Question about Compaq Presario CQ60-220US PC Laptop
Hp Pavilion DV 8000 (dv 8113 ea) heats up then hangs & turns off
I have HP Pavilion DV 8113 ea laptop computer its an year old, it battery almost expired and gives only 30 mints backup. If I use some software like office or listen song it works good but when I use video call or do multipal tasks on it it starts hanging and if I keep on doing things it turns off it self as its power failed. the same happens when I play multipal videos (more then 1) on youtube or from my hard drive it reacts same. is it battery problem or power problem or some other?
  • 3 Answers
I believe that would be the battery I would get a new battery that should solve the problem. When you use office or surf the internet that does not require as much power as playing games and watching videos. Just buy a new battery and that should solve the problem
Posted on Jul 18, 2010
Hi. i lost my sound on hp dv 8113 cl few days ago
  • Hi, the best thing to do at this point is perform a "System Restore." Try to remember the exact "Date before the problem occur, or once you start the System Restore, ("pick a date going back more than 5 days"), check the dates and see if any of the dates seem familar. Pick the closest date prior to the "Sound going out!" Type in the "Search Window" from the start menu: system restore; scroll to find, and open. Follow all the instructions carefully for the process to be successful. "Hope it works out for you; if so rating the help will let me know, thanks."
Apr 25, 2010 | HP Pavilion dv8000z Notebook
Hp pavilion dv 8000 will not boot from DVD drive or Hardrive. It goes to LAN card regardless of precedent set in the BIOS
when u start ur system try pessing f8 or f10 or watever is the key for boot option nd from there u can select from which device to boot
Apr 05, 2010 | HP Pavilion dv8000 Notebook
I have a hp pavilion dv 1659 us (dv 1000) the sata drive goes bad
It will recognize the new drive if you were able to "migrate" your data from the old drive. If not, you can clean install by booting from an optical drive (changing your boot order at start-up) and using a new OS disk or your recovery disks. You might be able to perform a remote partition & format and install from one drive to the other with USB external enclosures for each drive and another computer (depending on the 100G drive's condition). I hope this helps.
Feb 23, 2010 | HP Pavilion dv1000 Notebook
My hp dv 8000 Pavillion laptop will turn on and then it immediatly shuts down after 5 seconds or so
Power drain would be a better solution in this case. 1.first shut down the comp 2.unplug the charger 3. remove the battery and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer .
and if this doesn't help
then try to take out the ram or memory chip from the computer and place it back.
Jan 12, 2010 | HP Pavilion dv8000 Notebook
Is there an antenna inside the hp note book dv 8113 cl. I am having trouble picking up wireless services and and my other hp zv6000 is picking them up just fine side by side the reason I ask I had my other...
These laptops are hit and miss wirelessly to tell the truth. Take the wireless card out and make sure the antenna is attached to the card properly. You will see the two wires. Often times one fo these connections is broken. If so reattaching the antenna will solve the weak connections.
Nov 08, 2009 | HP Pavilion dv8000z Notebook
Sound driver
You need to download the drivers from the Compaq/HP WEB support/download page. Make sure you select your model laptop and the XP or Vista Windows version of the drivers you require and install them. Use this link to download the drivers http://h18000.www1.hp.com/cpq-country/cpq_support.html
Jun 10, 2009 | HP Pavilion dv8000 Notebook
I have hp pavilion dv 8000 and i get the error
system BIOS on hp motherboard allow hp approved hardware to be detected.if you want install net adapter that was not approved you have to remove BIOS whitelist & then flash the hp motherboard with modified BIOS.
May 16, 2009 | HP Pavilion dv8000t Notebook
Dv 6000, won't power up
call hp [800-474-6836] if you are in warranty..... because there are certain steps to be followed by hp and they will fix it for free
Mar 14, 2009 | HP Pavilion dv6000z Notebook
IE hangs on HP Pavilion DV 7 - 1130us
Speed up your computer by:
-- cleaning system junk
-- optimizing computer services
-- optimizing internet
-- repairing registry
-- defraging registry
-- clearing browsers junk
do these things with some secure tool such as Intel Software Partner Reginout.
Dec 31, 2008 | HP Pavilion dv7-1130us laptop
Compaq Presario CQ60-220US PC Laptop Logo
217 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
