Pc bleeps constantly when switched on. Monitor says no signal.
  • 12 Answers
SOURCE: NO Signal to monitor
Make sure your computer is off then: 1- keep press and release "F8" button on your keyboard while turning your computer on. 2- you should see a black screen with some text on it. choos "Safe Mode" If you still can't see anything you need to make sure all cables are connected and are not damaged. If still have problem you need to open your computer case and fasten all cables and cards because when your son pulled the cabel this could moved your computer case unsafely and loosen the cables inside. If you still have problem this means your hard drive has been damaged due to sudden movement while it was operating.(even if it's not operating sudden movement coulds damaged the hard drive). you need to buy a hard drive and install a fresh window on it but if you can not do it. Find your local computer repair shop (Yellow page- Thumson Local ...) Good Luck Please let me know of your progress and leave me a good feedback. Kind Regards
Posted on Oct 09, 2007
map9966
  • 2351 Answers
SOURCE: monitor doesnt switch on
Can you try another monitor?
Since you did try another video card (AGP). I posted (In you're other post), you have to make a bios adjustment under Advanced menu. Once you're P4SP-MX bios is set to boot to the AGP or set to Enable. The bios will no longer try to load the on-board VGA card. I am not being picky about the statement I am going to make ( so don't be offended). Monitor's only receive signal. They do not send signal to PC, just receive. The odds of two video cards not working is high. You did mention you have not heard P.O.S.T (A single beep), which is a test of the motherboard. There could be a loose connection in you're PC. I would remove the memory first. Clean the contacts with alcohol on a cotton swab & blow out the memory slots with canned air (allow time to dry). Than firmely reseat the memory. I would than re-check all data & power connectors within the PC, making sure all are securley connected. With respect to the AGP card, I would do the same. Remove, clean & reseat. Most older AGP's require additional power. Some use a power cable that is also used to power a floppy drive & others use a 4 pin molex (see link),
http://pinouts.ru/connector/4_pin_Molex_power_connector.shtml.
When you are in the bios & within the Advanced menu you may also need to set the bios to read you're AGP card to the correct speed. (EX: 1x,2x,4x). Page 2-19 in you're manual. Once all these checks & cleaning have been completed, try again. Boot the PC and hopefully you will see display on you're monitor.
Post here. Let me know how thing go. Don't assume anything, check all.
Luck!
Mike
Posted on May 13, 2008
  • 114 Answers
SOURCE: CPU bleeping constantly.
Yes that means the computer has failed POST. So yes, something has come loose or has got damaged.
"POST" is an acronym for Power On Self-Test. The POST process checks the basic system functions before attempting to load an operating system. It checks RAM, processor, drives, system interface, etc. If POST fails, the system will normally halt and may produce a series of beeps from the computer speaker which can help indicate the cause of the problem.
Posted on Jan 17, 2009
  • 107 Answers
SOURCE: When switching on PB not loading and is realising loud bleep
yes the beep pattern. btw , try checking your memory if you have 2 of them on try removing the other 1 then turn on pc. n do it vice versa. if
Posted on Jan 24, 2009
  • 1566 Answers
SOURCE: Hi I have an acer desk top pc and when i turn it
Hi!
You need to check on your CPU. You get the no signal informational message on your monitor if the computer itself is not running.
The beep may indicate different errors. It could be an issue with the a faulty memory card or the graphics (video) card. Try to use a blower to clean the inside part of the CPU. And then re-attach the memory card to their slots.
You need to take note how many beep it gives you. This could be very useful in helping you pin point the exact issue.
Posted on Nov 13, 2009
Why does my acer aspire z5761 keep freezing and has horizontal lines across screen and constant bleep?
You probably somehow killed the screen. Did you drop it or bang it into something? You can try downloading and replacing the drivers, but I doubt that will help. Lines on the screen are usually a physical problem, not software related.
You may try a Windows Restore if your machine has that ability. Some do, depending on who you bought it from. Again, doubful it will help, but worth a shot.
Need more information on the bleep. When does it bleep? Constantly? When you touch the screen? Or when you boot it up? What kind of bleeps? One? Several? Long? Short? Both? Repeating sequence?
Jun 28, 2015 | Acer Computers & Internet
Pc boots up, but shows no signal on monitor. then pc will no shut off
check all leads to your hard drives and make sure they are a tight fit.if its bleeping on start up then check all leads.
check your vga lead from your tower to your screen.
Mar 27, 2015 | Computers & Internet
Drum goes round, only cold air circulating and no heat to dry washing, machine is constantly bleeping and signalling end of drying cycle
If you pull the panels off you should find the tech sheet to help diagnose your machine. But in you case sounds like it need to be taken apart and cleaned and check the limit switches.
Jan 15, 2014 | AEG T58840 Dryer Electric
The hard drive constantly bleeps
try to reseat the memory first, its usually the one causing bleeps in pc.
Mar 29, 2010 | Buffalo Technology 1TB DRIVESTATION COMBO...
Jan 22, 2009 | Acer Aspireā„¢ T180 PC Desktop
Jan 17, 2009 | Computers & Internet
Switches on & bleeps
try to check the cable connection between the monitor and the tower. what is the color of the LED light on the monitor?
Oct 27, 2008 | Dell Dimension 3100 PC Desktop
New Mobo & Processor but nothing happening
You need to have a PSU greater than 450watts. that could be the problem..
Sep 22, 2008 | Computers & Internet
New Mobo & Processor but no Bleeps etc
Could be the power supply is not strong enough to power the system. Replace the power supply with one that is between 350 - 450 watts. This should provide ample power to the system.
Aug 05, 2008 | Computers & Internet
Computers & Internet Logo
14 people viewed this question
Alun Cox
David Payne
David Payne
