Kenmore drop-in electric range plug melted
Hello- Yes it can be fixed- first, make sure outlet is not damaged. If it is, it will need to be replaced. Next, plug is wired into a terminal block on back of unit. With care, this cord is easy to replace. And safer than it was before. A loose plug, or wire caused the fireworks. Let me know if this info helps- have more if needed. -Thanks- ED
Update on my range..it was not the fuse but, a screw that came off from were the nobe is located. I could not believe that cost so much troble..I did not give that screw coming off a second throught until I told my huband he screw it back on and like magic my rang TURN ON...
When I presses on the simmer button, that's when my range completely shut down. What do you think is the problem? I have tried the breaker and still nothing. My husband has opened the back to take a look.
