Question about Canon PowerShot S2 IS Digital Camera
Too much light in pictures
My camera had the problem of Black images before and I got it fixed with the solution provided here (The Iris problem)
But now my camera is giving trouble with Outdoor pictures where it is giving too much light making pictures totally white. I tried with all possible modes and reducing the exposure but didn't help. Indoor pictures are OK but not great as earlier.
The movie mode works well, the videos are as fine as before. Just the problem with the outdoor light.
Could you please help me out.
thanks in advance.
  • spawar2 Apr 21, 2008
    Actually I tried this one before but it didn't help. Thanks a lot for your solution though.
  • Maria
    Maria Apr 26, 2008
    I also used the "iris" fix, which worked fine, I can now take pics indoors just fine, color and everything else is good. No outdoor pics taken are good at all, almost a total white wash out. I also have changed settings to compensate for this, but nothing works, although some of the settings does give a somewhat better photo, even though most of the photo does still have the washout in it.
    Is there any other way to adjust/fix this problem?
    Problem Solver:
  • 4 Answers
Nikonian2, I've also tried this. Does not work for me either. Thank you..
Posted on May 06, 2008
    Scholar:
  • 154 Answers
Chack the white ballance and the EV +/- setting if possible set white balance to auto and EV to 0 (zero) or adjust the iso setting
Posted on Apr 21, 2008
My lumix camera will come on, but the display for the pifture is black, how do i fix this
I think most of these questions about black LCD's and black pictures relate to a stuck shutter. My Lumix LX2 has this. The screen is black and so are the pictures. On looking at the shutter through a magnifying glass I took a shot and I saw that the iris works fine, but the shutter did not open. I am sending the camera for repair at a reasonable rate from Clearer images here in the UK.This is the email: sales@panasoniclumixrepair.co.uk. Time will tell won't it?
Jan 13, 2012 | Panasonic Lumix DMC-LZ2 Digital Camera
My i85 camera's lcd no longer displays what you are looking at. Just a black screen. All the menu items are there and working. The battery is charged. The power button is working as well as the lens open,...
The iris is probably shut closed or the CCD is bad. The iris controls the amount of light that enters the CCD (charged coupled device). Sometime the iris get moisture inside and cannot open. Or the CCD is defective. Leave it in a dry environment for a day. If it doesn't cure then return it to the store for a refund because the CCD will need to be removed and replaced.
Dec 16, 2010 | Samsung i85 Digital Camera
I dropped my Canon FS100 camcorder a while ago and now it turns on, but there is no pictures. I can record, get audio, zoom, etc but the picture is just black. What is happening and how can I fix it?
The CCD may have been damaged and cannot process the image into an electrical signal or the Iris is stuck closed. It needs to be taken apart to fix.
Nov 01, 2010 | Canon FS100 Digital Camera
My camera started taking very bright pictures after more than two years of taking perfect pictures nothing has been changed on the camera setting and the blue light around the ok button is blinking now i...
More than likely the Iris that covers the CCD - just like in your eyes, is stuck open and cannot adjust to regulate the light to the CCD. Therefore you're getting bright pictures. The CCD is the component that captures the image and then converts it to an electrical signal to the processor or brain. The Iris getting stuck is usually caused by excessive moisture in the camera. The beach, where the humidity is high, will cause the iris to stick. Try leaving it in a dry storage for a few days to dry. Otherwise you'll need to take it in for repair.
Oct 28, 2010 | Kodak EASYSHARE M763 Digital Camera
A 620 canon camera iris does not open, photos seem
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
May 23, 2010 | Canon PowerShot A620 Digital Camera
Black Display Screen
first check the iris of the camera if it is opening,you will see this when you look inside the lens of the camera when you turn on and off the switch at camera mode if the iris is opening....if the iris is ok the second problem may occurs of your camera is the ccd image sensor....
Oct 31, 2007 | Sony Handycam CCD-TRV68 Camcorder
Black lcd screeen on my sony handycam
first check the iris of the camera if it is opening,you will see this when you look inside the lens of the camera when you turn on and off the switch at camera mode if the iris is opening....if the iris is ok the second problem may occurs of your camera is the ccd image sensor....go to a sony service center for replacing that...i know it is free for replacing that sensor cause that is the recall product not only on sony but in other brand because the manufacturer of their sensor is only one company....
Oct 19, 2007 | Sony Handycam CCD-TRV328 Camcorder
White outdoor pictures
Theres no better way than to open it and fix the Stucked iris!! You stored your camera for so long in the wrong side or not in standing position. Camera mechanism has oil and grease inside (that is the culprit why your iris is stucked), and will tend to settle in one spot if you will keep it not moving for a long time. But if you really want to fix without opening the unit try to use a black board with different size or adjustable center hole, this or these will serve as your camera iris, the brightest uses the smallest hole, experiment what suits you best.
Aug 26, 2007 | Samsung Digimax S1000 Digital Camera
Problem with DVRTVR22E
Aug 19, 2007 | Sony Handycam CCD-TRV107E Camcorder
Black LCD Screen
Faulty main or secondary board. Could also be faulty light sensor or iris. Not a user fixable problem unless you can get another f601 with a broken lens etc with good boards (to replace boards). Or a dead camera with good lens assembly (contains iris).
Very fiddly if you have the parts!!!!!!
Best advise is to sell it as faulty on ebay.
Aug 31, 2006 | Fuji FinePix F601 Zoom Digital Camera
Canon PowerShot S2 IS Digital Camera Logo
204 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
