Question about Zanussi ZDF490 Electric Double Oven
Oven fan wont stop when oven has completely cooled.
You should have someone come and look at it.
Posted on Jul 18, 2010
My electrolux EOU43002X oven bottom fan recently stopped. it also coincided with a buzzing from the timer panel. I replaced fan motor but timer wont work and the buzz still there when the timers tried
According to the convection fan which does not work, I suggest checking the main oven selector, wiring and convection fan.
According to the timer you should first set the time and then verify the correctness the timer relay. If relay is open than completely oven will not work.
Dado
Sep 08, 2015 | Electrolux Ovens
Why does the cooling fan on the oven continue to run?
Never heard of a cooling fan in an oven.they are usually used for fan baking, which speeds up cooking.
Sep 19, 2014 | Ovens
GE Built In Wall oven JTP25SOH6SS wont completely shut off
The cooling fan will stay on for a long time after using the oven. It should shut off after a while. If it is running all night for instance there is a great possibility that a relay is stuck on the control board.
Apr 13, 2014 | GE Ovens
Oven door won't unlock
kenmore selfcleaning oven door will not unlock code f9 appears in window
Jan 03, 2010 | Ovens
Main Oven fan stopped and not getting hot
When you say stopped, is it just the oven fan and the cooling fan is still running? Is the oven control knob still lit and is the main oven LED on?
Is the time set on the clock and is the clock set to manual?
Dec 28, 2009 | Stoves 720EF Electric Double Oven
My oven is constantly blowing out air at the front? Why
Your oven has a fan to draw in cool air at the bottom of the front panel, pass it around the case, and then blow it out at a position towards the top of the oven. This is a completely different fan that is at the back of the oven itself.
The cooling fan is necessary as the materials in modern ovens are kept light and thin as possible to save weight and manufacturing costs, however the flipside of this is that if not cooled by the cooling fan, they would be damaged by the heat inside the oven itself.
The cooling fan will continue to run for some time after the oven is switched off, because it will wait until the oven has fully cooled down before stopping the cooling fan.
Oct 03, 2009 | AEG B1180-4 Electric Single Oven
Self cleaning oven the fan will not go off after
Self cleaning ovens usually use very hot temperatures. Therefore if your fan is designed to help your oven cool, it will run until your oven is cool. Leave it running until your oven is cool and it should stop. It it does not let me know.
Jun 09, 2009 | Ovens
Oven Over Heat
Not sure if this is relevant but, have you set the clock correctly?  The oven will cut off if it's cooking on a timer.
May 01, 2009 | Smeg SE280X Stainless Steel Electric...
I have a Competence B1180, it cuts out after irregular periods of time, although sometimes it may even complete a cooking cycle, if turned off for 10-15min it will re-start, but invariably cuts out again...
Could be caused by either of following;
1. Faulty thermostat.
2. Faulty thermal cut out switch. (controls power to cooling fan).
3. Faulty cooling fan (not fan inside oven).
Test thermostat by setting thermostat to low temperature like 60 oC. If oven gets much hotter then its a faulty thermostat.
To test cooling fan and thermal switch take oven out and remove top or rear panels to expose components.
When oven gets hot the cooling fan should turn on. If it doesn't then check to see if there is a mains voltage present.
If mains current exist but fan is not turnig then replace fan. If mains voltage is not present then its the thermal switch.
Mar 01, 2009 | AEG B1180-4 Electric Single Oven
Oven wont work after self clean
I have a Whirlpool MOD. RBS275PDB17 single electric self-cleaning oven; although the manual is generic, it specifies, "When the cycle is completed and the oven cools, "End" will appear on the lower oven display and "LOCKED' will disappear" and "To Stop Self-Clean any time: Press UPPER/OFF, LOWER/OFF or OFF/CANCEL. If the oven temperature is too high, the door will remain locked. It will not unlock until the oven cools." Has your oven had time to cool?
Jun 13, 2008 | Whirlpool RBS275PD Electric Single Oven
Zanussi ZDF490 Electric Double Oven Logo
91 people viewed this question
Top Zanussi Ovens Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Zanussi Oven Expert? Answer questions, earn points and help others
