Question about Directed Electronics Dei '96 To '98 Jeep Cherokee Remote Start Interface Module
96 cherokee xj trouble codes list? - Directed Electronics Dei '96 To '98 Jeep Cherokee Remote Start Interface Module
  • 5,081 Answers
The error codes are given below
1192 Inlet air temperature sensor voltage is wrong
1193 Inlet air temperature sensor voltage is wrong
1194 Oxygen sensor heater performance is faulty
1195 Oxygen sensor is slow
1196 The oxygen sensor switched too slowly (bank 2).
1197 The oxygen sensor switched too slowly (bank 1).
1198 Radiator coolant temperature sensor voltage is wrong.
1199 Radiator coolant temperature sensor voltage is wrong.
1281 The engine is staying cold too long - check your thermostat.
1282 The fuel pump relay circuit seems to be having a problem.
1288 The intake manifold short runner tuning valve circuit seems to be having a problem.
1289 There's a problem in the manifold tuning valve solenoid control circuit.
1290 Compressed natural gas system pressure is too high
1291 The heated air intake sensor does not seem to be working.
1292 Natural gas pressure sensor issue
1293 Natural gas pressure sensor issue
1294 Can't get to target engine speed, check for vacuum leaks and idle speed motor issues.
1295 The throttle position sensor doesn't seem to be getting enough electricity.
1296 The MAP sensor doesn't seem to be getting enough electricity.
1297 The MAP sensor doesn't change its reading when the engine is running!
1298 During wide-open throttle, the engine runs lean.
1299 MAP Sensor and Throttle Position Sensor signals don't match, check for a vacuum leak.
1388 Auto shutdown relay circuit problems?
1389 No Z1 or Z2 voltage seen by the computer when the auto shutdown relay is used.
1390 Cam and crank signals don't match - did the timing belt skip a tooth?
1391 Sometimes, I can't see the crank or cam sensor signal.
1398 I can see the Crank Sensor's signal when I prepare for Misfire Diagnostics. Try replacing it.
1399 Problem in the Wait to Start Lamp circuit - (diesels only?)
1403 EGR position sensor not getting (enough) voltage.
1476 Too little secondary air injection during aspirator test.
1477 Too much secondary air injection during aspirator test.
1478 Battery temperature sensor voltage wrong.
1479 Transmission fan relay circuit problems?
1480 PCV solenoid circuit problems?
1481 Transmission RPM pulse generator signal for misfire detection seems wrong.
1482 Catalyst temperature sensor circuit shorted low.
1483 Catalyst temperature sensor circuit shorted high.
1484 The catalyst seems to be overheating!
1485 Air injection solenoid circuit problems.
1486 Pinched or blocked hose in the evaporative hose system.
1487 Control circuit of the #2 high-speed radiator fan control relay is having problems.
1488 Auxiliary 5-volt sensor feed is too low.
1489 High speed radiator fan control circuit problem.
1490 Low speed radiator fan control circuit problem.
1491 Radiator fan control circuit problem (may be solid state relays as well as other circuits).
1492 Ambient or battery temperature sensor voltage wrong
1493 Ambient or battery temperature sensor voltage wrong
1494 Leak Detection Pump (LDP) pressure switch problem - electrical or the pump itself.
1495 Leak Detection Pump (LDP) pressure switch problem - the solenoid circuit.
1496 Sensor feed is below an acceptable limit. (under 4v for 4 seconds - should be 5v).
1498 High speed radiator fan control circuit problem. (#3 control relay)
1594 Voltage too high in charging system.
1595 Speed control vacuum or vent solenoid control circuits shorted or lost.
1596 Speed control switch always high
1597 Speed control switch always low
1598 A/C pressure sensor voltage high
1599 A/C pressure sensor voltage low
1681 No messages received from the cluster control module (dashboard computer).
1682 Charging system doesn't seem to be working well. Check alternator, etc.
1683 Speed control servo power control circuit problem.
1684 The battery has been disconnected within the last 50 starts.
1685 Invalid key received from the Smart Key Immobilizer Module.
1686 No messages received from the Smart Key Immobilizer Module.
1687 No messages received from the Mechanical Instrument Cluster module.
1 693 The companion engine control module has shown a fault.
