Need info on mod kit for horiz output on Toshiba 51h93.
  • 2,326 Answers
Check the info from this link.
There is more info on the first PDF file from this link just download it.
Posted on Apr 21, 2008
  • Jaime Hernandez Apr 21, 2008
    The best place to find this kit is Toshiba. Call them and ask them to provide you with that kit, It might even be free of charge as this is something they missed during their design or testing.
  • 19,396 Answers
Do you have the part number, which kit do you need ?
Tv will not turn on even when reset button is pushed all you hear is a clicking noise
You need to replace the power supply on your set, this happen when horizontal output fail.
Dec 18, 2010 | Toshiba 51H93 51" Rear Projection HDTV
Horiz output failure repeatedly?
can you please provide the TV model and part #.
Thanks
Apr 15, 2008 | Toshiba 51H93 51" Rear Projection HDTV
Cross Reference part
The original transistor for the Horizontal output is a 2SC5588 you can get an original at the following link.
http://servicemanuals.vstore.ca/
Feb 01, 2009 | RCA D52W19 52" Rear Projection Television
Will not turn on
if main power supply is working check sub power supply.should be 1.5 volts on pe 42 pin8 and 9.
if missing replace ce36 and ce 39. i mounted mine caps on foil side.
May 20, 2008 | Toshiba 51H93 51" Rear Projection HDTV
Toshiba 51H93 .
check for cracks in the driver circuit, also i believe this maybe on of the models that had a kit that helped from driving the h-output to hard causing it to get hotter then normal.
Apr 11, 2008 | Toshiba 51H93 51" Rear Projection HDTV
Horizontal output transistor failure
check b+ comming from p/s. also check for blue flat caps in line with h-output circuit. if blown out the side. remove them from circuit. also might have a HVT goin bad. I believe this is also the model that might have a mod for h-out running too hott that requires adding a resister in the h-drive circuit. also try a heavier duty h-output.
Apr 09, 2008 | Toshiba 51H93 51" Rear Projection HDTV
Horz. Output Transformer for a GE Mod#46GW945
Check this guys: //http://www.electronica-usa.com/
This guys may carry that part: //http://www.globalsemi.com/search.aspx
Jan 24, 2008 | GE 46GW945 46" Rear Projection Television
TENGO PROBLEMA CON TV MOD. 27PT6441 37 PHILLIPS POR CAIDA DE RAYO CERCA DE MI CASA
Part # 483531057673 Horiz Driver kit...............................T.
Dec 06, 2007 | Philips 27PT6441 27" TV
High pitch noise in 27PT6441.
Check regulator and large filters in PS. Capacitors.
Sep 21, 2007 | Philips 27PT6441 27" TV
Televison & Video Logo
Top Televison & Video Experts
