computer runs for a short time and then there is a loud crack and then it shut down and then restarts. running a aopen AX34-U. I reinstalled the memory chips. Would it be a crack in the Motherboard I think when the motherboard get hot something lifts or breaks the curcuit and then cools down and then ok again till it get hot again. I hope you can assist me with this problem. Many Thanks. Terry.
    President:
  • 2,351 Answers
Hi terry44,
Try this first. Open the case. Please ground your self by touching any metal surface. Than place your hand on the hard disk drive. Do not hold the underside. Start the PC & continue to hold & listen. You mentioned the system runs for a short time, let’s see if it will crack & shut down while you’re touching the drive.
We want to see if the system still shuts down & you hear that crack. If it’s the hard disk drive you will feel it as well as hear it.
If you feel like the crack came from the hard disk drive than replace the drive because its going to die. Your thoughts about the board could be correct. With the case opened you should be able to pin down where the crack is coming from.
Let me know if this helped & what you found.
Get back to me.
Good Luck!
Mike
Posted on Apr 21, 2008
  • Mike Peluso
    Mike Peluso Apr 21, 2008
    How to vote you're expert & also how to repost more questions for same problem or answer expert's questions.
    Enter FixYa.com site.
    Sign in to your FixYa account.
    Locate My Profile on our FixYa's homepage.
    Under My Problem locate your problem and click on it.
    Under the solution given by the expert, choose.
8 yr old 52 inch abruptly shut down, loud cracking noise and smelling Burt rubber.
Don't know if it is fixable. It may be a blown electrolytic capacitor or something more seriously wrong ?
Mar 26, 2017 | Televison & Video
Why would my harley davidson 1998 dyna wide glide stop running after a short trip after being shut off for 20 minutes and restarted?
when it shuts down does it sputter first or is the shut down immediate without warning. sputtering is usually a condition of lack of fuel.any intake leak at the manifold especially at the head will cause "sneezing" out of the carb. Restart can be difficult and intermittent. A weak ignition module especially the adjustable kind can be unpredictable. a lot of the after markets are adjustable.A 1998 scooter tells me you have an Evo and being it's 16yrs old the likelihood of having a stock module is nil. check the plug where the module plugs to the ignition harness as well. Often times,because of it's age,these pins turn green or they either bend or they pull out just enough to break contact. I've also experience cracking of the wire insulation causing temporary short. shutting down the engine and difficult restarts.As with all jobs,check the simplest and obvious and don't start buying parts until you have checked all connections especially at the module where it meets the ignition harness.
Jul 19, 2014 | 2000 Harley Davidson FXDWG Dyna Wide Glide
Cracking noise of Lexicon MC12HD
replace your hdmi cable between tv and preamp...lemme know if it works.
Feb 17, 2014 | Lexicon Audio Players & Recorders
Makes terrible sparking noise and then shuts off
this noise is from a bad Magnetron need professional repair
Feb 01, 2014 | Danby DMW799 700 Watts Microwave Oven
The indoor unit of my 1.5 T , 2 yr old split ac is making noise like cracking of ice or plastic whenever the compressor is tripped or restarted. I've noticed water leakage (splash) from indoor un
indicates dirty evaporator fins that are icing up
that will overload the compressor and trip it
the ni oise you hear is the ice breaking up and the splashing is excessive water in the blocked drain that cannot run outside
get in a technician to clean and service the ac
Nov 24, 2017 | Heating & Cooling
Washing machine making loud banging cracking noise.
Sounds like something's got between the drum and tub and is resting on the heater element. Remove the heater and check in the gap
May 09, 2012 | Washing Machines
Intermittent loud cracking noise when running, otherwise performs ok
Does the loud cracking noise normally happen at night when its quiet.
Anyway whenever it happens it is most probably the automatic defrost heater kicking in and the noise you hear is ice melting.This could cut in every 12/14 hours depending on system and would normally run for about 15 mins.After this time the compressor should cut back in and the unit will run as normal.
Hope I helped.
May 13, 2010 | Bosch Classixx KGV28323 Bottom Freezer...
The refrigerator run loud for twenty minutes or so then it stops for ten minutes and starts running loud again
If the noise is coming from the back of the fridge, it could be the compressor is dying. Its cycling and over heating shutting off then trying to restart a short time after once the thermal overlaod resets. You hould call a service tech sooner than later.
Apr 04, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Electric Kenmore Dryer runs short time (seconds) and then stops.
your thermostat/s are not doing their jobs. They are allowing your dryer to overheat and also if your dryer has not been cleaned out on the interior you might want to do that. I've taken out globbs of lint build-up in them.
Mar 25, 2009 | Dryers
Loud cracking noise sounds like fireworks and wont get a picture
It seems you have loose or cold solder joint connection problem,causing a cracking sound.The solution is to reworks or resolder the solder joint connection in power supply section, audio section and inverter section...
Hope this may help you;
Regards,
VOTIT
Sep 25, 2008 | LG RZ-37LZ30 37 in. LCD Television
AOpen AX34-U Motherboard Logo
49 people viewed this question
Top AOpen Computers & Internet Experts
Michael Galve
Michael Galve
David
David
Alun Cox
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