1694 No messages received from the powertrain control module-Aisin transmission.
1695 No messages received from the body control module.
1696 Unsuccessful attempt to write to an EEPROM location!
1697 Unsuccessful attempt to update Service Reminder Indicator (SRI or EMR) mileage!
1698 No messages received from the electronic transmission control module or the Aisin transmission controller.
1719 Transmission 2-3 gear lockout solenoid control circuit problem.
1740 Either the tcc solenoid or overdrive solenoid systems doesn't seem to be making much sense.
1756 Transmission control pressure not equal to target. (Mid pressure problem)
1757 Transmission control pressure not equal to target. (Zero pressure problem)
1762 The Governor Pressure Sensor input was too high or too low for 3 consecutive park/neutral calibrations.
1763 The Governor Pressure Sensor input is too high
1764 The Governor Pressure Sensor input is too low.
1765 Open or short in the Transmission Relay control circuit.
1899 The Park/Neutral switch seems to be stuck!
Posted on Jul 18, 2010
Testimonial: "extremelly herlp full thank you"
  • INDIRA KUMAR
    INDIRA KUMAR Jul 18, 2010
    30 Sensor heater relay problem
    36 Sensor heater relay problem
    106 MAP sensor voltage out of range detected at startup
    107 MAP sensor voltage too low
    108 MAP sensor voltage too high
    112 Intake air temperature sensor voltage low
    113 Intake air (charge) temperature sensor voltage high
    116 Coolant temparature sensor reading doesn't make sense
    117 Engine coolant temperature sensor voltage low
    118 Engine coolant temperature sensor voltage high
    121 Throttle position sensor and MAP sensor disagree with each other
    122 Throttle position sensor voltage low
    123 Throttle position sensor voltage high
    125 Taking too long to reach proper operating temparature and switch to
    energy-efficient mode
    130 Sensor heater relay problem
    130 O2 Sensor Circuit Malfunction (Bank 1 Sensor 1)
    131 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 1)
    132 O2 Sensor Circuit High Voltage (Bank 1 Sensor 1)
    133 O2 Sensor Circuit Slow Response (Bank 1 Sensor 1)
    134 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 1)
    135 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
    136 O2 Sensor Circuit Malfunction (Bank 1 Sensor 2)
    137 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 2)
    138 O2 Sensor Circuit High Voltage (Bank 1 Sensor 2)
    139 O2 Sensor Circuit Slow Response (Bank 1 Sensor 2)
    140 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 2)
    141 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 2)
    142 O2 Sensor Circuit Malfunction (Bank 1 Sensor 3)
    143 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 3)
    144 O2 Sensor Circuit High Voltage (Bank 1 Sensor 3)
    145 O2 Sensor Circuit Slow Response (Bank 1 Sensor 3)
    146 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 3)
    147 Oxygen sensor heater element not working properly (this device helps
    to reduce emissions more quickly)
    151 Oxygen sensor voltage problem - short circuit to ground?
    152 Oxygen sensor voltage problem - short circuit to active 12V?
    153 Oxygen sensor response too slow
    154 Oxygen sensor does not show either a rich or lean condition - may
    need replacement
    155 Oxygen sensor heater element not working properly (this device helps
    157 Oxygen sensor voltage problem - short circuit to ground?
    158 Oxygen sensor voltage problem - short circuit to active 12V?
    159 Oxygen sensor response too slow
    160 Oxygen sensor does not show either a rich or lean condition - may
    need replacement
    161 Oxygen sensor heater element not working properly (this device helps
    171 The oxygen sensor is saying that the system air/fuel mix is far too
    lean (too much fuel is being added as a correction).
    172 The oxygen sensor is saying that the system air/fuel mix is far too
    rich (too much air is being added as a correction).
