Question about AOC 19LVWK LCD Monitor
Input Not Support
What does it mean when a black box keeps on moving in my monitor saying "Input Not Support" in it?
ACO Moniton connect to tv tonor card and tv on but massage input not support
Sandip Jadhav
9371144236
Posted on Aug 12, 2010
  • 58 Answers
You either set monitor resolution or refresh frequency out of boundaries. This models works optimal on 1440x900 resolution and 75 Hz refresh frequency.
Posted on Jul 18, 2010
  • 62 Answers
This means, that your operating system is not set to the recommended resolution of your monitor. Your monitor has a "fixed" resolution where the image will look best. You can change the solution in Windows XP if you right-click on a free space of your desktop, then choose "Properties". In the new window, that comes up, select the rightmost tab. There you can use the slider to adjust your resolution. Just try some different resolutions until the message disappears. If you use Windows Vista oder Windows 7 you can access the resolution windows by right-cliking on your desktop and selecting "Screen resolution".
Need manual for Hannspree Monitor Xm-S
When you say the picture keeps dropping, is it going to the black or blue screen where it says it cannot detect an input/source?
If so that could be a faulty cable, if you have a spare cable to connect to whatever the input you're using is it would be worth trying that.
Aug 16, 2016 | Hannspree Computers & Internet
Computer screen keeps going black,,turn the monitor off and on,,screen come up for a bit,,the d sub appairs then gos black again
Hello there
You dont say which machine you have but a common problem is they are set for the WRONG input,
Have you checked using the 'onscreen' menu,of the monitor that you are looking at the right INPUT ???? D-sub is the 15 pin video cable input from your computer to the monitor. .It will go dark if you are not supplying a signal on that input.
Sep 24, 2014 | Computers & Internet
Why is my dell inspiron 531s stuck on black screen with input not supported message?
Start pc in safe mode and try to change resolution.
Then update the graphics driver.
May 06, 2014 | Dell Inspiron 531s Desktop Computer
The screen is black and a little box that says no signal is moving around on the screen
Check your inputs. The no signal box means exactly that - there's no incoming signal for the TV to decode. So you've either disconnected a cable somewhere or turned off your input device.
Try changing the inputs on the TV (this will be a button saying input or A/V)
Try changing the channels
Check that your cables are correctly connected and that whatever you are trying to use (dvd player, PS3, etc) is turned on.
Check that your TV is tuned to the corresponding input it is plugged in to (if you plugged your DVD player into HDMI input 8, tune your TV to input 8)
Hope this helps.
May 11, 2011 | Sanyo Televison & Video
Monitor issue
Just sounds like the monitor cable is loose or bad or the input mode on the monitor is set wrong - set it to auto or step through the modes.
Aug 10, 2009 | Envision H191W Monitor
We have a flashing rounded rectangular box moving around on the screen which says input not supported. What does this mean? How do we fix it? this is happening on our Acer Monitor for our computer.
Right after you start up the computer, start pressing f8. You will then get into a setup, choose VGA mode. If this does not work, try lowering the refresh rate and changing the screen resolution.
Aug 03, 2009 | Acer AL1916W 19" LCD Monitor
I have a problem with my hp 1702 please help!!!!
this means that your screen settings are not compatible with the game. like 16 bit color to 32 bit color. set the screen settings so that you can play. Display properties would let u adjust these colors.
Aug 11, 2008 | HP L1702 17" LCD Monitor
Can not diaplay when connected to external TV tuner Box(fontech)
'The Monitor goes blank when the box is powered' what does that mean exactly? what box? What was the monitor doing before the said box was pwered?
Jun 04, 2007 | BenQ FP91G+ (Black)
Input not supported when trying to play a game
the game will need to be set to the same screen resolution as your monitor or the best that suits, beccause of it being widescreen, so look in the graphic or video settings in the game, or change the resolution of your monitor to suit the games highest setting. This is done by right clicking on your desktop, down to properties and then the settings tab in the next window and then move the slider at the screen resolution box.
Apr 25, 2007 | Acer AL1916W 19" LCD Monitor
AOC 19LVWK LCD Monitor Logo
281 people viewed this question
Top AOC Computers & Internet Experts
Jerry Umali
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
