Hello sir, iam using mozilla 3.6 as my default web browser and i have a dsl broadband connection of 512mb speed. but unfortunately the browser takes pretty longer time to load. how can i fix it? secondly, is it safe to remove the prefetch files?
  • noklam Jul 18, 2010
    thanks for ur prompt reply solution. it fixed my problem. once again thanks and would be in touch again sooner.
  • 4,281 Answers
For that press windows key +r so you can see run type in run "%tmp%" without "' then press enter then you can see all temp files remove all temp files.Then type in run "prefetch" then press enter then remove all prefetch files. Type in run "chkdsk /r" then press "y" then restart computer then it fix and recover errors on harddrive . Also scan computer with updated antivrus .Remove cookies and temp internet files. Uninstall mozila then reinstall. Then it will work fast. It is very safe to remove prefetch and temp files. Let me know if you need further assistance. Thanks for using FixYa.
Posted on Jul 18, 2010
I HAVE A DELL DESTOP COMPUTER THAT SENDS CONSTNT ERROR MESSAGES
Hi Laurie,
Either the modem or the Windows Explorer you are using may not be up to the speeds you need in browsing.Is the modem running on 3G speeds[above 3.0MB per sec]?
Change the browser and try another one.
My recommendations:
Both of which are a free download for installation.During setup installations,set the browser[Mozilla/Google]as your default browser.
Hope this helps.Thanks!
Please rate this answer.
Oct 31, 2011 | Computers & Internet
My modem gets heated after half an hour or less. I am using dsl cable broadband connection. Would you please give me the instruction to stop the modem heating and also the browser to work faster
Unfortunately, there's no real way to stop a modem from heating up. But if it overheats, then you should probably get a replacement, as most modems get warm but don't overheat. Call your internet service provider and they should provide you with a replacement.
And about your browser, DSL is inherently very slow, so it will always be that way. There's no real fix for that as long as you're still using DSL. If you want faster speeds, try a different ISP.
May 15, 2011 | Computers & Internet
Sir i have reliance broadband nd i want to connect with beetel(450tc1)adsl2+router.how can configure it?plz tel me sir. Thanks....
please explain better whats a reliance nd?
by the way you need to connect the dsl port to the phone line
wire a pc to a lan port and boot you will get an ip address then you can run a command prompt type ipconfig that will give you a the default gateway address thats the router address
type that address on the browser , that will take you to the router log in page insert name and password for router
if has a configuration wizard follow that for the PPPOE settings or dsl settings put your client ( username ) and password for the internet connection ( provided by internet provider reliance ) save the settings reboot both the router and PC an that should do it
Jul 29, 2010 | Computers & Internet
I'm trying to set up my netgear WGT624v3 router with AT&T DSL. I used to have broadband and used the netgear router. Switched to AT&T DSL. Internet is much faster when I go from the modem to the...
Please follow steps to configure your router with AT&T
1. Please remove all the connections from the router. Connect power to the router and then connect a cable from the computer into any of the 4 lan ports on the router. Make sure the modem should not be connected to the router or to the computer.
2. Open up the Internet Browser (Safari, Internet Explorer, Mozilla Firefox, Opera, etc.).
3. Put http://www.routerlogin.com/basicsetting.htm in address bar.
4. On the basic setting page scroll to the bottom and click on Apply.
5. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
6. Click on lan ip setup under advanced.
7. Change the lan ip to 192.168.10.1 and under use router as a dhcp server change the starting ip as 192.168.10.2 and ending ip as 192.168.10.51, click apply and click ok for any popup message that arise.
8. Once the browser display some error message like CANNOT FIND SERVER, ACTION CANCELLED etc, Connect the dsl modem on the wan port of the router and restart the computer.
9. Power off the dsl modem and the router after making the connections.
10. Power on the dsl modem and wait till the dsl light comes on, then power on the router.
11. Open a web browser (Internet Explorer, Mozilla Firefox or Safari).
12. Access the router (http://192.168.10.1).
13. Login to the router (Username = admin Password = Password).
14. Click on Setup Wizard and then select "Yes" and Click "Next" on the detection window.
15. It should give you a "Dynamic IP Detected" or "pppoe detected"(type the Username & Password of your dsl account in case of pppoe detection) and then click next.
16. Click Apply.
(still doesnot work then click on basicsetting, it will say does your internet connection require login,you need to click on NO then very bottom there would be router mac address you need to select USE COMPUTER MAC ADDRESS then click on apply
17. Logout of the router.
18. Open up another browser window and try to access internet.
Hope it can resolve issue
Thanks for using Fixya
Apr 17, 2010 | NetGear WGT624 Wireless Router
TalkTalk Modem Smartax MT882 to Netgear RP614 problem
Well your modem and router IP is same thats why you can't connect your router with modem
your have changed IP of the router,please follow steps to resolved your issue
RECONFIGURE THE ROUTER:
3. Put http://www.routerlogin.com/basicsetting.htm or 192.168.0.1 address bar. press enter
16. Click Apply.
Hope it can resolved your issue
Happy to help
Apr 04, 2010 | NetGear RP614 54 Mbps 4-Port Web Safe...
No activity on my new speedstream 4200
Ethernet and DSL lights are indicating you have ADSL available on your line, and that you have computers connected to the router.
