Question about Canon CanoScan 3000F Flatbed Scanner
Colour change Yesterday, all photos to be scanned have turned yellow in the scanner! What has happened, as I've scanned masses of photos and documents without any problem? Thank you for any help. Jennie
Try using "Multiscan" as scan mode in the box that appears when you click on the software button. It did the trick for me.
Posted on Nov 06, 2012
  • 2,016 Answers
In the Advanced tab for the scanner software, there is a tab labeled Color/Colour. On this tab, select the "Reset" button. This should return all color adjustment options to their default setting. If this does not resolve the issue, you may want to try reinstalling the software, but there is also a possibility that the unit itself has some problems.
Posted on Apr 21, 2008
How do you scan a document using a pc?
The printer can be used for scanning without a computer in sense of the scanner offering a copying facility - in B+W or Colour just by pressing the appropriate button on the printer. However, for scanning via the computer, if you are using a Photo programme (like say Adobe Photoshop or virtually all such programmes) normally you will find under the FILE menu (when programme is open) that you should see a menu item on the drop down menu when you click on FILE something like IMPORT - and the Epson printer will be seen listed in the menu that pops up. If you click on that, the Epson scanner programme will start. Normally there is a simple mode but you can change that to the PRO (or may be called Advanced mode) when you can do things like PREVIEW - which will then scan the document or photo in the scanner - and you can in the PRO mode change such as the resolution, what type of documents and so forth. When the Preview runs, you will see the document appear after the quick scan in the main RH panel. You can use a select tool to select the bit you want to scan if not the whole - most into on this will be in their manual - which you should have on the CD that came with the printer. Anyway - always worth ensuring you have the latest drivers, etc. so go to this link on the Epson website, click on Scanner Driver and Scanner Utility and download and install. Whilst on the Epson website, download the manual for that model as it will answer many queries for you as regards printing and scanning. All such info and software for downloading is under SUPPORT area - you select the region in the World where you live, then search for your printer model. The Epson website will normally auto-detect your computer's operating system to ensure you get the right version of Printer Drivers, other software and so forth. If you have no Photo Programme as yet - get Faststone Image Viewer (free) as an excellent programme. http://www.faststone.org/FSViewerDownload.htm
Jun 25, 2014 | Epson Stylus Multifunction Inkjet Printer/...
My scanner scans colour photos in a red and terquise colour. How do I fix this?
you might have to uninstall the scanner restart your computer then reinstall your scanner
if your printer/scanner came with an installation disc the drivers could be on it
you might have to uninstall the printer/scanner restart your computer then reinstall the printer/scanner and its drivers
click start control panel administrive tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you might see a yellow?question mark this will mean you need to install a new driver for this device right click you will have options to update driver,disable,uninstall or select properties again you will have the similiar options also have option to troubleshoot
lift the lid on your scanner lay the photo face down then select scan document/photo it will ask what format you want to scan it then it will ask where you want to save it browse select the file/folder where you want to save it (my pictures) most common
hope this helps
May 22, 2011 | Computers & Internet
When I hit scan, to computer, photo to file, nothing happens
the drivers for the scanner might have been corrupted
click start control panel administrive tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you might see a yellow?question mark this will mean you need to install a new driver for this device right click you will have options to update driver,disable,uninstall or select properties again you will have the similiar options plus you can troubleshoot
hope this helps don
Mar 12, 2011 | Computers & Internet
Red and yellow streaks appear in scans, always in the same location. The scanner was cleaned but the repair person could not find any problem with the equipment. Yet the streaks persist. How do I resolve...
execute a calibration to correct the wrong color:
  1. place your photo on the scanner, with a distance of 0.25 inch from the edge of the glass
  2. open Epson scan and select Professionnal Mode
  3. select the document source
  4. select the image type
  5. uncheck thumbnail then click Prevew
  6. crop the area of the image
  7. Click zoom to fine tune the area you see the streaks
  8. select the resolution of 72 dpi
  9. scan your photo
if the problem still not solved, you need to change the scanner unit , there are many dead pixels.
Dec 09, 2010 | Epson Expression 1640XL Pro Flatbed...
Printer HP Colour Laser Jet 2600n Hello, Our printer is smudging a lot recently, I?ve scanned a document so you can see what I mean! We?ve cleaned the runner and changed all the cartridges, but it?s still...
if you have more that a year with you printer, maybe the mirrors and lenses of laser scanner are dirty, try to disasembly and clean it, 90% ara that the problem.
Aug 18, 2009 | Office Equipment & Supplies
Hp scanjet2300c scans have a yellow tint and black patches.
The best way to check if the scanner is okay or not is by installing on another computer. First try B&W, then try color. IF it works may be your OS or driver (of the old comp) is corrupted.
S. Mohan
Dec 22, 2008 | HP ScanJet 2300C Flatbed Scanner
Text
 Chexc kteh boxes to see what  you have selected.
Colour photo
Grey Scale
Black and white
Oct 25, 2007 | Mustek A3 USB Flatbed Scanner
How do I scan colored paper and still read print? HP Scanjet 8270
First thing to try is just play with all the scan settings to see what gives you the best result - try changing resolutions, type of document, type of output document, contrast, brightness, type of scan. If this doesn't give you any better results, then one of the best ways to do this is to get some plastic sheet of the same or almost the same as the predominant colour on your forms (you can go one step further and make a multi coloured filter if you are feeling creative and your forms are all identical). The text jumps out of the page and most scanners will give you a good scan - just make sure the filter is not too thick/dark. Hope this helps :)
Jun 25, 2007 | HP ScanJet 8270 Flatbed Scanner
Canon CanoScan 3000F Flatbed Scanner Logo
182 people viewed this question
old marine
old marine
