Question about GE Profile 30" Free-Standing 5 Burner Self Clean Gas Range with Warming Drawer, JGB908 Kitchen Range
Oven fire Bottom baking element caught fire last night. Oven less than 2 years old. Don't know if element was cracked or it burned through the element; it is now in 2 pieces. I called the appliance store they told me that baking elements are designed to burn through....WHAT?!!!!!
    Genius:
  • 1,073 Answers
Wrong call ge@ 100-851-6200 and they will help you have the model number handy before you call
Posted on Apr 21, 2008
Broiler will not come on when baking
Take a look at the element ( the "tube" inside the oven that glows red hot when the oven is turned on). If the element is burned out it will not be hot and glowing. You may have a loose connection to the element but most likely it is burned out and needs replacing.
Our stove is 27 years old and I have had to replace top or bottom elements every 6 years or so. I just bought a replacement element at Canadian Tire in Calgary for about $34. Just undo the 2 screws around the element and attach the new element to the old wires.
Good Luck -I hope this works for you
Jan 10, 2013 | Moffat Ovens
Oven not heating up light ok fan ok
hi Lorraine. Thanks for choosing fixya! Usually, when an oven won't bake, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
Nov 05, 2009 | Creda C361E Electric Kitchen Range
Yesterday I heard a loud pop from inside the stove. Frigidaire smooth top professional series just about 5 years old. Looked inside and my parchment paper had caught on fire which had never happned before...
Is this an oven or the cook top?
A blown oven element is possible. You may still be able to bake but the oven will seem to take forever to warm up. An easy check would be to crank the heat up full bore and put your hand near the top then the bottom. You should feel more intense heat the nearer you get to a working element.
May 08, 2009 | Kitchen Ranges
Baking Element Caught fire
Elements wear out from the inside. Sooner or later it happens to all of them.
Mar 31, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Fire Mondel # PLEB30T9FC
very possible hat the element is no good, does it look physically burned???? if so replacing the elemnt is the only option,2 screws and 2 wiredis all, simple to replace, unplug/disconnect power first,,, the wires are always live to the elemnt!!!!!!!
Dec 21, 2008 | Frigidaire GLEB30T8A Electric Double Oven
Err on display when I try to set the bake temperature
or try doing this
1. Turn the clock selector knob to OFF
2. “Tweak” the oven control by turning the clock selector knob slightly to the left (counter clockwise). This may stop the flashing message/beeping and clear the display window.
Nov 12, 2008 | GE Profile JTP18 Electric Single Oven
Oven was not working. Range and bottom warmer is working, but the oven isn't working.
if this helps please vote me a fix ya
Jul 15, 2008 | Frigidaire Kitchen Ranges
I have an old model electric Jenn-Air D-120. Last night my oven bottom burner cought on fire and burned up. Can this be fixed or is the stove shot.
Usually the bake elements are relatively cheap and easy to replace. Use your model # and click on one of the links to the right and search for your part to make sure that it is still available. It would be worth repair.
May 15, 2008 | Jenn-Air Kitchen Ranges
this a common complaint when the element burns out it is scary to see but all you need to do is replace element
Apr 21, 2008 | GE Profile 30" Free-Standing 5 Burner Self...
funny same thing just happened to me and it all seams to be the bottom element of the same ovens around the same year, I bought mine in 99 also, I keep my oven very clean becasue i know the dangers it may cause, I think this is a major problem and it needs to be addressed.
Aug 19, 2007 | Maytag MER6772 Gemini Electric Kitchen...
Kitchen Ranges Logo
258 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
