Question about Samsung SCX 4521F All-In-One Laser Printer
Hardware connection issue when scanning
Hello - I am trying to scan a document, but am getting an error message that tells me I am not able to connect to the device (the printer/scanner). I have restarted both my PC and the printer. Any suggestions?
Thanks!
  • kasubeck May 21, 2008
    How do I use the scanner function on my samsung scx4521f?
  • 161 Answers
Your USB cable is too thin, or too long, or both. USB signal loses strength beyong 6ft. Use a good quality, thick USB cable and if tha unit is over 10 ft. from the computer, use a USB active repeater.
Be blessed.
Posted on May 28, 2008
    Genius:
  • 2,785 Answers
Try by reinstalling the device driver
Posted on May 13, 2008
What is the error 017-988 for phaser 6128mfp
It's a scan from PC error. Most common problem is that the destination folder for scan does not exist. Does it give that error on just a plain text document as well? It could be the document type and settings. Hardware wise could also be a main board issue.
Oct 20, 2014 | Xerox Phaser 6128MFP AllInOne Laser...
Server connection error when scanning
have you set up your scan Email account with you page Scope disk with the copier. is the server set up for scan to email. Also check the konicaminolta web site for scan operator manual. Down load the scan programs
Mar 24, 2010 | Konica Minolta Bizhub c203 Copier
Cannot scan documents
go to device manager look for imaging device (scanner) right click and uninstall. / click scan for hardware changes tab, found new hardware must be appeared and click next / select don't search, i will choose the driver to install / click show compatible hardware and choose scanner driver found and click next. and finish.
Feb 11, 2010 | Fujitsu M3091DC Path-Through Scanner
ok try disabling the printer the enable it. almost like rebooting the printers drivers... if that dont resolve the issue then try reinstalling the printer incase that some of its drivers has bcome corrupted or uninstalled.
Nov 11, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
An error ocurred communicating with the scanning
Hi I will be glad to assist you in this issue. here is the libk that will fix the issue:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00897542&cc=us&lc=en&dlc=en&product=391153
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00040499&cc=us&lc=en&dlc=en&product=391153
Nov 05, 2009 | HP Officejet 7210 All-In-One InkJet...
I have a brother MFC 9440CN when I try to scan a document the error message comes up as not being connected to pc. The cable is definitly connected as the print option works fine. Can you help. Thank you.
Are you scanning from the PC, or are you scanning from the printer?
If the latter, the scanner is trying to send the document to a server software on the PC, which is probably not running; hence the "not connected" message.
Try acquiring a picture using Control Panel -> Scanners -> Acquire Image and see if it works. If it does, you must run (or reinstall) the Control Center software, and configure it as to where to store the Scan-to-File documents.
Nov 02, 2009 | Brother MFC-9440CN Laser Printer
Scanner not working
Hi Jkey !
As per the information you have provided, I understand that you are receiving an error "No scan option refer to the documentation" on the printer, when you try to print from the front panel of the printer (I mean from the printer's side).
However, plz provide me the proper error message so that I can assist you in the best possible way. If you are unable to scan from the printer's side, then try to scan from the computer and check if it is working or not. It should work when you try to scan from the computer, if not there may be a communication issue between the two devices.
To check the communication perform the below steps:
IF the printer is connected via USB cable, then perform below steps:
Useful scripts For Windows XP:
To isolate the issue I suggest you to try scanning from the Windows Image acquisition(WIA) wizard on the computer.
Follow the below steps to Scan using WIA
1.Verify that the all-in-one product power is turned on and the printer cable is properly connected.
2.Click Start then Click All Programs then Click Accessories then Click Scanner and Camera Wizard.
3.Follow the Scanner and Camera Wizard instructions to scan images to the computer.
If you are able to scan fine using the above steps, please write back to me along with the exact error message.
With Regards
Mike.
Jun 27, 2009 | HP Photosmart 2575 All-In-One Printer,...
Scanning negatives on CanoScan 600F, I get an error message "Cannot write or read. 252.0.0"
The Canon support site is the place to go for that if your Manual does not tell you.
However remove the software and reload it - it may be as simple as that.
Dec 26, 2007 | Canon CanoScan LiDE 600F Flatbed Scanner
Samsung SCX 4521F All-In-One Laser Printer Logo
182 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
