Question about General Electric Microwave Oven
Ge microwave wes1450dm1bb nothing fuse good micro switches good do i check transformer next?
  • 19 Answers
SOURCE: Ge Spacemaker microwave jvm240 wv Micro hood combo.
sounds to me like the magnatron has shorted out. i don't know of a way to test them unless you have some high dollar equipment. a continuity test prob wont tell you anything. what reading did you get on the cap when you tested it?
Posted on Jan 06, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave doesn't have any power, ** Display, **thing...
Nice touch with the diagram. Thanks!
The neutral line passes through the cavity thermostat, which may be open. In the schematic, it's left of the center bottom.
In the pictorial diagram, it's located just below where you added the note "120V OK". Its top half is cut off in the picture and it has blue and white wires attached.
Also, the low voltage (LV) transformer shows fuses in its primary and secondary, although one or both may be internal and inaccessible.
It may also be a problem on the control board, which we repair nationwide for only $39.95 postpaid. Feel free to reply back if you need further assistance.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 10, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: GE microwave oven - just stopped stopped working
A microwave can be dead for many reasons.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
NOTE: There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting.
Posted on Jun 08, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: neff h7871
If it went dead almost immediately after pressing the Start pad, that\'s usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that\'s usually a failing high-voltage transformer.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.microtechfactoryservice.com/cap_test.html
http://www.microtechfactoryservice.com/diode.html
http://www.microtechfactoryservice.com/mag_test.html
http://www.microtechfactoryservice.com/xformer.html
We\'re happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jul 06, 2008
SOURCE: My GE microwave, model #WES1450DM1BB; serial #SM908139U, shows
When I try and heat some food, the microwave runs but doesn't heat anything, its a model wes1450dm1bb
Posted on Aug 23, 2009
How do I check the magnetron or the capacitor?
There are three microswitches
When checking a microwave oven that seems to operate properly yet does not heat first check for 110VAC at the primary of the large transformer.
Dec 13, 2017 | GE Spacemaker JVM1640SJ Microwave Oven
GE Profile JE2160 - Just stopped working. Touch pad works, light goes on when door opens. When starting, timer counts down, can hear a relay click, but nothing (no fan, no turntable, no magnetron. Fuse...
Hi
If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work. You should check the internal door switches, the high voltage circuitry and the circuit board for this kind of problems. But for that you will need a certified technician to help you make these repairs.
Aug 19, 2011 | GE JE2160 Microwave Oven
Where is the fuse located on a ge spacemaker micro
the fuse is located in the back close to the power transformer you have to take off the cover to get to the fuse.good luck
Feb 28, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM1650WB008 Microwave. Daughter used left
probably blew the magnetron or high voltage transformer DONT test either unless u discharge the capacitor possible shock risk that unit is still live even unplugged.... i wanna telll you these days that micros are disposable items because the parts are gonna cost more than just to buy a new one plus if any arching occured that same problem is gonna occur again if it did work so basicallly that miro is kapout... hope this helped
Jan 31, 2010 | GE JVM1650 1000 Watts Microwave Oven
Microwave Model WES1450DM1BB I boiled 4 cups of
Owners of a GE WES model might want to look at this blog post.
I'm sure the magnetron overheated and tripped the magnetron's thermal cutout.
I'd strongly suggest taking it back if you can.
Dec 24, 2009 | GE Microwave Ovens
Everything seems to work but not heat
the switch is ok. if it was bad itt would blow the fuse. ge had magnetron problems on the 1600 series. if you have an amprobe and are getting 110 volts from the control to the transformer. place the probe around just 1 wire to the transformer. if you get less than 12 amps replace the mag
May 18, 2009 | GE JVM1650 1000 Watts Microwave Oven
I have a ge profile microwave. When I plug in the microwave, it's fine. As soon as I hit the start button, the microwave blows the HVT fuse. I assumed that it was the diode and the capacitor that were bad....
Another possible option would be to cheak the door micro switches . They can also blow the ceranic fuses.also how did you cheak the magnatron?Did you remove it complet and cheak over the ceramic end area if it was bubled?
May 15, 2009 | Microwave Ovens
Mar 15, 2009 | GE XL1800 1100 Watts Microwave Oven
General Electric Microwave Oven Logo
178 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
