My 32lg3000 tv as a thick band that moves up my tv in a darker shade. serail: 901manjif607 product# 2A.AEKLQLWP
  • richard_k371 Jul 18, 2010
    i've got a 6inch band that moves up on my 32 lg3000 lcd tv in a darker shade of colour
  • richard_k371 Jul 20, 2010
    than
  • 4,806 Answers
This sounds like the backlight is bleeding or having the clouding effect.
This is a common problem with LCD tv's and there is not much you can do about this apart from go into the tv picture setup menu and drop the contrast and brightness. This in most cases kind of hides the bleed but it will however be still visible when you watch certain programs.
Some tv's have a special menu that allows you set backlight settings. If your LG tv has one of these settings go through the settings until you find one that your happy with.
Replacing the backlight itself can cost as much as the tv was brand new.
I have an LCD tv which is having the same problem, i adjusted the settings and the cloud is hardly noticeable.
If of course the tv is still under LG's warranty you could send it back to them for repair.
Regards.
Posted on Jul 18, 2010
  • 19,396 Answers
Hi.
First try connecting the TV to a different main socket, a bad ground on line can cause similar problems.
Also test the TV on different inputs, and using different cables and devices (eg. DVD and external receiver box or console).
The problem is likely main controller board. PSU failure may cause the same problem.
Repair must be done by a technician, first testing PSU voltages, then testing and eventually replacing main controller board.
Here parts, the main controller is not in stock. It must be ordered from LG (if available)
Here service manual with schematics and troubleshooting diagram. Click Get Manual on the left.
  • Ginko
    Ginko Jul 18, 2010
    Hi.
    I wanted to add that the technician can also try the adjustment procedure described at page 10 and following of the service manual (Here service manual). I do not think that the adjustment will fix the problem. Problem is more likely fixed reading voltages from PSU and following the troubleshooting chart at page 16 of service manual to find fault.
    Regards.
    Ginko.
Samsung UN40D6000SFXZA TV has blue screen with vertical lines of various shades of blue.
You may try a new T-CON, but most of the problem could be a display panel.
Nov 01, 2017 | Samsung Televison & Video
My tv has a darker shaded area in the middle of the screen ,,is this an easy fix?
No it isn't an easy or cheap repair. It is usually caused by the screen having some type of damage to it. Usually cheaper to buy a new TV.
Dec 14, 2015 | Televison & Video
I have a client we have bleached her hair twice but still have a gold band in the middle I do not want to hydrolize her hair any more what do I do to get it all to the the same color without damaging it...
You can either color the whole head a darker blonde or try and tone the gold band with a violet toner. Depending on how gold the band is and the color of the remaining hair, I would recommend using Redken Shades EQ in 9V. You will have to watch it closely in the shampoo bowl to make sure to get it just right and not over tone the rest of the hair.
Nov 10, 2012 | Matrix V Light Hair Bleach Lightener 32oz
Hi I have 32LG3000 there was some static discharged from me to HDMI cable to the tv and now the picture is shutting down after 5 sec so basically I get picture and sound the top half of the picture is...
The spark has damaged the image processor - the entire mainboard (the board that carries the processor and the AV connectors, including the HDMI) will have to be replaced. The board will cost you around £50 - you can buy it from here
http://www.sparedparts.com/products/details/32lg3000_main_board_lg_ebu43398305/
or you can order it at a dealer
Dec 19, 2010 | LG Televison & Video
RCA r56wh78 scrolling vertical bands
it is going to need to be tested to find the component that is causing the problem
Oct 21, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Dark band on left side, Samsung HL-R5668W
the reflecting mirror is likely loose and falling down inside the light reflecting tube. you should have seen the band getting darker and larger,
the small mirror is in front of the lamp and bends the light,
remove the lamp and look down the tube (light path)
May 06, 2008 | Televison & Video
Convergence problem
no u cannot do anything on ur own u need to call an expert,
Apr 04, 2008 | Samsung HL-R5087W 50" HDTV-Ready...
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