    174 The oxygen sensor is saying that the system air/fuel mix is far too
    175 The oxygen sensor is saying that the system air/fuel mix is far too
    176 Flex fuel sensor can't be seen
    178 Flex fuel sensor problem
    179 Flex fuel sensor problem
    182 Compressed natural gas temperature sensor problem
    183 Compressed natural gas temperature sensor problem
    201 Injector #1 control circuit problem (open or shorted)
    202 Injector #2 control circuit problem (open or shorted)
    203 Injector #3 control circuit problem (open or shorted)
    204 Injector #4 control circuit problem (open or shorted)
    205 Injector #5 control circuit problem (open or shorted)
    206 Injector #6 control circuit problem (open or shorted)
    207 Injector #7 control circuit problem (open or shorted)
    208 Injector #8 control circuit problem (open or shorted)
    300 Misfire detected in multiple cylinders.
    301 Misfire detected in cylinder #1.
    302 Misfire detected in cylinder #2.
    303 Misfire detected in cylinder #3.
    304 Misfire detected in cylinder #4.
    305 Misfire detected in cylinder #5.
    306 Misfire detected in cylinder #6.
    307 Misfire detected in cylinder #7
    308 Misfire detected in cylinder #8.
    320 Crankshaft position sensor reference signal cannot be found while
    the engine is cranking.
    325 Knock sensor (#1) signal is wrong.
    330 Knock sensor (#2) signal is wrong.
    340 No camshaft signal being received by the computer
    350 A coil is drawing too much current.
    351 Coil #1 is not reaching peak current at the right time
    352 Coil #2 is not reaching peak current at the right time
    353 Coil #3 is not reaching peak current at the right time
    354 Coil #4 is not reaching peak current at the right time
    355 Coil #5 is not reaching peak current at the right time
    356 Coil #6 is not reaching peak current at the right time
    357 Coil #7 is not reaching peak current at the right time
    358 Coil #8 is not reaching peak current at the right time
    401 A required change in air/fuel mixture was not detected during
    diagnostic test.
    403 An problem was detected in the EGR solenoid control circuit.
    404 The EGR sensor's reported position makes no sense
    405 EGR position sensor voltage wrong.
    406 EGR position sensor voltage wrong.
    412 The secondary air solenoid control circuit seems bad (this is used
    for the aspirator).
    420 The catalyst seems inefficient (#1).
    432 The catalyst seems inefficient (#2).
    441 Evaporative purge flow system not working properly
    442 A leak has been detected in the evaporative system!
    443 Evaporative purge flow system solenoid not working properly
    455 A large leak has been detected in the evaporative system!
    456 A small leak has been detected in the evaporative system!
    460 The fuel level sender is not reporting any change over a long
    distance. Something seems wrong.
    461 The fuel level sender is not reporting any change over a long time.
    462 Fuel level sender voltage wrong.
    463 Fuel level sender voltage wrong.
    500 Haven't heard from the speed sensor lately.
    505 The idle speed air control motor doesn't seem to be working
    correctly.
    522 Oil pressure sensor problems
    523 Oil pressure sensor problems
    551 The power steering switch may not be working. (Neons: high pressure
    is showing up at high speed)
    600 Oh-oh! The coprocessors aren't talking to each other within the
    computer!
    601 Internal computer error!
    604 Internal computer error! (RAM check)
    605 Internal computer error! (ROM)
    615 Starter relay circuit problem
    622 Generator field control problem
    645 A/C clutch relay circuit problem.
    700 The automatic transmission computer or Aisin computer has a problem -
    ask it what's going on. I don't know.
    703 Brake switch circuit information seems wrong.
    711 Based on the transmission temperature and its operations, it looks
    like the transmission temperature sensor's gone bad.
    712 Transmission fluid temperature sensor voltage wrong.
    713 Transmission fluid temperature sensor voltage wrong.
    720 The Output Shaft Speed Sensor doesn't match the reported vehicle
    speed.
    740 The engine's running faster than it should for these speeds, so I
    think thetorque convertor clutch lock-up system is bad
    743 Torque converter clutch (part throttle unlock) solenoid circuit
    problem - shift solenoid C electrical fault
    748 Governor Pressure Solenoid circuit problem (Transmission relay
    circuit problem in Jeep RE transmissions)
    751 Overdrive override switch has been pressed for over five minutes.
    Just thought you should know.
    753 Overdrive solenoid control circuit problem (transmission relay
    circuit in Jeep RE transmissions.)
