I have a denon ucd-250 cd player. LCD is flashing on an off and the unti isn't otherwise working. My guess is probably the PSU board has failed. Anyone know of any common component failures on this model
  • Ian-the-tech May 12, 2008
    post script, 10V failure was due to motor fialure in the end. replaced spindle motor and driver, now works perfectly
I dont know where all the wires go
Posted on May 12, 2008
Checked all IC protectors ICP-N15 on the power board and found that the one on the +10V rail (IC654) had popped to 10k ohm resistance. Replace it and all is ok
Posted on Apr 22, 2008
I have a Denon UCD-F07 cd player and it no longer plays cd's . I believe I need a new optical unit for CD-750M drive . the current number on the unit is KSM-2101A. The serial number on the drawer is...
http://shop.euras.com/geraetesuche_new.php?modselect=699489&artgroup=4400000000&&vgl=1&g7=3130732N
Maybe your problem is solved in the meantime, but on this site you can get the optical part for the UCD-F07
Dec 31, 2010 | Audio Players & Recorders
Hi, The power light flashes on and off on my Denon DND 9000 cd players when switched on. Nothing else lights up or works.
The problem is the power circuit board part number GU-3413. It costs about $200 to replace and can be purchased from any of Denon's authorized parts distributors.
Mar 01, 2010 | Denon Dnd9000 Dual CD Player CD Player
Monitor on a emachine 250 computer comes on picture is very light faded in the background but no light
This is a typical symptom of a failing LCD screen inverter board or LCD screen backlight lamp. The backlight lamp failure symptoms are very similar to the inverter board failure symptoms. If you have to guess which one is causing the problem, try replacing the inverter board first. LCD screen inverter boards fail more often than the LCD screen backlight lamps.
Feb 16, 2010 | Acer Computers & Internet
Hi, my cd drawer on my ucd 100 dosen't open and it
hi,
same problem with my dads UCD 100. the problem is the motor is going and the latch spring in now too tight to release. to resolve replce the motor, but temporary solution is to stretch the spring a bit and that should allow the release. you might need to pull it out a bit once it comes out to lock it off otherwise it might slide back in.
hope this helps.
Nov 05, 2009 | Audio Players & Recorders
UCD 110 - Doesn't recognise every CD and will only play some CDs. I've tried cleaning the player with a CD Cleaning disc but to no effect.
I've had the same problem with a denon ucd 70,had the laser replaced and still the problem remained.Finally it appeared that a little wheel which moves the laser over the disk was broken and therefore the entire system finally couldn't read any cd anymore It started with some cd's however.
Still looking for a replacement wheel and fear that I have to buy a full new laser unit
Sep 24, 2009 | Denon Audio Players & Recorders
Noise coming out of speakers connected to Denon AVR 1908
Check for nearby wireless devices and move them away. -If the audio output from the source device (i.e. DVD, CD player) is digital (i.e. PCM, DTS or Dolby Digital) you're on your own. I'd be willing to bet the output is analog (red and white RCA), because the "beeps" and "exploding sounds" you describe seem like it could be caused by interference. Try replacing the cables. Otherwise the issue is probably with your receiver.
Aug 11, 2009 | Denon AVR-1908
Radio preset Denon UDRA-f10 doesn't save
1) tune in to a radiostation
2) press the Memory button
3) select a preset number for 5 Second
4 Skip "press Memory again"
Feb 04, 2009 | Denon PMA-100M Amplifier
I have a Denon 1650 CD player. Denon doesn't carry the parts to repair it. (Scratchy sound on all CD's). Are there aftermarket parts anywhere? Thanks Ray Durr
Based upon your description, the problem is most likely either the D/A converter IC or a bad audio output transistor/opamp. Without seeing the unit, remote diagnosis is just a guess. The IC should be available generically. Can you post a photo of the board? If I can see what is in there, I can point you to the suspect parts. I don't have a service manual for this one.
Dan
Oct 01, 2008 | Denon Audio Players & Recorders
Cd player not playing some cds: denon cd player ucd-77
try cleaning your not working cd with soap and water, and dry it with paper towel. tnx
Jan 30, 2008 | Audio Players & Recorders
434 people viewed this question
 Grubhead
Grubhead
