Question about Sony BRAVIA KDL-40S2010 40 in. LCD Television
Sony Bravia was working fine last night and when I turned on this am nothing. The light is not on and the set won't turn on. The cable box plugged in the same strip works but the tv won't turn on. Not even with it's own remote.
    Novelist:
  • 153 Answers
Try unplugging set for approx 5 minutes or so, cross your fingers and re-try. Other wise sounds like power supply board failure. Some shops repair the boards others replace them
Posted on Jul 22, 2010
Bravia TV has pink screen
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Aug 01, 2015 | Sony BRAVIA KDL-52S5100 52 in. LCD HDTV
My set is plugged into a cable box. the tv will not turn on either manually or with the remote.
Plug the power cord directly into a wall power outlet, and make sure that the standby light is lit (turn it on/off manually to see if anything changes). If there isn't any light, then it's most likely broken.
If the TV works again, being plugged into the power outlet in the wall, then the problem is with the cable box (i bet you figured that out too).
Jul 06, 2014 | Envision L32W761 32 in. LCD TV
My car won't turn on it was working fine last
Just because you charged the battery it doesn't mean it is any good. Modern sealed batteries fail; just as you described, fine one moment and then nothing, they go open internally.
Jul 19, 2013 | Cars & Trucks
Cant get the power to turn on,worked fine last night, it got unplugged, this morning plugged in, won't turn on and the power button just flashse
Flashing is either an error code or the set trying to boot up--some of the Mitsubishi sets if power removed will blink for a minute and then stop--then the set can be turned on.
a model number?
Apr 28, 2012 | Mitsubishi Televison & Video
Sony BRAVIA KDL-40V2500 audio not working
I would Google the model number carefully for "problems" "no sound" and usually this set will display some kind of error code===it may even have a hard reset to try===service manuals are available on the net/web to allow you to see how the sound circuit is set up etc.
Mar 29, 2012 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sound coming out of speakers in spurts
speaker volume spinner i.e which is use to increase n decrease the volumn is not working and it has a ball in the end.
if you slowly turn the volume controller nob probably u will get clear sound at one point.
Apr 01, 2009 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
Sony bravia kdl40s2010u
A 4 flash indicates you have a backlight problem. Either the backlight inverter boards have failed or you have a backlight that has failed in the LCD panel. You will need a technician to check the set to determine which is the problem.
Nov 08, 2008 | Sony Televison & Video
SONY BRAVIA KDL-40S2010 40"
Mine isnt even 1 year old and same problem. was fine last night, woke this morning, turned it on and there they are green and purple
Apr 08, 2008 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Digital channel set-up
Unplug the set for 12 to 24 hours. if that does not help, go into channel search but make sure the cable box is plugged in and turned on. If that does not work call out a tech to sort out your problem. Experimenting is fun at times, no insult intended, but its not the best thing to do with a TV set.
Sep 18, 2006 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony BRAVIA KDL-40S2010 40 in. LCD Television Logo
346 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
