Question about Ovens
I have a Siemens microwave/oven HB86P.70B installed approx two years ago. The Microwave has stopped working eg. Will start for approx 5 seconds and then stop. I do not know if the appliance is still under warranty - Name: A. Pasi address: 21 Westbourne Gardens Glasgow G12 9PE Have you any suggestions for the problem? could you Check the warranty for me please? thank you s. Pasi (mrs.)
  • 213 Answers
SOURCE: MIcrowave stopped working
there is a 15 or 20 amp fuse behind the control panel. turn power off at breaker, remove control pand the fuse will either be round and the size of a quarter, screwed in or will be about an inch long and cliped into place
Posted on Nov 19, 2007
  • 1314 Answers
SOURCE: Kitchenaid builtin microwave oven # Kemc307KSS
ok the meat probe error is the meat probe is wired backwards yor microwave is a blown fuse in line with the primary interlock switch send me an email at b4829@yahoo.com can help the primary interlock switch is a fancy way of saying one of the three micro switches in the door that the hooks on the door trip when its closed
Posted on Jan 25, 2008
SOURCE: siemens microwave oven HB86k.70b
I have the same problem, have you found out the cause?
Regards
Posted on Sep 04, 2008
  • 338 Answers
SOURCE: Jenn-Air JMC7000 Microwave Stopped working
take the trim off of the microwave and on the top of the oven on the right side all the way in the back there should be a reset button just like a surge protector.
Posted on Dec 01, 2008
IbuyUSA
  • 9 Answers
SOURCE: Miele Microwave Oven M636 EG
Use Miele UK
http://www.miele.co.uk
click Customer Support
then
click Operating Instructions
select File;
  • M616, M626, M636
free download PDF format
Posted on Oct 19, 2009
Magnetron fan runs all the time
The timer that runs the mag is stuck. Unplug fan for 30 seconds and check it out. If not fixed, then look at replacing if microwave is older 7-8 years old.
Feb 24, 2013 | GE JKP90SPSS 27" Microwave Combination...
Siemens HB86E560B/01 microwave oven.oven working ok.when selecting wattage for microwave it cutts out after approx.30 secs. higher the wattage selection the sooner it cutts off. is there an overload heat...
Please have your power rating checked on the outlet and also if possible measure the mains voltage on the outlet . If low this can trip the microwave as it runs short of current/voltage.
Also make sure the plug is tight on the socket. Choose a lower wattage and see if the microwave works a longer time. If so the microwave must be checked within for a faulty capacitor, magnetron , wave guide or transformer.
Clean the oven , check the connections within and try once again before we can infer.
Aug 19, 2011 | Ovens
Our microwave is approx. 9 years old and has started to shut off after 6 seconds. It is a Panasonci Inverter (Lost book) Type S333 (F04114182CP) Is this repairable.
1) power to display- main fuse good
2) no power to magnetron- check all realated thermal switches hidden behind control panel. Remove top grill to find two hidden screws.
May 30, 2011 | Ovens
The microwave does not make anything warm, but it is working. Secondly, the timer starts working for seconds only then go to zero. Herman
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Dec 13, 2010 | Ovens
This KitchenAid combination wall oven and microwave unit was purchased in 2002. Except for having to replace a fuse in 2004, it worked fine until the microwave started acting up recently. In September...
Good Question. I work on all brands of appliances, and I swear by KitchenAid-Whirlpool appliances. That being said, I do not recommend oven-microwave combinations, because the ovens will last 30 to 40 years, but the microwaves start having major repairs from 6-10 years on. I would bite the bullet and put in a separate Panasonic microwave (with an inverter) and a seperate KitchenAid Oven. You also need to install a 2000 Joule or higher surge protector, for your microwave oven. Panasonic microwave ovens are better than the KitcheAid ovens at this time.
I would suspect that the touch panel-control board failure may have been caused by the repairman, just because the timing is a little too close to the mag repair. No way to tell you for sure, and I myself have had control board failures the same day that we changed a light bulb, so anything is possible. Usually a factory defect is going to show up before 8 years. In the last 4 years in the greater Seattle area, 70 - 80% of our business is from power surges hitting the electonics in the different appliances, so this could also have been what has caused your repairs. On a 240 volt Oven, the only way to protect it from power surges is to have a whole-house surge protector installed on your house electrical panel. You still need to have individual surge protectors, above 2000 joules, for your appliances that are 120 volts. Good Luck, Appliance Specialists
Dec 09, 2010 | KitchenAid Architect® KEMS378S Electric...
Dec 01, 2008 | Ovens
Siemens microwave oven HB86k.70b
Regards
May 04, 2008 | Ovens
Use Miele UK
then
select File;
  • M616, M626, M636
May 02, 2008 | Miele DG 4080 Stainless Steel Electric...
Ovens Logo
615 people viewed this question
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