What has probably happened is that Optus did not set up the new router with your username and password. Go to thw following website for details on how to setup the modem.
http://help.optuszoo.com.au/help/dsl/connected/windows/optus_modems/speedstream_4200
Manual Modem Settings The Optus DSL Broadband self-installation CD configures all the necessary settings for your DSL Broadband service. You do not need to manually configure your modem if you have run the self-installation CD. While the following information is provided for your reference, using the self-installation CD is the recommended method for configuring your modem.
The Siemens SpeedStream 4200 ADSL modem can use either USB or Ethernet to connect to your computer.
  • If you are connecting via USB you will need to run the self-installation CD to install the USB driver before you connect your modem. The Siemens SpeedStream 4200 ADSL modem supplied by Optus has been customised for the Optus DSL Broadband service. Only the USB driver supplied on the self-installation CD will work with the Optus service. If you do not have the self-installation CD, you can download the latest drivers from the Siemens website.
  • If you are connecting via Ethernet it is possible to manually configure your modem without the self-installation CD. Only a web browser is required.
After connecting your modem there are two key steps to manually configure your modem for the Optus DSL Broadband service:
  • PC settings - Configure your computer's Ethernet network interface.
  • Configure Your Modem - Set the password in your modem's configuration pages.
top
PC Settings Step by step instructions are provided for each of the supported Windows operating systems:
  • Windows 98/Me
  • Windows 2000
  • Windows XP
  • Windows Vista
top
Configure Your Modem To configure your modem settings you must now access the configuration manager using your web browser. This is done by entering the IP address in the address bar of the browser window as follows:
Note: If you are updating the password in your modem, please complete steps 1 to 3 only.
Step 1 of 5
  • Enter http://10.1.1.1 (Default IP address of the Optus Supplied Siemens SpeedStream 4200) to access the modem Configuration software. You may wish to add this page to your Favorites for easy access later.
  • The following modem System Summary screen will appear.
ss4200_home_disconnected.gif Step 2 of 5
  • Click on the word Setup in the green menu of options on the left side of the web page. An expanded set of options will be displayed.
  • Click PPP in the list of options that appeared below the word Setup.
  • The ISP Password page will appear:
  • Replace the default username (john_citizen@optusnet.com.au) with the username provided for you by Optus DSL Broadband.
  • Replace the default password with the password provided by Optus DSL Broadband in the Password field.
  • Note: You will find your Optus DSL Broadband username and password on the letter you received with your self-installation kit.
  • Save these details by clicking the Save Settings button.
Step 3 of 5
  • The next screen will ask you to disconnect and reconnect to the Optus DSL Broadband service.
  • Click the link to return to the System Summary page.
  • Click the Disconnect button to disconnect the modem from the Optus DSL Broadband service. The text on the button will change to Connect.
  • Click Connect to reconnect the modem to the Optus DSL Broadband service.
Step 4 of 5
  • Click the word Mode in the green menu of options on the left side of the web page.
  • Confirm that Optus Bridge is the selected operation mode.
  • If Optus Bridge is not selected click the radio button next to Optus Bridge to select it.
  • Click the Apply button.
  • Click the Reboot button to restart the modem using your saved settings.
  • After about a minute the modem will return to an operational state and connect to the Optus DSL Broadband service.
ss4200_reboot_3.gif Once the modem has rebooted and the ADSL connection has been successfully established the DSL LED indicator will light steady green.
Your modem is now connected to the Optus DSL Broadband service.
Jul 25, 2009 | Siemens SpeedStream 4200 (13A4200001)...
Connection using DSL-2640T
Try diagnose and repaire the connection if that does not work Reset your modem it should go back to default manufacture setup.Then turn modem off and connect any computer or laptop to the modem with ethernet wire turn the modem on go back to your computer that you are connected to modem with wire go to network connections and disable the wireless Network connection and enable local area connection once you see you have connected and have internet working go to start menu you can do this on the start search bar with vista or run with any other windows version type cmd and press enter, it should bring a DOS command menu and then type in ipconfig and enter scroll up and down to where you see default gateway type that ip address to your internet browser it should take you to login screen username should be administrator password admin setup your WEB key make the wireless access available DO NOT FORGET to write the web key down, give a name to the connection and change the default password from admin to something you can remember. save the settings and turn that off keep the laptop on. Then unplug the ethernet cable and switch the network connectiion again enable wireless disable local area also you need to scan the available wireless internet and pick the one you just named use the webkey to access and save when the connection in made.
Feb 18, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
Browser will not open
If all fails you could try setting it back to factory!
Sep 30, 2017 | Acer TravelMate 529ATX Notebook
Siemens Speedstream 2624
Find the reset button on the rear panel of the wireless device and follow the factory reset instructions below: 1. Power Off the router. 2. Hold the Reset Button down while you Power On the router. 3. Continue holding the Reset Button until the Status (Red) LED blinks TWICE. 4. Release the Reset Button. The factory default configuration has now been restored, and the Router is ready for use. The DSL/Cable Router's default IP Address is 192.168.254.254 To establish a connection from your PC to the DSL/Cable Router: 1. After installing the DSL/Cable Router in your LAN, start your PC. If your PC is already running, restart it. 2. Start your Web browser. 3. In the Address box, enter "HTTP://" and the IP Address of the DSL/Cable Router, as in this example, which uses the DSL/Cable Router's default IP Address: HTTP://192.168.254.254 The first time you connect to the DSL/Cable Router, the Setup Wizard will run automatically. (The Setup Wizard will also run if the Router's default settings are restored.) This should get you in the right direction. ZT3000 "Beta tester of "0"s and "1's"
Aug 20, 2007 | Siemens SpeedStream 2624 Router...
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
