Question about Weber Genesis Gold B Premium Grill
Igniting is not working I have to press the igniter 10times or more before it ignites ther is a spark every time a press it but it dont ignites
  • tegner667 Jul 18, 2010
    I dont think this is a solution becuse it has worked before for many years
  • 360 Answers
Hi, i believe this grill has a push button electronic ignition. The first thing to check is to remove the top and replace the battery, be sure the battery is put in correctly. If this does not fix the problem, check the wiring from the igniter to each electrode for breaks, shorts, or disconnected. If these things do not work, start by replacing the igniter itself.
Take care
Posted on Jul 18, 2010
  • tegner667 Jul 19, 2010
    This one have piezo electric lighter and there is a spark everytime I press the button and its about 10mm long
    Still it fails to ignite the gas!
  • Quadri Olatunbosun
    Quadri Olatunbosun Jul 19, 2010
    You need to replace the igniter...
  • 6,826 Answers
Pressing the button for the ignitor may create a spark, however, the spark, if not placed exactly in the gas flow will not ignite.
The solution is to use a long lighter, the kind you can get for $1 at a dollar store, or $2 at walmart.
This bypasses the mechanism that doesn't work in most grills.
Good luck to you.
Burner igniters keep sparking long after the burner is lighted
The igniter is activated by a pressure switch, when you press a button or push in the knob, sounds like it has a bit of gunk in ther e stopping it from coming out again.
Mar 05, 2014 | Thermador SGS36GS Gas Cooktop
Finding ignition relay
Ignition relay .... There are 2 types of ignition. (1) the ignition key (2) the ignition system that delievers spark to the spark plugs. Why do you need ther relay ?? Does the car not crank over ?? Or does the car crank over and don't start ?? I can help .... but I need more info. please.
Mar 03, 2013 | 2000 Ford Taurus
HOW TO SET AN ROTER FOR AN 92 CADILIAC DEVILLE
standing passenger side vechicle with crankshaft pulley facing your.number one sparkplug location should be at twelve Oclock position.you need to know cylinders locations front cylinders left to right is 1 3 5 7 and back cylinders left to right is 2 4 6 8 and firing order is 1 8 4 3 6 5 7 2 your ignition timing need to be 10 degrees BTDC AT 800 RPM. YOU SET TIMING YOU NEED TO DISABLE SPARK ADVANCE BY CONNECTING JUMP WIRE OR PAPER CLIP STRECTCH AND BEND YOU NEED TO CONNECT JUMPER WIRE TO A AND B DLC TERMINALS. if ignition timing way off you wont get no spark.but check ignition fuse and make sure distributor cap and rotor good shape also spark plugs and wires.if all is good your ignition module or ignition coil bad.the 4.9 can be time if you have 4.6 engine cant adjust ignition timing PCM control timing.code scan vechicle first before buying new parts.look for ignition module or pcm fault codes.look for faulty crankshaft sensor or camshaft sensor.many things will cause no spark conditions.
Dec 22, 2012 | Cars & Trucks
My 1990 hond accord will turn over but wont start can you please help
MAKE SURE SPARK PLUGS AND WIRES IN GOOD CONDITION, REPLACE DISTRIBUTOR CAP AND ROTOR,CHECK FOR SPARK AT SPARK PLUGS,IF YOU DONT SEE SPARK CHECK TO SEE IF POWER GOING TO COIL IF NOT CHECK IGNITION FUSE.IF FUSE OKAY AND POWER GOING TO IGNITION COIL,COIL FAULTY OR IGNITER UNIT FAULTY. CHECK FOR FUEL PRESSURE MAKE SURE FUEL FILTER BEEN CHANGED.FUEL PRESSURE SHOULD BE 40 PSI. IF YOU GETTING SPARK AND FUEL. YOUR IGNITION TIMING OFF OR VALVE TIMING OFF DUE TO A WORN TIMING BELT.
Nov 01, 2011 | 1990 Honda Accord
I have no spark any reason that comes to mind?
possible distributor. most of the time spark is produced by distributor
Mar 25, 2011 | 1992 Honda Accord
Car turns over will not start no spark at the spark plugs
CHECK IGNITION MODULE FUSE.AND CHECK FOR POWER GOING TO MODULE AND COILS.IF NO POWER PROBLEM IN IGNITION MODULE FUSE OR LOOSE BROKEN WIRE.IF POWER GOING TO IGNITION MODULE.THE IGNITION MODULE FAULTY.TO SAVE MONEY AND TIME.HAVE CAR SCANNED TO MAKE SURE YOU DONT HAVE ECM OR PCM PROBLEMS.YOU DONT WANT TO BUY A IGNITION MODULE IF YOU DONT NEED IT BECAUSE THEY COST FROM $100.00 TO $200.00.THATS WHY SCAN IT FIRST.
