Question about Dryers
I need to connect 2 dryer vent hoeses together in order to reach the window where the vent is. What can I use to do this?
  • 625 Answers
Use a small length of 4 inch aluminum vent pipe and two screw clamps
Posted on Apr 21, 2008
No air blowing out of unit
Hi Robert
Sounds like a clogged vent or blower trouble.
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But...if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Heating Element
Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace the heating element. You can check for an ohm reading but will need to refer to the service manual for proper reading. This sometimes on the tech sheet located somewhere on the dryer. Usually between 9-13 ohms.
Cycling thermostat
Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork . This thermostat usually has four wires going to it. Check the 2 terminals that are opposite each other and are the closer together of the 2. These 2 terminals should have continuity. If not replace the thermostat.
Bud
Oct 11, 2013 | Avanti Dryers
Heating but not drying, doesnt seem to be blowing very strong through dryer vent
Hi cipera11...
I think your problem is a clogged or cogging vent
Heating Element
Cycling thermostat
Please take time to rate me thumbs up.
Sep 11, 2011 | Amana Dryers
Taking a long time to dry.
Hi dawansd
Clogged Vent
Heating Element
Cycling thermostat
This is a Free answer, Please rate me.
May 25, 2011 | Dryers
The Dryer has hot air but the clothes are not getting dry?
Clogged Vent
Heating Element
Cycling thermostat
Apr 14, 2011 | Maytag MDE6000 Dryer
Dryer takes forever to dry clothes. now it will not dry clothing
Clogged Vent
Heating Element
Cycling thermostat
Apr 11, 2011 | Dryers
Runs for 15-20 min and shuts off when restarted it will do the same
Clogged Vent
Heating Element
Cycling thermostat
This is a free answer, Please rate me.
Oct 10, 2010 | Roper REX4634KQ Electric Dryer
My maytag neptune dryer is taking twice as long to dry cloths. i've had it 5 years & it's gas.
Clogged Vent
Cycling thermostat
Oct 05, 2010 | Maytag Neptune MDG5500AW Gas Dryer
MY KENMORE DRYER IS TUMBLEING BUT IT WONT DRY M CLOTHS
Clogged Vent
Cycling thermostat
Oct 04, 2010 | Kenmore 73952 Gas Dryer
Vent hose is too short
Yes you can connect 2 together, obtain 1 longer hose or use a fixed rigid pipe suitable for hot water etc - similar to drain pipe. All these shouled be readily available from your local plumbing supplies store.
Oct 05, 2009 | Dryers
Dryers Logo
66 people viewed this question
Top Dryers Experts
