Question about Sony KP-61HS10 61" Rear Projection Television
Convergence Settings Access
I have convergence problem since last week. I read people talking about setting it but how can you go to those settings? Is there something on the remote control? I opened my TV but could not see any where. So where are those
  • 1 more comment
  • DIY Freak Apr 21, 2008
    Thank you Slinteriors for the quick reply.
    I will try it and post later how it goes.
    Thanks Again.
    Slinteriors,
    Just wanted to make sure. My picture quality degrades and corrects.
    Sometimes the picture is very blurry and sometimes it's ok but the
    words on the screen are still sort of ghost. So my problem is
    definitely the convergence isn't it? I have already ordered the ICs.
    (STK392-560)
    Thank you.
  • weazy May 21, 2008
    I think I have the same problem. Horizontal looks good but vertical I get Green then color and red lines. Are these IC's replaceable without special tools. ZIF connectors, or do I need to solder?
  • Sony Master
  • 8,617 Answers
You will need to replace Both convergence ICs they are STK392-560 they are located on the d board mounted to large aluminum heat sinks. here is a link where you can get replacements as well as free installation instructions and on line tech support.
http://servicemanuals.vstore.ca/
Posted on Apr 21, 2008
  • Sonny Berry
    Sonny Berry Apr 21, 2008
    95 percent of the times its the convergence ICs that are the problem, and thats the easiest and cheapest to repair. If that doesnt work then you will need to trouble shoot further. But if you ordered through the link I posted they will go the extra distance to help you figure it out. thats on the off chance that the ICs dont fix it.
We can set the convergences great but after about 10 to 15 minutes ithe reds lines start moving a little again will not stay in position. It's a widescreen Mitsubishi rear projection tv ws-55857.
The problem - you're setting the convergence settings, but you're not saving them, you're
simply exiting the menu screen. Be sure to save your convergence setting for each
of the three colors. It sounds like you're setting RED last, and not saving its convergence setting,
whereas the GREEN & BLUE are holding their convergence settings, since you're saving them
correctly before proceeding on to RED....
Mar 15, 2011 | Mitsubishi WS-55857 55" Rear Projection...
Projection TV Convergence problem
go to the Mitsubishi service center to solve your problem
Jun 20, 2010 | Mitsubishi WS-65869 65" Rear Projection...
Can not find convergence on tv settings
Convergence settings are internal to the set on a circuit board somewhere. If you do not have a service manual for this set and some rather expensive equipment, it is unlikely you would be able to restore convergence.
Normally, convergence does not drift unless some electrolytic capacitors have aged to the point that they cannot maintain high enough voltage. This means that, even if you could find the pots that control the convergence, they would not be able to restore convergence.
The inside of a projection TV has DANGEROUS high voltages that can persist for WEEKS after the set is turned off. We are talking HEART ATTACK voltages.
You should have your set repaired by a qualified (insured) service technician.
Oct 10, 2009 | RCA HD52W59 HDTV Projection Television
RCA 52WM24 COLORS SEPARATED, AND PICTURE IS BOWED IN MIDDLE
Yes,convergence is dead,U know how to solder right?Buy the convergence kit,replace what in that kit.Also buy a DVD for instructions,never done this before,for safety reasons.Tries these websites Tv Repair World.com Or Ebay.com.
Sep 29, 2009 | RCA R52WM24 52" HDTV Projection Television
Tv has double image color red and a curl line on left upper corner also sometime in middle of tv it has line
This sounds like a problem with "convergence" of the TV. Convergence is the electronic aiming of the Red, Blue & Green projectors. Typical convergence problems look like double or triple images on part or all of the screen, wavy lines, curled edges, excessive red, green or blue color or tint, etc. Sometimes, convergence issues can be corrected in a menu setting of the TV that has to do with "Picture Settings" or "Advanced Settings".
If the colors are out of alignment a great deal or went out "all of a sudden" it will probably not be repairable via the menu adjustment described above - but is certainly worth trying.
If it does not straighten out with the menu adjustment, it will probably require replacement of the convergence integrated circuit(s) chips located in the TV. This was a big ticket repair years ago, but can be done sometimes for as little as $40 in parts. Don't let the low price fool you though.. It can easily take several hours (or more!) to access, remove & replace the components and reassemble the TV. Soldering skills are a must - and I'm not talking about soldering plumbing pipes here either. These are delicate electronic parts and need a 15 - 30 watt soldering iron and desoldering braid or solder ****** and LOTS of patience to perform CORRECTLY. As such, it is another "not a DIY project" unless you're willing to turn your TV into a large floor model paper weight. If you decide to attempt this repair, you should google your TV brand and model along with the term "convergence". Parts, costs and procedures vary by TV. Unplug the TV for a day or so before starting the work to let capacitors discharge fully - just to be safe. Lastly - don't forget the heat sink compound - it is an absolute *must*!
Sep 17, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Problem after replacing convergence board
Yes, you do need to set up the convergence in order to get the picture geometry correct. the antenna and maybe some other settings will need to be restored through the appropriate user interface screens. You will need your owners manual for a guide.
Jul 12, 2009 | Samsung HCM4215W 42" Rear Projection...
Setting the convergence is not a user servicable item. Such adjustments need specialized equipment for proper alignment. Have unit serviced by pro/tech
Apr 05, 2008 | Sony KP-61HS10 61" Rear Projection...
Resetting convergence daily on Toshiba 43h70
Hi Mark, tough call without putting a scope to the circuit, either the convergence IC`s are going bad, signal from DCU is going bad (digital convergence unit), or possibly bad solder somewhere in the convergence circuit, I`m afraid your going to need a tv tech for that problem, BMW Rider
Jan 02, 2008 | Toshiba 43H70 43" Rear Projection...
Key Functions
7,8,9 = select R, G or B
+100,0,PRE-CH = mute R, G or B
INFO = test/normal
4 = shifts from point to line, grid move
2 = restore factory
SOURCE = H/V select
ADD/DEL = Save
S.MODE = exit
MUTE = cursor forward
P.MODE = cursor back
Volume +/- = moves convergence left or right
Channel +/- = moves convergence up or down
1 = zero's all convergence settings (ugly!)
U/D/L/R = move cursor
SELF FOCUS = saves the convergence adjustment - do before exiting
Good luck.  I let a sub-standard service joint work on mine - they replaced the OEM chips with a higher wattage equivalent, and I've had nothing but problems ever since.
Oct 11, 2007 | Samsung HC-P4752W 47" Rear Projection...
Philips 60pp9202 sound but no picture
Sorry no pic, but if you look from back of set on deflection board(board with HV transfromer)big part with about 4 wires coming out going to your picture tubes. Looking close to leftside of board the last IC with heatsink shield standing up has a small 7 pin ic if looking on it you should see TDA8177 or something to that affect. This is the verticle IC. Since you have found the IC's (convergence) then the only thing left is to look for open fuses like 1300, 2004, 1900 etc and see if open. Concerning cost if you buy from www.bluestaronline.com these part are inexpensive so it wouldn't hurt to buy all. Rule of thumb, if set has color problem then Convergence IC, if no problem just went out one day while playing fine then Vertical, then the alternative if no sound the audio area, which is not common for this set. Hope this helps!
Sep 03, 2007 | Philips 60PP9202 60" Rear Projection...
Sony KP-61HS10 61" Rear Projection Television Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
