Question about Cell Phones
Hi i have a O2 XDA VENN (unlocked a and now to as Pantech Matrix PRO), and i'm traying to configurate the MMS service for the TMN mobile operator in Portugal. It don't now all the information i need and where to introduce then in the mobile phone, i tried to use the information on the TMN site for other sites, but some thing is missing. Best regards And Thank
  • pgeraldes Jul 18, 2010
    I tried contact already my operator company (TMN) but they don't now the model.
  • pgeraldes Jul 20, 2010
    Hi how can help?
    President:
  • 2,047 Answers
The mobile device is for O2 and therefore unless you unlock it you will not be able to use it for most if the functions which other networks provide.
When a phone is locked it means it already has factory settings for that particular network provider set as default. Unless the phone is unlocked other setting for other network providers cannot be used. Probably you have all the settings in place but when the phone sends an MMS request it still uses the O2 setting so it comes back as an error. But if the phone has been unlocked then all you have to do is go to connection manager and change your preffered setting for MMS.
Hope this solution has been helpful?
Posted on Jul 20, 2010
    The mobile phone is unlock, i just don't now how the insert the information, and if i have all data i need for mms, the internet and the rest work fine
    regards
  • 1,284 Answers
Hi. since the phone was originally designed to work on 02 XDA, it will in most cases be difficult to configure the setting of another network on it like you intend to do expect if you ask TMN mobile to setting you the settings which they may likely not send because they don't have the model (Pantech Matrix PRO) of the on their network. (If they have, thy will send to to you).
So you may not be able to use the MMS service on the TMN network because of the phone.
Am a phone expert...
Take care
Posted on Jul 18, 2010
    hi,
    But the O2 XDA VENN ou Pantech Matrix Pro have windows mobile 6.1, i now that it's possible to configure, but the TMN don't now how.
    Information on the web
    Acesso TMNI9
    Start
    Settings
    Connections
    Connections
    No menu My Work Network
    Seleccione Add a new modem connection
    E preencha os seguintes campos.
    Enter a name for the connection
    TMNI9
    Select a modem:
    Cellular Line (gprs,3G)
    Next
    Acess point name:
    wap.tmn.pt
    Next
    User name: tmn (minusculas)
    password: tmnnet (minusculas)
    Domain: * nao preencher
    Advanced...
    Finish
    Carregar em OK (canto superior direito)
    De volta ao menu Connections
    Escolha Manage existing connections
    Escolher mytmn
    No menu Proxy Settings deve configurar:
    this network connects to the internet
    this network uses a proxy server to connect to the internet
    proxy server:
    nao preencher
    Advanced...
    Escolher WAP e configurar:
    Server 172.30.2.22
    porta 9201
    Username:
    password:
    domain:
    Carregar em OK (canto superior direito) até voltar ao menu principal.
    Start
    Settings
    Connections
    GPRS Setting
    Please select your GPRS autentication method
    [] PAD authentication (seleccione esta)
    CHAP authentication
    carregar em OK (canto superior direito) até voltar ao menu principal.
    Nota:
    Para utilizar a ligação WAP deve criar endereços/favoritos começados por wsp://, por exemplo, wsp://tmni9.pt
    Para utilizar a ligação internet deve criar endereços/favoritos começados porhttp://, por exemplo, http://pda.sapo.pt
    Configuração MMS
    Start Settings
    Connections
    Advanced
    Select Networks
    Programs that automatically connect to the intenet should connect using:
    MyISP (NãO ALTERAR)
    Programs that automatically connect to a private network should connect using:
    New...
    Enter a name for these settings:
    MMS
    Modem
    New...
    Enter a name for the connection:
    MMS
    Select a modem
    Cellular Line (GPRS, 3G)
    Next
    Acess point name:
    mmsc.tmn.pt
    Next
    User Name: tmn (minusculas)
    Advanced...
    Finish
    Carregar em OK (canto superior direito) até voltar ao menu Network Management
    E preencher:
    My Work Network
    Carregar em ok (canto superior direito) até voltar ao menu principal.
    Start
    Messaging
    Menu
    MMS Configuration...
