Washing machine has burning odor
My washing machine motor burned out. I replaced the motor and coupler. The washer works well and spins well but I've noticed as the cycle advances towards spin that there is a burn odor emanating from the machine. I can't seem to localize the odor by just sniffing the various machine parts.
My machine is a Whirlpool LSQ8200HQ0
    President:
  • Washing Mach... Master
  • 2,651 Answers
Smell usually come from motor over worked, possibly under powered( check to make sure you have a110 volt, supply and not perhaps 100, possible bad start capacitor eminating small as well, its mounted either to the motor itself or on the back wall just below the water valve assy
Posted on Apr 23, 2008
I have a maytag model# mav2755aww, I have a burn smell when it's in the spin cycle. yes it is spinning the water is draining ?
Burning odor may be coming from a overheated motor under a heavy spin load.
Before going any further;
1.Make sure the circuit breaker for the machine is working properly and know its location.
2.Have a working fire extinguisher nearby.
3.If a electrical/motor fire starts, you need to turn off breaker power to the washer..Then use the extinguisher to put out any fire.
Try spinning the basket empty and see if the odor still persists if so, you need a new motor ..
If not, you have to think about the weight of the washload that the spin cycle must handle..
If a light load causes the same odor, stop using the machine until you replace the motor and check the transmission for any problems.
Oct 02, 2014 | Washing Machines
Washing machine does not spin.
Hi
Thanks for using FixYa. If your washer pumps out the water but doesn't spin, check these:
The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. The motor coupler may be broken. Many washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. A belt may be broken. The clutch may be worn. It may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor. The transmission may not be shifting properly. The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Replace whichever part has gone bad. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
May 08, 2010 | Admiral AW22 Top Load Washer
MACHINE STOPPED - BURNING SMELL COMING FROM WASHER
The burning smell is from your coupling and when this breaks the rubber spins across the plastic face of the opposite coupling. Your washer will not wash or spin until this is replaced. fortunately these are cheap and easy to replace. Refer to my step by step instructions to replace yours.
Here is the guide:
http://www.fixya.com/support/r4355933-washing_machine_repair_direct_drive
Mar 24, 2010 | Washing Machines
Burned rubber smell after replacing motor coupler, otherwise runs
The most common cause for the coupler failing is a bad gearcase. The machine should go through a neutral drain before the spin if it doesn't drain the water first it over works the motor trying to spin a full tub. No belt on this one, odor could be from the motor or the coupler starting to shred again.
Mar 01, 2010 | GE Spacemaker Washer and Dryer Electric...
My washer will fill up but then wont spin just makes buzzing sound
It doesn't agitate If your washer doesn't agitate, check these: Lid switch Motor coupler Belts Clutch Drive motor Drive pulleys Transmission Agitator Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. Motor coupler Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it. Belts Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.) Clutch If your washer was made by GE®, it may use a clutch for agitating the clothes. As the clutch wears out, it may prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician. Drive motor Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
Jan 05, 2010 | Maytag HAV3460AWW Top Load Washer
The agitator in my kenmore elite washer won't agitate. The water won't spin out. The basket turns, and we've had the clutch replaced. Any suggestions?
Jan 01, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore washer odor
The most likely cause of a burnt rubber smell is a worn motor coupler.
Sears parts site
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.24922200&pop=flush
Go to the sub section with the brake/clutch/motor/gearcase and item # 13 is the motor coupler between the motor and transmission.
It has three parts. 1. A plastic piece with three prongs fits on the transmission input shaft. 2. A plastic piece with three prongs fits on the motor output shaft and 2. a RUBBER grommet with 6 holes fits between them.
Over time, the rubber piece can wear and the two plastic pieces can rub against it at speed causing a rubber burning smell.
Replacing one is easy.
Remove the cabinet, the pump (2 clips) the motor (two screws and clips) and the motor mounting bracket (two 1/2: bolts).
Remove the rubber piece and pry off the two plastic pieces. Fit the new plastic pieces on the transmission and motor shafts. Replace the mounting plate. Carefully line up the six holes as you put the motor back on.
Replace the motor mounting clips, the pump and clips and cabinet.
Sep 10, 2009 | Kenmore 22422 Top Load Washer
Crown series 12 cycle washer will not agitate and smells like something is burning like a for instance a vacumme belt kinda smell in that cycle it spins fine fills fine drains fine but just makes a so
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
Drive pulleys The motor or transmission drive pulley may be worn and unable to turn the drive belt. If so, replace the pulley.
Transmission The transmission could have either of these problems:
  • Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may not agitate properly or at all.
  • The transmission may have a worn or broken gear, or some other internal problem.
If you suspect a transmission problem, you may have to call a qualified appliance repair technician to repair it.
Agitator The inside of the agitator--where the transmission shaft attaches--can become worn, and strip out the spline that allows the agitator to properly grip the shaft. Then the transmission shaft rotates back and forth as it should, but the agitator doesn't move properly. If this happens, you may need to replace the agitator and/or the transmission spline.
May 07, 2009 | Frigidaire FWSB5700DS Top Load Washer
Washing machine spins slowly and smells of burning rubber
The belt could be worn and will be slipping on the pullys, as it spins up the rubber , rubs against the pullys and that is what creats the burning rubber smell, the belt needs replacing.
regards jonno
Apr 21, 2009 | GE WBSR3140DW Top Load Washer
Kenmore Washer-coupling replaced-
Be sure that when you replaced the coupler, that you tapped on the rear (transmission) coupler. Take a long extension and a 9/16" socket and tap it until the shaft is flush with the inside of the coupler. Also, we have found that sometimes shaved rubber from the old coupler isnt rubbing or fell down in the area. Also, if you have it back out, be sure your new coupler doesnt show wear already. That would be an indication of a bad transmission, basket drive, or drum block.
Sep 05, 2007 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
243 people viewed this question
Top Washing Machines Experts
