Question about Apple iPod nano 5th Generation
Ipod nano 5th generation. problem with short battery life.
Ipod nano 5th generation. Am now using second replacement - despite charging battery first time overnight dont get more than 6 hours use playing music or radio before needing new charge, whether charging from laptop or mains ipod charger. have made necessary settings to reduce power consumption eg screen saver. Am I doing something wrong or is there a basic battery fault here?
EverGreenEle
  • 25 Answers
SOURCE: Ipod nano and ipod video 5th generation
First off, simply press the center and menu buttons at the same time to reset the iPod video. That is the common way to fix a frozen iPod.
In regards to the Nano, sounds like the scroll wheel is defective. We would recommend replacing the scroll wheel if a reset does not do the trick.
Rick
EverGreen Electronics
Posted on Mar 14, 2008
SOURCE: ipod nano - stopped working - will not come on anymore
i had the same kind of problem...i found out i can reset my iPod
actually i did that by connecting Ipod to computer one finger from one hand to press the Center button, and one finger from the other hand to press the Menu button i did it for several seconds and for a few times..then its started again...
Posted on Dec 15, 2008
dvdcdlaser
  • 1285 Answers
SOURCE: Ipod shuffle (2nd gen) completely dead
you are still under warranty...take it to the sony apple store...they will fix it /replace it or tell you there is cost if it not the battery (note do not tell them you charged overnight, and for the future do chage any gadgets more than 3-4 hrs) when you do charge over night you are actually shorten the battery life span or overcharge....so as soon as you come home from school,work,whatever cell/ipod or any other device needs to be charge...charge it now and unplug before you go to bed....
Posted on Jul 05, 2009
rcalorisian
  • 313 Answers
SOURCE: My 3rd Generation iPod Nano died and won't charge.
You may just need to leave it plugged in for a few hours and see if it comes to life. It is usually the case.
I am sure you will be fine.. give it a try
Posted on Sep 09, 2009
SOURCE: My ipod nano 5th generation will not sync - error
http://support.apple.com/kb/TS2830 the instructions from this link worked for me though it's not for the nano
Posted on Feb 16, 2010
How to reset a ipod5 five generation
Toggle the hold switch on and off (Slide it to hold, then turn it off again)
Press and hold the menu and center (select) buttons simultaneously until the apple logo appears, about 6-10 seconds. May need to repeat this step.
Apple Support iPod iPod nano 5th generation Troubleshooting
Feb 12, 2015 | Apple iPod nano 5th Generation
What is wrong with my ipod ao 5th generation
Flip the iPod Nano's "Hold" switch to "OFF."
The iPod Nano cannot be turn on if the switch is set to "ON."
Reset the iPod Nano. Move the "Hold" switch to "ON" and then "OFF."
Then, press down the "Select" and "Menu" buttons on the Nano. Hold those buttons for about eight seconds.
The Apple logo will then become visible on the iPod Nano. Once this occurs, try turning the iPod Nano on once again.
Connect the iPod Nano to an iPod charger or a computer that is turned on via the iPod Nano's USB cord. Charge the Nano for at least 30 minutes.
Then, try to turn the Nano on.
Update the iPod Nano's software.
Connect the Nano to your computer via the player's USB cable. Open iTunes, and click the iPod Nano's name on the left part of iTunes.
Click the "Summary" option at the top of iTunes. Then, click on the "Check for Updates" button that's positioned in the middle of iTunes.
Follow the instructions that appear inside iTunes in order to install the updates on the Nano.
hope this helps
Sep 23, 2012 | Audio Players & Recorders
How to use an ipod nano generation5? what to do with it how to play more games how to charge
Plug it into your computer and connect with iTunes. Sync your music. This will also charge it. I'm not sure what kinds of games are available on the nano. If you want games get an iPod Touch.
Jan 11, 2011 | Apple iPod nano 5th Generation
Its not charging
Patty:
It sounds like the battery has reached the end of its usable life.
If the iPod Nano that you have is the same that is pictured above, then ifixit has a procedure for replacing the battery.
Note: The repair is listed as "Difficult", so you may be challenged by it:
http://www.ifixit.com/Guide/Repair/Installing-iPod-Nano-2nd-Generation-Battery/422/1
Thank you for using FixYa and Happy New Year!
Jan 09, 2011 | Apple iPod nano
Ipod Nano 5th Gen. 3 months old and died--won't restore either.
A possible problem with the battery. Battery life depends on how you frequently used the devised and how you handled the proper cycle to charged and drained the battery.
Battery charging should complete it's charging hours and you have to properly fully drained the battery at least once a week, this will make the battery life go longer.
Initially try to plug and connect the Ipod into your computer and see to it that it was turning ON, or it was giving any sign that it was responding when you connect it to the computer.
Is there any incidents happen that you got a problem on charging the unit, or any like incidents like power outage on the area or a short circuit on the device charger?
Let me know here again for further instruction and clarification.
micro~
Feb 23, 2010 | Apple iPod nano
This watch is compatible with ipod 5 generation 8 GB
This watch is compatible with iPod 5th generation (video); iPod Nano 2nd generation (aluminum) 2GB, 4GB, and 8GB; iPod 5th generation (video) 60GB and 80GB; iPod Nano 1st generation 1GB, 2GB, 4GB; and the iPhone.
Feb 08, 2010 | Timex Ironman iControl Watch with iPod...
5th generation ipod will not charge
It could be something wrong with the main board or a faulty replacement battery.
hope this helps at all.
good luck :)
Jaxon
Oct 04, 2008 | Apple iPod MA446LL/A MP3 Player
Sad face icon
To reset an iPod with a Click Wheel, including: ipodnano3.jpg ipodclassic.jpg icon_ipod_5g.gif ipodnano2.jpg ipodnano.jpg ipodphoto.gif ipodg4.gif ipodmini.gif
  • iPod nano (3rd generation)
  • iPod classic
  • iPod (5th generation)
  • iPod nano (2nd generation)
  • iPod nano
  • iPod with color display (iPod photo)
  • iPod (Click Wheel)
  • iPod mini
  • iPod mini (2nd generation)
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
Dec 06, 2007 | Apple iPod MA446LL/A MP3 Player
Apple iPod nano 5th Generation Logo
139 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Parshiv Luthra
Mohamed Ismail
Mohamed Ismail
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
