Question about Danby DPAC12061 3 in 1 Home Comfort 12,000 BTU Portable Air Conditioner, Dehumidifier, Fan, Oscillat...
I have a Danby Portable 3 Season Home Comfort Air conditioner Model #DPAC10030 made in china.i have two questions. Where can I buy the Adjustable window/patio slider kitas mine has been deformed by the sun? And the External water tanks quick disconect switch is snapped off do I require a new tank or can the the switch be replaced . Is this model compatable with the newer models and where can I get them?
SOURCE: Danby air conditioner model #DPAC10060(R)
here is the manual link: http://www.danby.ca/manuals/DPAC8020.pdf
Posted on Jun 15, 2007
  • 230 Answers
SOURCE: Danby PORTABLE Air Conditioner model
The base needs to be dumped regularly. The air conditioner sweats water during operation and the pan collects it. Your manual should give you the procedure on how this is done. In some cases there is a hose attached to the drain pan so that you can direct the drainage to a more conventional drain location.
Posted on Jun 27, 2008
hemantraj
  • 638 Answers
SOURCE: Remove Water Tank
  • require you empty the unit by hand (usually less expensive units). These have either a removable water tank which must be emptied, or have an internal tank and a drain, where you have to empty the water into your own pan. Sometimes the drain is on the bottom of the unit, making it hard to find a pan that will fit under the unit to drain it.
  • discharge most of the water through the exhaust hose (usually more expensive units). This is called "Auto-evaporation" or "Self-evaporating" feature.
Most units are made so that they can be drained with a gravity hose that flows to a drain inside or outside your house. But the water must drain down. If the drain is higher than the unit, you may need a condensation pump to move the water upward. A few units do include a pump to send the water a short distance through the drain pipe.
do no forget to rate the solution as fixya if it helps you.
thanks.
Posted on Jul 02, 2008
SOURCE: Need new external water tank quick release for Danby DPAC9030
You can order it from Danby directly (you can get their contact online from the Danby website). They cost like 4$+shipping, I had to buy one last summer. They ship to Canada and the US.
Posted on Jun 25, 2009
SOURCE: My danby air conditioner/dehumidifier model dpac
Also check to see that the nut on the male connection to the external water tank is tight. Mine dripped because the nut was loose.
Posted on May 30, 2010
Danby DPAC9008 Portable Air Conditioner Problems & Solutions.Where to buy new filter?
Unless your filter has been destroyed, it washable and reusable. If it has been destroyed call the Danby Consumer Hot Line 1-800-263-2629 to get a new one.
Hope this helps you. Thanks for choosing FixYa.
Aug 04, 2011 | Danby DPAC9008 Portable Air Conditioner
I need to replace a hose on a Danby portable airconditioner model # DPAC120068
The first place to start is with the manufacturer, Danby 800-496-6049. Or take a section of the hose with you and go to your nearest home center and purchase a similar hose (same diameter) and use all the existing fittings that you have, to remount it with the new hose. There are several types available that will work well for this type of application and probably last longer than the original hose did.
Hope this helped you. Please let me know. Thanks.
Jun 08, 2011 | Danby 7,000 BTU Portable Air Conditioner -...
How to turn on the AC?
Here's a link to a site that has a free copy of your owners manual available. Just scroll all the way down and enter in the code shown and you'll be able to download the manual instantly.
http://www.devicemanuals.com/guide/Air%20Conditioner/Danby/Danby-DPAC120068-3-In-1-Portable-Home-Comfort-System-==TWpVME56TTM=.html
Hope this helps and best regards!
Aug 01, 2009 | Danby DPAC120068 Air Conditioner
Batteries?
It splits in the middle
Jun 24, 2009 | Danby DPAC8399 Air Conditioner
Danby-Simplicity SPAC 1220081 - manual gives no indication on how to activate the ionizer function, ie: get the light to turn on suggesting its working. Any ideas? kms. Oops - typo in the model # correct...
I talked to the Danby rep and he said you activate it by pressing the 'fan' button on the control panel for 3 seconds until the ionizer indicator light activates/deactivates. I haven't tried it yet (I'm at work) but I'll give it a shot when I go home.
Jun 23, 2009 | Danby Portable Air Conditioner
Heating & Cooling Logo
96 people viewed this question
Top Danby Heating & Cooling Experts
coolfelix
Level 1 Expert
Dan Webster
Dan Webster
Dennis Boxerman
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