Apr 04, 2010 | 1991 Oldsmobile Cutlass Supreme
My car wont start but will crank and thers no spark
Look to the source of the ignition spark that supplies all 4 spark plugs. The ignition coil supplies spark to the rotor and the rotor sends spark to each individual spark plug wire via the cap and rotor. If you are getting no spark check the cap and rotor for wear and then go to the coil and see if it is malfunctioning. If all of that fails then the sensor suppling the signal to the ignition coil is probably to blame. Usually the Camshaft or Crankshaft sensor that feed signal to the ECM or the ignition coil. Be methodical, follow your way down the line and check everything and you'll find the problem for sure!
Oct 16, 2009 | 1993 Toyota Corolla
I need to know the timing sequence for a 1998 Mercury Mystique 2 liter
ignition timing or valve timing?
ignition timing not setable.
info:
The ignition system consists of an ignition coil, spark plug wires and spark plugs.
The crankshaft position sensor signal is the basis for ignition timing calculations. The alternating voltage signal from the crankshaft position sensor is digitized by the powertrain control module. This digitized signal is then used to position the closing time of the primary circuit of the ignition coil.
Ignition angle is determined by the powertrain control module in response to engine operating conditions. Once ignition angle has been determined, the powertrain control module interrupts the current to the primary circuit of the ignition coil thus triggering the ignition spark which is supplied to the cylinders through the spark plug wires and spark plugs.
The ignition coils are triggered by the powertrain control module in pairs (cylinders 1 and 4 and cylinders 3 and 2) sending one ignition spark to the firing cylinder and one ignition spark to the corresponding cylinder on the exhaust stroke. This make sures that any unburnt fuel residues remaining in the cylinder on the exhaust stroke are re - ignited to provide cleaner exhaust emissions.
May 06, 2009 | Mercury Mystique Cars & Trucks
Heater wont ignite. Has fuel coming out front of
if the spark plug is sparking it is hot enough to lite the fuel.is ther dirt in fuel tank???is there water in the fuel???? what is the air pressure set at????is the nozzle clean and spraying correctly?????any of these will cause the heater not to fire.not the spark plug.
Feb 20, 2009 | Dayton E51 Oil Filled Utility Heater
Set the keyless entry
TS06 DEC 05 Keyless Entry - Transmitter(s) Inoperative
There was a recall in DEC. 05 for this particular vehicles remote transmitter system....though im not sure if they would do service free of charge now...
Moving along...if you have no working transmitter, you have to do the following to get it working again:
* Ensure vehicle audio PIN number is known or audio PIN security system is deactivated prior to battery disconnection.
* Ensure a door is open
* Disconnect the negative battery cable, wait minimum 5 seconds then reconnect
* Within 20 seconds of reconnecting the battery cable, insert the keyin ignition then cycle the ignition key from the "ACC" position to the"ON" position 20 times, leaving the key in the "OFF" position after thetwentieth turn.
* the vehicle's indicators will flash 20 times to indicate successfulentry. NOTE: Should the indicators fail to flash, wait 5 seconds thenquickly turn the ignition switch from the "ACC" to "ON" position 10times, leave the ignition "OFF" after the 10th turn and wait 15 secondsthen recycle the ignition switch 20 times.
* the vehicle's indicators will flash 20 times to indicate successful entry.
* within 10 seconds of the indicators having ceased flashing, press the button once on each transmitter.
* turn the ignition key to the "ON" position to lock in and exit from the programming mode.
And if you have even 1 transmitter that does work, its not nearly as difficult:
* ensure a door is open
* remove key from ignition
* lock the doors using the transmitter
* unlock the doors using the transmitter
Within 20 seconds of unlocking, insert key in ignition, turn theignition key from the "ACC" position to the "ON" position 20 times,leaving the key in the "OFF" position after the twentieth turn.
The vehicle's indicators will flash 20 times to indicate successful entry.
Within 10 seconds of the indicators having ceased flashing, press thebutton once on each transmitter. Once finished, turn the ignition keyto the "ON" position to lock in and exit from the programming mode.
Hope this helped,
Jem
Nov 12, 2008 | 2004 Suzuki Verona
Weber Genesis Gold B Premium Grill Logo
202 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Marvin
Marvin
Are you a Weber Grilling Expert? Answer questions, earn points and help others
