Question about Kenmore 96213 Electric Kitchen Range
My kenmore electric range 9621 shut down
Hi, need help yesterday while i was cooking, my KENMORE ELECTRIC RANGE COMPLETELY SHUT DOWN..My husband tried the circuit breaker however, my unit never came back up...Could it be the stove itself that broke down ? or will have to hire a electrician ?
I only had my stove for only two years...
  • 4 more comments
  • myrcrr68 Apr 21, 2008
    help
  • deneara Jul 31, 2008
    I was using my kenmore electric range when the largest burner sparked when I put my boiler on it and the entire stove shut down including the oven. I unplugged the range and plugged it back in but nothing happened. I looked on the back for a reset button and saw none.
  • Anonymous Mar 18, 2014
    circuit board on back of range is not have screws but a type of clip holding it on how to remove the clips
    electronic circuit board not held by screws but a type of metal clip
    We cnnot remove the metal type of clip to replacethe ectronic circuit board. thee are no screws just clips
  • Anonymous Mar 22, 2014
    Hi - the Kenmore range digital control panel is poorly designed & keeps breaking.
My sisters range went off reset breaker now the electronic system is going crazy how do I get it to stop beaping
Posted on Apr 20, 2012
  • 975 Answers
Check inside the stove for some kind of fuse , also check with a multimeter set to OHMS the circuit breaker of the stove to see if theres continuity . hope it helps
Posted on Apr 21, 2008
My induction cook top was on high to boil (P6) when it let out an odd pop sound, the element shut down then an error code flashed across the dash: E035 - constantly beeping. I have unplugged the oven
Is there a chance that you transposed the first two digits?
KENMORE ELITE Electric Range Parts Model 79095073310
Manuals , diagrams and help.
Note you do not have to download manuals to read them. Click on the name to the left.
Oct 30, 2014 | Kenmore Kitchen Ranges
Kenmore drop-in electric range plug melted
Hello- Yes it can be fixed- first, make sure outlet is not damaged. If it is, it will need to be replaced. Next, plug is wired into a terminal block on back of unit. With care, this cord is easy to replace. And safer than it was before. A loose plug, or wire caused the fireworks. Let me know if this info helps- have more if needed. -Thanks- ED
Mar 03, 2010 | Kenmore 45062 / 45069 Electric Kitchen...
Replacing both receptacle and cooking element but it is still not
you just may have shorted your king sealy or robert shaw switches for those burners
check the selection switches behind the control panel
Dec 15, 2008 | Kenmore 95589 Electric Kitchen Range
Dual cooking zone burner not working
Okay...what you have is a dual element with the 6 inch coil burned out. Yes, this is repairable, but unfortunately, since this is a dual element, it is sold as one assembly. The part number for a replacement is WB30T10044, and you can find it at repairclinic.com for about $90 (repairclinic item number 824238). I know it isn't cheap, but it beats having to pay for a service call, or buying a new appliance.
If you wish to repair this yourself, you can do so by following these steps:
1. UNPLUG the range before servicing. There are dangerous voltages still present even with burners turned off.
2. There are a few screws located under the front edge of the cook top. You will need to open the oven door to see them. Remove these screws and the top should lift up. If the range is not equipped with any kind of hinge supports, the top will have to be propped up.
3.On some ranges, there is a disconnect plug for the surface element wiring harness. If you have this feature, unplug the wire harness from the connector and follow these steps:
a. Unplug the cook top and leave the elements in place.
b. Place the whole cook top assembly face-down on a soft surface (like some old towels, or a blanket).
c. Remove the affected surface element. Take note of the numbered positions where the mounting screws are located and locations of the wires. You may want to write down the numbered positions and the wire color codes. HINT: A good digital camera can save you time if you have one. You will need to install the new element in the same manner.
d. Install new element (upside down). Handle the surface elements with care. They are very fragile. Care also must be taken not to handle the element coils or ceramic material. Try to handle from the underside of the element only. Oil from your hands can cause damage to the element and/or premature failure.
e. Re-install the cook top back on the range and you are DONE.
NOTE: If your range does NOT have a disconnect plug on the wiring harness you will need to perform the repairs with the cooktop propped up, and install the surface element assembly from underneath. A helpful hint: Use some duct tape to hold the element secure until you have it screwed back into place. Don't forget to remove the duct tape when completed. Once completed, lower the cook top and secure with screws.
I hope you find this information helpful. Let me know if you have require additional assistance.
Sep 09, 2008 | Kenmore 95589 Electric Kitchen Range
Jenn-air shut off while cooking giving f9 code
code F9 keeps flashing when I attempt to turn on my oven. What does this mean?
Sep 03, 2008 | Jenn-Air JES9800A Electric Kitchen Range
Rang
check the fuses that is located in the back of the stove where the clock
Apr 21, 2008 | Kenmore 96213 Electric Kitchen Range
Kenmore electric range 911.9369181
F8 Failure of Electronic Range Control (ERC) Replace Electronic Range Control/Clock (ERC)
Dec 01, 2007 | Kenmore 91112 / 91114 / 91117 Electric...
Oven door won't open
Best bet on this one is to replace the lock assembly. Although you could make a minor adjustment that may help. what you would do is with the door open put latch in lock position and then slightly bend latch to the left, making sure not to twist it. This works about 80% of the time.
Aug 11, 2007 | Dacor Epicure ERD36 Dual Fuel (Electric...
Kenmore 96213 Electric Kitchen Range Logo
688 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
