Question about Whirlpool Calypso GVW9959K Top Load Washer
Wont start cycle
How do i get to the pump to check it
  • 975 Answers
There are two different cycles , WASH CYCLE , and RINSE CYCLE , witch one NOT working.
Posted on Apr 21, 2008
  • ALBERT GARCIA
    ALBERT GARCIA Apr 21, 2008
    OK , LETS GET THIS ONE SOLVE RIGHT AWAY , first lets check the problem , washers fills up but it WONT START CYCLE ??
  • ALBERT GARCIA
    IF IT WONT START CYCLE , check the magnetic switch or reed switch located underneath where the top door closes ,this is a safety switch ,check w/ a multimeter for continuity . hope this helps
Miele washing machine wont spin or drain
clean your filter first then check there is nothing in the pump area
Jan 22, 2014 | Miele Washing Machines
Samsung washer wont spin
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
Check this link for tips;
Jun 28, 2012 | Samsung WF337AA Front Load Washer
If oil pressure sending unit is bad will it stop fuel pump from working on a 2000 blazer
You should never try a pump without it being in fuel. It uses fuel for lubrication when it is running. If the vehicle doesn't start at all when you first crank it over it is not the oil pressure sender. If you just put the pump in you might want to turn the key off and on several times to cycle the pump then try to start it. If it doesn't start then check fuel filter or check fuel pressure at fuel rail in engine compartment. Is fuel pump cycling at all when the key is turned on? There is a problem with ignition switches on some of these blazers.
Jan 04, 2012 | Chevrolet Cars & Trucks
Washer wont go on cycle
If it's a machine that starts with a pump out first it may have a blocked pump. Have you tested in a different socket to rule out that?
Jul 06, 2010 | Washing Machines
Wont drain, no pump
Hi it sounds like a blocked pump needs cleaning out
Feb 17, 2010 | Dishwashers
Dishwasher wont drain, it runs through the cycles but wont drain
do u hear the pump at end of cycles.try starting it right at end of cycle.u should hear water pump out
Nov 24, 2009 | Office Equipment & Supplies
99 ram diesel wont start
Did you check to see if there is power to the glow plugs if not then that may be the problem and if there is power when you cycle the key not to start but for the plugs to warm up you may have a bad glow plugs.
Apr 22, 2009 | 1999 Dodge Ram 2500 4WD
Ariston Washer Dryer AML 105
i know it sounds simple but have you checked the filter and also check for foreign objects in the pump impellor
Jun 26, 2008 | Washing Machines
Wont pump water
If it did not pump at all I would say you had a bad pump. Try removing hoses and check for plug up. If there is no plug up, I would manually try to adjust the timer to see where in the cycle it does not pump. It could be a bad cycle timer.
Feb 04, 2008 | Hotpoint WMA30 Front Load Washer
Whirlpool front loader washing machine (AWO3361) WONT DRAIN
Remove drain hose from where it connects to the plumbing under the sink/tub. Inspect the spigot. If clogged, clean. If clean, then tilt machine back and remove drum to pump hose from pump. Check hose and also drain pump. Clear any obstructions.
Nov 03, 2007 | Washing Machines
Whirlpool Calypso GVW9959K Top Load Washer Logo
24 people viewed this question
Dan Webster
Dan Webster
Sal De
