Question about Samsung LN-S2641D 26 in. LCD HDTV
Not Available in current mode
I have a 26" Samsung LN-S261D HDTV, I can see the picture but ther is a box in the center that says not available in the current mode. I have spoken with Samsung. They had me take the batteries out of remote, change the source and it is still flashing "not available in Current mode." When I push the source button, it will have a fuzzy screen and in the top left corner it switches from av 11 to av 60 to av 62 and just keeps going like there is a stuck button.
  • 1 more comment
  • ggmoulton Nov 23, 2008
    I have the same problem.  "not available in current mode".  And, when I use the menu it keeps toggling thru the menu choices without being prompted.  Please help.
  • rosssie Nov 27, 2008
    I have the same problem the LN-S4092D model
  • Anonymous Mar 20, 2014
    When I press on the AV button no response and I opened the input sources I found only TV is highlightened while others like receiver are not
    Problem Solver:
  • 61 Answers
You could a pinch in the wire going to button assy
Posted on Nov 19, 2008
My samsung hdtv his stick on shop mode
go thought this url http://www.samsung.com/in/support/howtoguide/supportHowToGuidePopup.do?howto_guide_seq=10&prd_ia_cd=02010100&map_seq=591&udt_dt=Oct%2012,%202007&page_gb=D&model_name=&type_ia_cd=02010000
Sep 12, 2010 | Samsung LN-S2641D 26 in. LCD HDTV
My Samsung LN-T2653H is having problems with power
Possible bad(bulged) capacitors on power supply board, and possible bad main board, too.
Apr 18, 2010 | Samsung LN-T2653H 26 in. LCD HDTV
32'' Samsung LCD HDTV - will not turn on
needs power supply board replaced. VERY common problem, can call 1-800-samsung for nearest service center.
Dec 29, 2009 | Samsung LN-S3241D 32 in.LCD HDTV
Not available in current mode message
True that.. whatever device you have connect does not support the resolution its pushing.. You need to investigate what resolution your device is pushing try lowing the resolution to supported ranges and bingo you got a fix. You do not understand how to do that look at the user manual.
Oct 22, 2009 | Samsung LN-S4041D 40 in. LCD HDTV
Samsung LN-TFT-LCD Television
The first time this happened to me, I unplugged the power cable from the back of the TV and then held the power button on the front in for 5 minutes. Its tedious but, it clears the memory out of the TV and should work.
The second time it happened my first method didn't fix the problem.  So try this:
1. Press "MENU" on the remote. If you're problem is the same as mine, then the menu is jumping around very eratically so you'll have to time your button presses accurately.
2. In the  "Picture" Category turn ON: DIGITAL NR, DNie Demo, Film Mode, and Blue Screen.
3. Exit the Menu, and Unplug the Television.
I let my Tv sit for about 2 weeks before I turned it on again, but when I did the "Not Available In Current Mode" message was gone, but replaced with smaller blue message boxes that say DigNR, DNie, and Film.  I then went back into the MENU and turn OFF: DIGITAL NR, DNie Demo, and Film Mode and the problem was gone!
Jul 31, 2008 | Samsung LN-S3251D 32 in. LCD HDTV
Box right in the middle of my tv-
make sure it is turned off on the tv and the cable box. if that dose not fix it it may need a main board
Jun 30, 2008 | Samsung LN-S4692D 46 in. LCD HDTV
BLACK BOX
ok, with a samsung go into your menu then down to the setup tab and you should see the caption sub menu under there.
also a samsung it is on your remote that came with the tv or should have, Hope this helps.
Jun 28, 2008 | Samsung LN-S3251D 32 in. LCD HDTV
When vewing tv sometime a box pops up saying not available in current mode
try changing the hdmi cable to hdmi1 slot, also try with component cables, since they are HD also. also check to see if tv is in air or cable status
Jun 09, 2008 | Samsung LN-S4692D 46 in. LCD HDTV
Samsung LN T2653H
You can find the schematics for the tv at the following link.
http://www.eserviceinfo.com/index.php?what=search2
May 26, 2008 | Samsung LN-T2653H 26 in. LCD HDTV
No Picture
You may have a bad power supply. The worst case scenario is a defective panel. This power supply is very easy to change. Part number BN96-03057A
Average cost is $77.00
Best regards
circuitcity
Oct 17, 2007 | Samsung LN-S3251D 32 in. LCD HDTV
Samsung LN-S2641D 26 in. LCD HDTV Logo
1,024 people viewed this question
Henry  Thomas
Henry Thomas
