I have an Acer 5633 that will not come out of hibernation. the on light comes on as does the led on the dvd drive and a fan runs for approx 5 seconds, then it just sits there like a plastic brick. I have tried taking the battery out and running it from the mains aadaptor only with the same results. There are no POST bleeps.
  • 2 more comments
  • barmysod Apr 21, 2008
    would that I could disable hibernation, The machine doesn't boot at all
    The machine went into hibernation the awfully nice windows xp told me that.
    I appear to have c..ked up and put this question in the pc desktop category, it is in fact a notebook, my appologies
    Nothing appears on the screen at all and there is no power on self test. The power light comes on as does the dvd busy light, the fan runs for a few seconds and then goes off, the lights stay on.
  • 30 Answers
Disable hibernation in the power settings. I've run across many computers that do not respond properly to hibernation mode, and that do the same thing. It's easier to simply disable hibernation mode and have it fall into sleep mode instead.
Posted on Apr 21, 2008
  • 1 more comment
  • Arthur Dellea
    Arthur Dellea Apr 21, 2008
    Well, if the machine is not booting at all, then it is not hibernation. It's a good chance that either your monitor is dead, or even the motherboard in the computer is dead. First, I would try a second monitor, borrow a friend's if you don't have one. If that doesn't work, then you definitely need to take it to a local repair shop, it's too serious for you to fix yourself.
  • Arthur Dellea
    I reread your initial response. You noted that you tried even with the battery out, unbfortunately most laptops will not run properly (or at all) if you try to run them plugged into AC without a battery in place.
    Can you describe to me what happens when you power the system up, on the screen? Do you see anything at all?
  • Arthur Dellea
    OK, I was curious as to how XP told you that it was in hibernation when you cannot see anything on the screen, that confuses me a bit.
    Narrowing it down, the three main things that I feel it could be are...
    • A bad or broken screen
    • A dead battery
    • A dead motherboard
    I'm hoping that it's not the motherboard, but if it's not POSTing, then there's a pretty good chance that is the problem.
    Sometimes a dead battery can cause this to happen, as I noted most laptops won't even boot without a working battery in place. From what I've seen, most laptop batteries only last about 5 years on average under regular use. If the battery was only holding a charge for 30 minutes or less before this happened to you, then chances are that you need to buy a new battery, or a refurb battery.
    To see if the screen is bad, you could try connecting it to someone's computer monitor and booting up. In most cases, laptops will auto-switch to the external monitor and use that instead. If you see the screen on bootup when connected to a monitor, then you know the screen is dead. I just got a card the other day in the mail for laptop screen repairs, http://www.microreplay.com
I cant make my Acer aspire 5536 work
Sounds like the hibernation and hard drive setting need looking at under the power controls, also check that a password is not required in returning from hibernation.
Sep 13, 2014 | Acer Aspire 5536-5224 Notebook
Does not switch on but power on light is on
I would remove the battery, power supply, RAM and hard drive. Plug the power supply in and see what happens when the power button is pressed. If nothing, there is a motherboard issue, possibly a GPU error. If it comes to life, re assemble bit by bit until the culprit is found.
Jan 14, 2014 | Computers & Internet
Acer aspire m3640 no power light hard drive light on
Check/reseat monitor cables. If the fan and HDD are running, perhaps the power led is out. Check the monitor cable connections. Is the monitor plug into AC? Turned on? Shut down Desktop , unplug, reseat Graphics Card, if applicable, reboot.
Dec 13, 2012 | Computers & Internet
My hp a6700f desktop has a problem with booting up or coming out of hibernation. It seems everytime it restarts it goes to sleep and I can not revive it. The fans come on and the DVD drive starts up but no...
You can turn off the hibernation in the power option control panel, but that may not be your problem, the power supply may be going bad, but I would turn off the hibernation first and see if that resolves your problem, if not get another power supply. I hope this helps. Good luck and have a nice day.
May 01, 2011 | HP Pavilion a6700f PC Desktop
Hi, My Optical drive is not working in Acer Aspire 5633 wlmi laptop. So I have bought an external DVD drive and now I want to make that as default optical drive. How can I make it? BIOS is not allowing...
AS the new drive is a USB drive, you cannot make it default via the BIOS as the BIOS has no control over the USB device installed.
You can however configure Windows Backup/restore to default to the USB drive for the purposes of Backup and Restore.
Hope that helps.
Jan 04, 2011 | Acer Aspire™ 5633WLMi PC Notebook
How do i tell if my acer computer has a bad power supply or motherboard, without buying a new power supply first?
