Question about Euro-Pro 9120 Computerized Sewing Machine
Bobbin case problems with machine, model 9110 sewing machine
My bottom bobbom wont catch how do i fix the timeing or restart settings?
Posted on May 08, 2008
  • hillbillie May 08, 2008
    it wont thread
How to fix the operation buttons on a 9110 euro pro
check and make sure the bobbin winder has returned to it's normal position for when you sew
May 09, 2016 | Euro-Pro Shark 9110 Sewing Machine
Why does the bobbin case pop out and jam the thread?
First check that the thread in the bobbin is facinf the correct way. Then check tension on top. Also check to see if you have the same thread on top and in bobbin. Also needle and material can cause the bobbin to jump. Make siure that the needle thread stays where it should, if one of the threading sites come undone this can cause bobbin jump too.Hope something here helps.:-)
Mar 13, 2015 | Euro-Pro Shark 9110 Sewing Machine
I have a EURO -PRO model 9110. The bobbin tension is not correct.The top thread can be easily pulled out after sewing.How do I adjust the bobbin tension?
Hi janna
have you tried adjusting the top tension first?
if you have a drop in bobbin then it has to be adjusted at a sewing shop
the bobbin case you take out of the machine you can, using a small screw driver,,here's how
lower bobbin tension--
to test the bobbin tension,
remove the bobbin case & bobbin,,
hold it by suspending it by the thread,,
**** it once or twice,,
if the tension is correct, the thread will unwind by about an inch or two
if the tension is too tight, it does not unwind at all
if the tension is too loose, it will drop too much
to adjust turn small screw on the side of the bobbin
to the left is tighten
to the right is loosen
Sep 21, 2011 | Euro-Pro 9120 Computerized Sewing Machine
What is the name for the case that holds the lower bobbin on the euro-pro 9110? It is made of plastic and sits inside of the needle plate. I need to be replace it but I can't locate the part number...
its called the bobbin case, check these sites for one
sewingpartsonline.com
sewvacdoctor.com
sewingpartsdirect.com
whitesewingcenter.com
sewingsupplywarehouse.com
sewforless.com
some of these site you might have to email & ask them about the part
Sep 12, 2011 | Euro-Pro Shark 9110 Sewing Machine
Euro-Pro Shark Intelli-Sew 9110
you need a new bobbin case, only problem is finding the right one. I am currently wasting hours trying to find one for our 9110 intelli sew which has needle holes punched through it from where it jumps right out. I think lots of manufacturers know fine which parts fit the Euro-Pro but would like all of us to scrap them and go out and buy theirs!
Aug 28, 2008 | Sewing Machines
Shark 9110 won't thread bobbin
The same thing just happened to me, but I am miising a piece that fell off. Make sure there is a little metal wire piece on .the bobbin winder, if not that is your problem
Jul 23, 2008 | Euro-Pro 9120 Computerized Sewing Machine
Bobbin case problems with machine, model 9110 sewing machine I cannot seem to get the bobbin thread up (there are supposed to be two threads on the outside). Instead the thread on the needle gets stuck...
First, rethread the machine and be sure the thread passes through the take up lever. If it still does the same thing, remove the needle plate to access and remove the bobbin case. Check the bobbin case for burrs, scratches or any rough spots. If you find one it needs to be buffed with an emery stick or sharpening stone until it is smooth and then buffed with some steel wool. Clean out any lint you see and reinstall the parts.
sewman7
Jun 26, 2008 | Singer 3116 Simple
Won't catch bobbin thread
In order to see whether or not my euro-pro 9110 had a timing issue, the service rep had me change out the needle (making sure I was using anything but a Singer brand needle--they do not work in these machines). I re-threaded the needle, took out the bobbin casing and the plastic ring encasing the bobbin, then lowered the needle to see if the hook on the metal ring holding the bobbin actually catches the thread on its own. If it doesn't catch, it's a timing issue and needs repair. They can walk you through this process of troubleshooting and set up repair if need. Call Eruo-Pro's customer service center for sewing machine service and repair at 800-798-7395
Apr 17, 2008 | Euro-Pro 8260 Mechanical Sewing Machine
Euro-Pro 9120 Computerized Sewing Machine Logo
109 people viewed this question
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
