Sky remote code unavailable? Is it possible to use sky remote for hanspree tv?
  • 7 Answers
Hi you can get your sky remote code by pressing interactive then going to sky customer service (Option 4) then choosing your code it will remind you what it is :) I hope this helps and also im pretty sure you can use your sky remote for a hanspree tv they work with almost every tv
Posted on Jul 18, 2010
I have a Hanspree TV and just got a Synergy V RT-U64CD remote, but the code printed for Hanspree, 768, does not work. Any Ideas?
Check other codes to Hanspree brand. If you wish to get more codes, check these links. Do not stick on brand name to remote control. Check for the code to Hanspree with any other remote control. The site mentioned above has three digits, four digits and five digit codes to different brand of popular remote controls. Check them with patience.
Feb 25, 2013 | Televison & Video
Hanspree TV chgs channel w/ cable remote but cant turn on/off
Thanks but I no longer require assistance. I tried to remove my post but it does not seem possible. I no longer need assistance because I sent the TV back. There is no solution as there is no universal remote code --- ridiculous for a brand new TV set that most people are probably going to want to use with cable!
Jan 13, 2009 | Hannspree (K206-10U1-005) Television
Hanspree codes
The information that I have found by searching is saying that your remote is not a "learning" remote and you need to get a rev 8 remote which is a "learning" remote.
Jan 05, 2009 | Televison & Video
How do i key in code for digibox
TO PROGRAM THE remote USING THE 3 DIGIT CODE:
1. Turn on the TV receiver
2. Press TV on the Sky Remote Control
3. Hold down SELECT and the RED buttons together for approximately two seconds, until the RED LED on the Sky remote blinks twice.
4. Enter three digit code from list for the receiver (early versions now flash twice).
5. Press select to enter code structure (the LED will flash twice if a valid code has been entered).
6. Now press the STDBY button and test other functions.
Repeat if necessary until a code is found that works most common functions.
TO PROGRAM THE remote USING THE 4 DIGIT CODE:
1. Turn your TV on.
2. Press tv on your Sky remote control.
3. Hold down select and the red button together for about two seconds, until the red light on the Sky remote control blinks twice.
4. Press tv on your Sky remote control again.
5. Key in the four digit code for your brand of TV. The light on the Sky remote control blinks twice. If the light blinks once only, recheck the code for your brand of TV and start again at Step 1.
6. Press the standby button on your Sky remote control. If your TV switches off, press select. The light on the Sky remote control blinks twice (code stored). If your TV does not switch off, press tv, then press the standby button. Repeat this (press tv, then standby) until your TV turns off, then press select (stores code).
If at this point the LED on the Sky remote control blinks three times then all possible codes for that make of receiver have been checked. Repeat from step one, ensuring that you enter the correct manufacturer code.
At the end of the sequence, if you see the TV Guide screen, the remote control setup process is complete. If you did not see the TV Guide screen, you must now complete the following steps.
8. Press tv on your Sky remote control.
9. Hold down select and the green button together for about two seconds, until the red light on the Sky remote control blinks twice.
10. Key in the number of the channel on your TV that you use for watching satellite TV.
11. Press select on your Sky remote control. The red light blinks twice. The remote control setup process is complete.
If after trying this, you still have problems, call your broadcaster's help desk. For your broadcaster's help desk number, select the Telephone Numbers option from the Services screen.
Dec 19, 2008 | Computers & Internet
TV REMOTE CONTROL NOT WORKING
1. Turn your TV on.
Oct 17, 2008 | Philips HDD065 MP3 Player
SKY REMOTE CONTROL CODE FOR SHARP LC-37X20E TELIVISION
You need code 1221 for this tv. I have the same tv, and using a rev.6 Sky+ remote, everything seems to work fine with that code.
As Sky seem completely unaware of this television, and possibly countless others, people should use the following site for a more complete remote control list than Sky themselves have:
http://sky.uebv.com/
Jul 18, 2008 | Sharp Televison & Video
32PFL5232D/37
The code is 0081 and this is how you do it.
'4 digit' or 'Brand Set' method
1. Turn on your TV.
2. Press TV on your Sky remote control.
4. Press TV on your Sky remote control again.
5. Key in the Brand Set code for your brand of TV. The light on the Sky remote control blinks twice.
If the light blinks once only, re check the code for your TV and start again at step 1.
6. Press the on/off button (power-top right button on your Sky remote control).
If your TV switched off, press select . The light on the Sky remote control blinks twice.
If your TV did not switch off, press TV , then press the on/off button. Repeat this (press TV , then on/off) until your TV turns off, then press select.
If the light on your Sky remote control blinks three times, your Sky digibox has checked all the possible settings for the code you used. Check that you have the right 4 digit code and start again at step 1.
7. Press TV guide .
If you see the TV Guide screen, the remote control setup process is complete.
If you did not see the TV Guide, you must now set the TV Guide function as follows:
8. Press TV on your Sky remote control.
9. Hold down select and the green button together for about two seconds, until the red light on the Sky remote control blinks twice. The remote control setup process is complete.
Mar 11, 2008 | Philips 32PF5320 32 in. HD-Ready LCD...
Sky code for remote
The code for you sky remote is 0125.
4 digit' method
1. Turn on your TV.
5. Key in the Brand Set code for your brand of TV then press select. The light on the Sky remote control blinks twice.
If your TV did not switch off, press tv , then press the on/off button. Repeat this (press tv , then on/off) until your TV turns off, then press select.
7. Press tv guide .
If you did not see the TV Guide,you must now set the TV Guide function as follows:
10. Key in the number of the channel on your TV that you use for watching satellite TV (For scart switching, this may be one of the other buttons on your remote e.g. help, i or a colour button).
Feb 13, 2008 | Televison & Video
Televison & Video Logo
145 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
