I have a Lexmark printer tht is over 5 yrs old. I saved it when I purchased another more up to date one. I would li8ke to use it now but keep getting a message saying I need a cisc. I do not have any disc. How can I set it up otherwise. Is there software in the computer I can connect to. Thank you.
  • 6,826 Answers
If you go to the Lexmark.com website and type in your printer's model #, you might be able to download all of the drivers found on the disc.
Posted on Jul 18, 2010
I NEED TO SET THE TIME AND DATE ON MY LEXMARK X5470 ALL IN ONE.
Set the printer to factory defaults. Caution you will lose all stored custom settings. You will then be prompted to set the language, country, date, time and time format, your fax number, and name on your printer..
You can reset your printer to the original settings by first turning off the power. Then p
ress the Start Color (green button) + X and keeping the buttons pressed down. Press the Power On button once to power the All-In-One on. Continue to hold the Start Color (green button) + X buttons for the next ten seconds.
When the prompt appears , release the buttons and follow the prompts on the display to choose your language, country or region code, date, time, and fax number.
Use the forward and backward arrows to select your language. Use the checkmark to save the setting.
Use the keypad to enter the date, time, fax number, owner's name, and press the checkmark after each selction to save.
For future reference support information for your printer may be found here.
Jan 21, 2012 | Lexmark X5470 All-In-One InkJet Printer
I've had my Lexmark x2580 installed on my new Acer Windows 7 machine for 6 months now. I kept getting a "please register" message but since it is about 2 yrs old & I'd already registered, I...
Make sure your print spooler service is running. This article in the Lexmark website about How to Restart or Reset the Print Spooler in Windows might help you enable the service again. If problem continues, please contact Lexmark technical support for additional assistance.
Feb 10, 2011 | Lexmark X2500 All-In-One Printer
How to replace the ink cartridge
1. Look at the indicator light on your Lexmark printer. You'll need to replace ink cartridges when the light flashes or turns red instead of the standard green.
2. Purchase Lexmark ink cartridges. You can buy the brand name or purchase a generic version that is compatible with your printer. You can shop for low cost ink cartridges from ABC Ink.
3. Remove the old cartridges from your printer. Grip the sides of the Lexmark ink cartridges and pull it out. Dispose of the ink cartridges in a recycle program like the one at Staples or save the cartridges for refill.
4. Install the new ink cartridges after removing the protective tabs. Avoid touching the IC chip when installing the new Lexmark ink cartridges. Replace the cover of the printer.
5. Allow the Lexmark printer to run a nozzle test. Print several pages with the new ink cartridges to make sure you installed the ink cartridges correctly. The indicator light should return to a solid green color.
do rate the solution if it helps
Nov 26, 2010 | Lexmark X1240 All-In-One InkJet Printer
My Lexmark C510 keeps popping up with a Paper Jam 241 error in Tray 1. There is no paper jam. I open the printer door take the tray out, put it back in and shut the door. How can I fix this problem? I...
I have a Lexmark C510 colour printer: Manufacture date June 2005.
I had been getting the "Paper Jam 241 error in Tray 1" message for some time. Sometimes it would print just fine but in the past several months, it's been bad. I'd pull the tray out (notice roller marks on the top sheet that was only partially fed), reinserted the sheet properly into the tray and try again and again. The techy at Lexmark mentioned that I could purchase a new rubber roller that feeds the sheet but that I might first wipe down the roller myself as they get worn and old. I first wiped it down with a damp cloth to clean it then thought to try reconditioning it with leather conditioner we'd purchased for our couch (I'm sure Amourall would work just as well). Voila, the old, dry roller was picking up paper again. Just open the rear door and that grey roller (it's black again when you recondition it) is at the bottom. Hope that helps.
May 11, 2010 | Lexmark C510 Laser Printer
Lost my manual, need to change the ink cartridge, help
  3. Step 3 Remove the old cartridges from your printer. Grip the sides of the Lexmark ink cartridges and pull it out. Dispose of the ink cartridges in a recycle program like the one at Staples or save the cartridges for refill.
  4. Step 4 Install the new ink cartridges after removing the protective tabs. Avoid touching the IC chip when installing the new Lexmark ink cartridges. Replace the cover of the printer.
  5. Step 5 Allow the Lexmark printer to run a nozzle test. Print several pages with the new ink cartridges to make sure you installed the ink cartridges correctly. The indicator light should return to a solid green color.
Apr 24, 2010 | Lexmark C533DN InkJet Printer
New computer won't print on old Lexmark 5150 printer
You can download the latest driver from lexmark.com .
May 05, 2009 | Lexmark X5150 All-In-One InkJet Printer
Uninstall printer
Don't worry about the old driver, just install new printer, set it as you default print and everyting should work.
Mar 05, 2009 | Lexmark X2350 All-In-One InkJet Printer
Installation disc
Here is a download link for your installation disc. Click HERE
Aug 21, 2008 | Lexmark X1150 All-In-One InkJet Printer
Printer
just make sure that there's nothing under the cover where it 'snaps' back into place.
no worries, check for up to date printer drivers here
Feb 28, 2008 | Lexmark X3470 All-In-One InkJet Printer
SCANER,PRINTER,COPYER
Saving a scanned image on the computer
1 Load an original document facedown on the scanner glass.
2 Close the top cover.
3 From the desktop, double-click the Lexmark Imaging Studio icon.
4 Click Scan.
5 Select the Photo, Several Photos, or Document option.
6 Click Start.
7 From the Save or Edit screen menu bar, click Save.
8 To save to another folder, click Browse, and select a folder. Click OK.
9 To rename the file, enter the name in the File Name area. To assign the name as a prefix to all of your photos,
select the “Start all photos with File Name” check box.
10 To save the photo as another file type, select the file type from the File Type drop-down list.
11 To select a date for the photo, click the drop-down list, and select a date from the calendar.
12 Click Save.
Jan 22, 2008 | Lexmark X2500 All-In-One Printer
20 people viewed this question
k24674
Marvin
Marvin
