Question about KitchenAid KHGV01RSS Dryer
When I dry 2 loads back-to-back I blow a circuit breaker. Why might this be?
    Problem Solver:
  • 5 Answers
It is because your you have 2 loads back-to-back a dryer cant hold that
Posted on Jul 23, 2010
Dryer not heating
Hi
If the dryer is not drying the clothes then you would need to check for the following things-
Electric Dryer---
1. Inspect the fuses and circuit breakers they may have burned out or tripped. Usually, dryer will still tumble but not create heat if a fuse or a circuit breaker is not working.
2. Check for the amp reading at 240 V, it should have reading of 24, 21 and 3 amp (approx.) for 2 lines and neutral respectively.
3. Heating element may have turned or the connection to the element might be loose. Sometimes a shorted circuit element will keep on blowing the fuse or circuit breaker.
4. Motor wiring shorting to ground.
Hope this helps... Please post back if you need more information.
Daniel
Dec 11, 2010 | KitchenAid KEHS01P Electric Dryer
Kenmore Elite 45986 Front Load dryer wont get hot ?
Hi
Hope this helps...
Daniel
Nov 16, 2010 | Kenmore Elite 45986 Front Load Washer
Are there fuses in the dryer? Not getting hot. Could it be the heating element?
Hi
Electric Dryer---
Hope this helps...
Daniel
Sep 15, 2010 | Whirlpool WED5100SQ Front-Load Electric...
My dryer is making too much noise and it's not even drying up clothes.
Hi
If the dryer is not drying the clothes then you would need to check for the following things—
Electric Dryer---
Hope this helps...
Daniel
Sep 12, 2010 | Frigidaire FER311FS Electric Dryer
Not heating
Electric Dryer---
Post back if more assistance is required. Hope this helps...
Daniel
Sep 03, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Not heating up
Electric Dryer---
Daniel
Sep 03, 2010 | Whirlpool LER4634J Electric Dryer
Dried a load fine, next load tumbles wont dry. still cant get heat
Make sure front of dryer is not blocked, air flow is needed to dry.Check that the lint filter and exhaust duct is clean.
Check the blown fuses and home’s circuit breaker tripped. Dryer use 2 household Fuses or a circuit breakers, If one is blown, the dryer may still operate but not heat. Alternatively, the dryer may heat, but it may not heat up as hot as it should. Replace the Fuses or reset the circuit breaker.
Another common cause of a dryer failing to heat is a faulty Heating Element. You will need to replace it.
Good Luck and have a nice day.
Rating the solution is highly appreciated.
Jul 02, 2010 | Kenmore 63942 Dryer
My maytag front load dryer turns on and runs,it does not blow any hot air
Check the blown fuses and home’s circuit breaker tripped. Dryer use 2 household Fuses or a circuit breakers, Replace the Fuses or reset the circuit breaker.
Jul 01, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Ground Fault circuit Breaker trips each time a load is applied
The most likely causes in their order of probability are: 1) water somewhere in the circuit causing the hot wire to ground; 2) a legitimate trip caused by a defect in a device plugged into the circuit; and 3) a defective GFCI breaker. In the first case, wait until it has been dry for about a week and see if it trips. In the second case, make sure there is nothing plugged into the circuit and try resetting. In the third case go ahead and put the regular breaker in, then put a GFCI outlet into the first box downstream from the breaker. If installed according to the directions, that outlet should protect all of the outlets downstream.
Feb 26, 2009 | Cutler Hammer 1 Pole 15 Amp Ground Fault
KitchenAid KHGV01RSS Dryer Logo
Top KitchenAid Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Oloyede Monsuru
Are you a KitchenAid Dryer Expert? Answer questions, earn points and help others