    756 Shift solenoid B (2-3) fault
    783 The overdrive solenoid can't go from 3rd gear to the overdrive gear.
    801 Transmission reverse gear lockout solenoid circuit problem!
    833 Problem with the clutch-released switch circuit?
96 jeep fuse diagram
what jeep>? must be guess which it is.?
ok , I roll me dice and land on xj cherokee.
I roll again and land on USA, (not export)
the see ive posted the FSM 100 times here.
and all that , is in that.
XJ 96
http://www.morris4x4center.com/knowledge-base/index.htm?utm_source=cj#service
Mar 03, 2016 | Jeep Cars & Trucks
What is the wireing color combination for a down stream 02sensor on a 1996 jeep cherokee?
its in the fsm. ever seen one?
96 XJ
see it here, for free. XJ 1996 , click wiring
the see PDF page 17? index
then see.
8w-30 or OXY pdf page 136 and next 3.
but there is not just one engine, so do look for your engine there.
it is there. if your car is USA car, and not Export car.
http://www.jeep4x4center.com/knowledge-base/index.htm?utm_source=cj#service
posted 100 times now, this link.
nobody ever searches.
Mar 06, 2015 | 1996 Jeep Cherokee
Where is the airbag fuse located in the 96 jeep cherokee fuse box?
srs fuse.
the fuse is in the FSM too.
XJ jeep
i found no fuse. for that.
it has bags?
USA car?
http://www.jeepforum.com/forum/f11/1996-cherokee-airbag-753490/
battery neg lug pull for 1/2 hour min, should make it safe.
PDC cavity 5 here
http://www.fixya.com/cars/t11007180-96_jeep_grd_cherokee_laredo_fuse_box
on our forum. amazing.
rumor has it that some 96 xj, have these odd bags that have Special screws to defeat bags, Id get a real FSM and read that.
they can kill you.
Feb 22, 2015 | 1996 Jeep Cherokee
Dose the dash have to be pulled to change a blower motor on my 96 cherokee XJ?
no
should have 3 8mm bolts holing it in from the bottom of the blower moter
Sep 22, 2013 | 1996 Jeep Cherokee Country
Jeep grand cherokee limited '96: check engine
If a warning light is on, there's a trouble code stored in the computer. There are well over 800-1,000 possible trouble codes in the average late model vehicle, so asking us to guess what's causing your problem without knowing the code is a complete waste of time. Get the code read. Post it here. THEN we can help
Jan 12, 2018 | 1996 Jeep Grand Cherokee
Code 463 fuel level sensory high imput, what is this and where is it located
Not sure if this helps or not, but here is information from the 1998 Jeep Grand Cherokee Service Manual, ezg_25.pdf, page 6 of 20…
Hex Code = 95
Generic Scan Tool Code = P0462
DRB Scan Tool Display = Fuel Level Sending Unit Volts Too Low
Description of Diagnostic Trouble Code = Open circuit between PCM and fuel gauge sending unit.
Hex Code = 96
Generic Scan Tool Code = P0463
DRB Scan Tool Display = Fuel Level Sending Unit Volts Too High
Description of Diagnostic Trouble Code = Circuit shorted to voltage between PCM and fuel gauge sending unit.
Hex Code = 97
Generic Scan Tool Code = P0460
DRB Scan Tool Display = Fuel Level Unit No Change Over Miles
Description of Diagnostic Trouble Code = No movement of fuel level sender detected.
for additional information on troubleshooting and resolution:
http://rapidshare.com/files/138412864/ServiceManual.Jeep.Grand.Cherokee.1998_by_Parasico.rar
Mar 01, 2010 | 1998 Jeep Grand Cherokee
I have a '96 jeep cherokee xj, although there is plenty of water in the system, the coolant warning light stays on. Any ideas?
Look in the overflow reservoir, and some designs use low brake fluid indication using the same bulb, (which I really do not understand ...!) check both of those areas.
Sep 19, 2009 | 1996 Jeep Cherokee
Directed Electronics Dei '96 To '98 Jeep Cherokee Remote Start Interface Module Logo
735 people viewed this question
Top Directed Electronics Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Directed Electronics Car Audio and Video Expert? Answer questions, earn points and help others