    Em preferences deve preencher os seguintes campos:
    Retrieve messages immediately
    Download on home network onlu (opção do utilizador)
    Save sent messages (opção do utilizador)
    Reject all messages
    Allow delivery report (opção do utilizador)
    Allow read report (opção do utilizador)
    use signature with this account (opção do cliente)
    Signature:
    Attempts before giving up:
    Photo resolution: Original
    Na opção Servers
    New (premindo e mantendo)
    E preencha os seguintes campos:
    Server name: mms
    Gateway: 10.111.2.16
    Port number: 9201
    Server Adress:http://mmsc/
    Connect via: MMS
    Sending size limitation: 100k (opção do utilizador sendo que 100 é o valor máximo)
    WAP Version: WAP 1.2
    OK
    De volta ao menu MMS configuration deve activar o servidor criado (Set as Default)
    APN INTERNET
    Start
    Settings
    Connections
    Connections
    No menu My ISP
    Seleccione add a new modem connection
    Internet
    Select a modem:
    Next
    Acess point name:
    Internet
    Next
    Username: não preencher
    Password: não preencher
    Domain: *não preencher
    Advanced...
    Finish
  • Shehu Pro
    Shehu Pro Jul 20, 2010
    O.k..
  • 5,081 Answers
Just contact the TMn customer service department . Usually they will send a setting in the form of a message which will prompt you to save it and you are all done to get the MMS going..
    hi,
    I already tried that. the TMN say that don't now the model, and how it works
How do i unlock pantech c300?
If your phone purchased in USA on or after 26 January 2013, please contact your network/service provider and get their permission to unlock your phone with a help of third party online unlocking service provider.Using network unlock code is the best way to unlock your Cingular locked Pantech C300 mobile phone.If you need an unlock code visit Classicunlocking.com Here you can unlock your mobile phone within a day.
Apr 03, 2013 | Pantech C300 Cellular Phone
UNLOCK MY PANTECH CELL PHONE
You can unlock your Pantech cell phone using unlock code.But you need to mention the model ,Country and current network provider to get the unlock code. Visit Onlinegsmunlock.com and select your phone model and give the Country and current network name and get the unlock code.
Mar 28, 2013 | Pantech Cell Phones
How do you unlock a pantech 6010
It's PANTECH P6010 also it's knows as PANTECH PURSUIT II..
You can get the Unlock code for this Phone at
Simpleunlocking.com/pantech-pursuit-ii/rs16wp9/ and Unlock it from network Lock easily.
Oct 02, 2012 | Cell Phones
8digit unlock code
Unlock Any Pantech phone at cheaper price $0.50 onwards
http://unlockpantechmobile.com
Unlock Pantech C740 Matrix,
Unlock Pantech C790 Alladin-Duo,
Unlock Pantech C810 Duo,
Unlock Pantech C820 Matrix Pro,
Unlock Pantech P1010,
Unlock Pantech P2000 Breeze,
Unlock Pantech P2020 Ease,
Unlock Pantech P2030 Breeze III,
Unlock Pantech P6010,
Unlock Pantech P7000 Impact,
Unlock Pantech P7040 Link,
Unlock Pantech P7040P,
Unlock Pantech P8000 Crossover Android,
Unlock Pantech P9020 Presuit,
Unlock Pantech P9050 Laser,
Unlock Pantech P9070 Burst,
Unlock Pantech P8010 Flex,
Unlock Any Pantech,
Unlock Pantech,
Unlock Pantech Mobile,
Unlock Pantech Phone,
Sep 15, 2012 | Pantech Crossover (P8000)
A friend gave me a pantech c530 it needs to be unlock any help?
There can be many ways to Unlock your phone. As far as i know unlocking by codes is the simple and safe way. I will suggest the website Unlock-Zone.com which is doing good service and they were recommended highly in the cell phone forums.
I used them to unlock my cell phone. contacted them and within 30 mins i had my unlock code and my phone was unlocked.
Hope this helps.
Oct 04, 2011 | Pantech Slate Cell Phone
I need a code for my pantech matrix c740
What type of code do you need ? Security code or unlock code.......
If you want the unlock code means get from this site http://www.onlinegsmunlock.com/pantech-c740/rs7wp9/ , it provides the step by step instructions and simple methods for unlocking your pantech mobile at a safe way.............
Jul 07, 2011 | Pantech Matrix Cell Phone
Can i use this phone with t-mobile internet(t-zone)
Yes, you can. I just bought an unlocked pantech duo and i have t-mobile services.
what you need to do is make sure you change your internet and mms settings.
this website here will give you step by step instructions on how to change them.
http://www.howardforums.com/archive/topic/1347310-1.html
Apr 03, 2010 | Pantech Matrix Cell Phone
Unlock pantech c3 rogers
can you help me unlock my pantech c3 cell phone. I dont have the master code.Pls. Thank you
May 28, 2008 | Pantech C3 Cellular Phone
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