The chicken and the egg comes to mind here!
Does the cpu fan come on? CPU 5 Volts is on
Can you open and close the DVD draw? 5 Volts is on
Does the Hard drive spin up? 12 Volts is on
Do the lights work on the keyboard? POST has completed.
Does the hard drive light work? CPU is on
Not sure what else to suggest but Power Supplies are not that expensive and fairly universal.
Hope that helped.
Jan 04, 2011 | AcerPower S260 PC Desktop
Acer Aspire One in permanent hibernate ''coma''
There have been times when Ctrl + Alt + Delete has brought the desktop back up. Usually, hibernation is disrupted by simply pushing the power button once, the computer will eventually come out of hibernation. Most clients I have done work for have me take hibernation off completetly, this is done in the control pnel under power options. There is a tab specific for hibernation.
Nov 30, 2009 | Acer Aspire One AOA150-1570 Notebook PC
Acer Aspire ZG5 Power Led showing yellow
Hibernation is the biggest creator of software nightmares...it has killed more computer systems and corrupted more systems than I can count. Go to control panel > power options and change your power settings in there. Turn hibernation off and just have the computer go to sleep after a certain time. You will find that the computer will come right back in sleep mode and will be ready for action. Don't worry about the system running until sleeping and then waking up, it's a lot better than finding your entire operating system is now corrupt and has to be re-installed.
Sep 15, 2009 | Acer Aspire One PC Notebook
Acer 5110 won't standby properly
Check the power-save settings / properties. You may have to hit a specific key to "wake" it up. To make things worse, sometimes you have to hit yet ANOTHER key to wake it from hibernate.
Jan 11, 2008 | Acer Aspire Notebook PC
Open Questions:
Toshiba technical support customer care number +1888784-9316 With 24x7 major subsidiaries and affiliates worldwide, Toshiba Corporation is known as a world class innovator and global high technology product leader worldwide. Toshibha launched laptop computers from its kitty way back in 1985 and by Financial Year 2010 they have managed cumulative shipment of more than 100 million Laptops. Toshiba has been known to set benchmarks when it comes to quality and features that results in exceptionally high performance. In spite of the exceptional features you may experience issues related to data recovery, backup and security and may be deprived of any support by the Toshiba Support. In the event of an OS Crash there is always a chance that you may Toshiba Support your critical data. Virus attack or accidental data deletion are also some of the other reasons that could cause mess. An updated backup will warrant that you do not lose your critical data forever. DataAlign comes to you rescue in these situations. DataAlign offers comprehensive technical assistance for your computer's data backup, recovery and security. DataAlign lets you schedule backups to execute daily, weekly or monthly. Our award winning cloud backup Toshiba Customer Service lets you schedule your backups continuously throughout the day. Data Align gives you affordable services that saves you both time and money and that lets you take control of other important things in life like growing your business or spending time with near ones. TOSHIBA is known for its diversified product range and services worldwide. Still, there are several issues that a TOSHIBA user can face on the TOSHIBA computer. Problems faced by TOSHIBA customers BIOS update Toshiba Backup Slow Performance Windows 10 upgrade Data Backup and Transfer Office and outlook setup Wifi and Internet Issues Audio & Video Issues Startup and Boot problems Windows updates Computer Tune-up Issues Virus Removal Issues Our highly talented and expert IT Team can help you fix most of the issues that you face with Toshiba Virus . And the best thing is that we can help you get your data backed up on our secure cloud storage. Why Our Toshiba Help Desk Number Technical Support Team Are Best? With several years of experience in our kitty working with a wide variety of customer group, we have gained an edge when it comes to providing technical support for TOSHIBA Computers. To add to it, our expert technicians trained specifically on TOSHIBA computers are always ready to help you best possible solution for any issue that you may face with your TOSHIBA product. 24X7 availability and assistance for your TOSHIBA computer. We have a dedicated & experienced support team to handle issues for your TOSHIBA computer We ensure little to no downtime with maximum uptime and highest productivity for your TOSHIBA Computer. We ensure Data backup and retrieval assistance We ensure end to end ownership & solution for issues you face with your TOSHIBA computer. Quick and efficient support over the remote. You can sit back & relax while one of our techs fix the issue for you. All these issues and many more, concerning Toshiba users are directly and efficiently resolved by our technically knowledgeable team who can be Reached 24/7 on our Toshiba Contact +1 888 784-9316.
Apr 25, 2018 | Toshiba Computers & Internet
Computers & Internet Logo
133 people viewed this question
David Payne
David Payne
