Question about Yahoo Messenger
I cannot connect to yahoo messenger for a long time. As i try to login using my userid and pasword, it shows an error that "there was a problem signing into yahoo messenger. Please try again a little bit later".But same problem occurs even when I tried to rebooted my PC and after tried to log in.Even twice I have formatted my system..but the problem remains same. YAhoo 8,7,6 all versions of messengers are having the same problem...but earlier I have successfully used all these yahoo messenger versions.Yahoo latest version 10 is also not working on my PC as during installation it is giving me error: incorrect command line parameter nad as a result the yahoo messenger is not opening after installation.Currently yahoo messenger 8 with voice is installed on my pc and I want to use this just like before.PLease help me asap...as for long time I cant login to my yahoo messenger.On the other hand using the same id and apssword I can connect through yahoo web messenger or meebo.Please give me a solution asap.
    Problem Solver:
  • 4 Answers
Maybe you could delete yahoo from your laptop and re-install it or if that doesnt work perhaps you could make a new user?
Posted on Jul 18, 2010
Problems with log in to Yahoo Messenger
Hello. You can probably fix this condition by following these steps:
  1. Click on the gear icon in the upper-right of the IE window
  2. Click on Internet Options
  3. Click on the Advanced tab
  4. In the Settings window, scroll all the way down to "Use TLS 1.0" and make sure that is checked.
  5. Click Apply, then OK.
That should fix it for you. This is due to a recent change in how Yahoo handles login requests.
I hope this is helpful.
Jan 25, 2015 | Yahoo Messenger
I cant open my ym account....
I suggest you to check whether your email address and password is correct or not, by logging in at the www.yahoomail.com website, If you are able to login then your account exists and the email address and password is correct.
If it shows wrong password, try forgot password.
If you are able to login to your account in website, only you cannot login in yahoo messenger, There might be some problem in yahoo messenger, I suggest you to download the recent version of yahoo messenger and try logging in, if problem persists check your internet connectivity, Sometimes we couldn't login if there is a problem in internet connection.
There may also be problem with windows firewall settings.
And also check whether the yahoo messenger is added as exception in the windows firewall or not, If not add the yahoo messenger to exception list.
May 24, 2010 | Yahoo Messenger
What is the difference between my email userid and yahoo im
If you have a yahoo userid and a password, it means that you own a yahoo account, as well as an instant messenger account. In other words, same yahoo userid and password can be used for email as well as instant messenger. If you use the same userid for email and instant messenger, then the password should also be the same, which belongs to the userid which you use. If you want to use different user id and password for email and instant messenger, you can create two userid's and use one for email and the other for the instant messenger.
Sep 09, 2009 | Yahoo Messenger
Messenger error 81003005
here are some causes: Firstly; this error occurs when your connection preferences are not properly set. I'm not talking about your Yahoo! ID and Password here, but you may need to adjust certain features depending on what network you're on. Let's says for example, if a firewall protects your network, it may block yahoo messenger when it tries to connect to the server. You need to change your connection settings, click the Messenger menu in yahoo messenger and select Connection Preferences. Select Firewall With No Proxies. Select your Internet Connection type from the pull-down menu at the bottom and enter your Home Country if the adoptions aren?t grayed out. Click OK and login again using the new settings. If this option doesn?t work, click Connection Preferences in Yahoo! Messenger again and select No Network Detection. Try to login again using the new settings. In some instances, you may need to provide yahoo messenger with the IP address of your firewall or proxy server (you can get this information from your network administrator or from your Internet service provider). Click Messenger and select Connection Preferences again. Select Use Proxies. Enable either the HTTP Proxy or the SOCKS Proxy as needed and provide the proper address. Click OK and login again using the new settings.Secondly; if you are using IM9 there are sign in problems. This is what yahoo has to say. Try an updated version of Yahoo! Messenger 9.0(9.0.0.2128). This latest build includes a fix for the sign-in issues that have been affecting some users. If you were seeing an error code?81003005? when trying to sign in, this latest version may fix that problem. Even if you were experiencing a different kind of sign-in issue, I recommend installing this latest version. Hope it was helpful!
Thanks.
Jun 16, 2009 | Yahoo Messenger
Login error 81003004 from Yahoo Messenger
Firstly; this error occurs when your connection preferences are not properly set. I'm not talking about your Yahoo! ID and Password here, but you may need to adjust certain features depending on what network you're on. Let's says for example, if a firewall protects your network, it may block yahoo messenger when it tries to connect to the server. You need to change your connection settings, click the Messenger menu in yahoo messenger and select Connection Preferences. Select Firewall With No Proxies. Select your Internet Connection type from the pull-down menu at the bottom and enter your Home Country if the adoptions aren’t grayed out. Click OK and login again using the new settings. If this option doesn’t work, click Connection Preferences in Yahoo! Messenger again and select No Network Detection. Try to login again using the new settings. In some instances, you may need to provide yahoo messenger with the IP address of your firewall or proxy server (you can get this information from your network administrator or from your Internet service provider). Click Messenger and select Connection Preferences again. Select Use Proxies. Enable either the HTTP Proxy or the SOCKS Proxy as needed and provide the proper address. Click OK and login again using the new settings.Secondly, if you are using IM9 there are sign in problems. This is what yahoo has to say. Try an updated version of Yahoo! Messenger 9.0(9.0.0.2128). This latest build includes a fix for the sign-in issues that have been affecting some users. If you were seeing an error code“81003005” when trying to sign in, this latest version may fix that problem. Even if you were experiencing a different kind of sign-in issue, I recommend installing this latest version.Hope it was helpful!
Jun 05, 2009 | Yahoo Messenger
Change your messenger connection settings. I had to check "Connect via a proxy server " in order to sing in.
Goto Connection  Prefrences and use a http proxy.
thank you
Jun 02, 2009 | Yahoo Messenger
Are you behind a firewall (like one in schools) or using proxy??
If so, see any options are available to change the connection settings in yahoo messenger before connecting.
How can I login without registration?
u need to register to use yahoo services bcoze they save u r userid & password in there databace or if u have user name & password of other user so u can use that for login without registration.
Sep 15, 2008 | Yahoo Messenger
Yahoo Messenger Logo
148 people viewed this question
Top Yahoo Computers & Internet Experts
micky dee
Mike
fixrfast
Level 1 Expert
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
