Question about Pioneer GM-X372 Car Audio Amplifier
No audio to speakers from deck, just to amp
Hi i have a Pioneer DEH-4600MP which seems to work fine; however none of the car speakers make any sound regardless of the volume. What does apparently recieve a weak signal is my amp which powers a subwoofer. If I put the volume fairly high (like 35/62, while normal listening volume was maybe 10) I can hear the output from the subwoofer. The amp has a seperate input from regular audio cables (red and black out of deck). This setup worked fine when I purchased the car used, then came and went, and now just works as described above. All connections look fine (main cable bundle, antenna, and RCA cable). Could the deck have a bad internal amp or something? Let me know if any more information would help...thanks!
  • 1 more comment
  • TCab Apr 23, 2008
    Great troubleshooting steps; there was no voltage going to the speaker wires while the yellow seemed correct at a bit over 12 volts.
  • TCab Apr 23, 2008
    Actually; I realized I'm an idiot and when I first tested the unit wasn't ON so nothing would've been outputted anyway. When operating, 6 wires had the about 1/2 voltage deal (all about 5.4 out of 12.2), while one pair remained at zero. I did not test the external amp signal yet as I'm not sure of the steps on the BCAE page (although that site is awesome).
  • Anonymous Nov 18, 2008
    Hmm I have a similar problem. I have a VM9512 that powers up but no sound. I checked the voltages across each wire - 6 of them measured 4.5V. The other two are definitely messed up, one measured 11V and the other 0V. Would this mean the IC is bad or perhaps a user replaceable component instead??
    Thanks
For the pair that is at 0v, disconnect them from the wires that go to the speakers and re-test them. If they remain at 0v, they IC is defective. If they return to the voltage on the others, check the wiring between the speaker output wires and the speakers. Make sure they're not grounded anywhere.
Posted on Apr 25, 2008
  • 631 Answers
It's possible (probable) that the head unit has a blown internal amplifier IC. Measure the DC voltage on each of the 8 speaker wires on the head unit. Place the black lead on the chassis of the head unit. Probe each wire with the red lead. All should read approximately 1/2 of the voltage on the yellow wire. If you get some that are significantly higher or lower, disconnect all speaker wires from the harness and measure again. If the voltage is still not ~1/2 of the voltage on the yellow wire, the IC is almost certainly defective.
For the external amp, you need to check the shield ground for the head unit. The following page shows you how.
Test RCA shield ground
Posted on Apr 22, 2008
  • Perry Babin Apr 23, 2008
    If the head unit was on but the IC had no voltage on the speaker wires, the IC is most likely defective. There are a few (very few) head units that allow you to defeat the amplifier via menu control but I don't think you can do that on the 4600.
    Were the shields OK on the head unit? If they were and you have 12v on both the remote and B+ terminals for the amp (black meter lead on the ground terminal of the amp), the external amp may be defective also. The blown output IC shouldn't affect the RCA output signal.
Pioneer DEH-X6500BT amp & speaker problems
Depending on the car and your setup sounds like the amplifier is not wired properly or an issue with adjustments on your deck itself. More info on your sound setup would be helpful.
Dec 28, 2013 | Pioneer DEH-X6500BT MP3/USB A2DP Bluetooth...
Amp error deh 1500ub
hi I have a pioneer deh 1500 and I cemessage that appears on the screen "amp error"
I need help to prepare
Feb 10, 2013 | Pioneer Car Audio & Video
I have no sound coming from my rear speakers on my pioneer deh-6300hb
The first thing you will need to do is test all of your speakers and speaker wires for any shorts or grounds. Just one shorted speaker or speaker wire will shut off the audio. If your speakers and speaker wires check out fine, you probably have a bad internal output ic inside of your deck.
Feb 28, 2012 | Pioneer Car Audio & Video
I bought the deh-2200ub to replace an infinity stereo in a 2005 kia optima. There's less wires on the pioneer, which I just taped off, I have no sound. AARRRGGGGGG!!!! help
Hi, the wires should be connected as indicated below. Please let me know if you have questions, and thanks for using FixYa.
2005 Kia Optima Car Stereo Wiring Schematic Pioneer wire color
Car Radio Battery Constant 12v+ Wire: Orange yellow
Car Radio Accessory Switched 12v+ Wire: Yellow red
Car Radio Ground Wire: Black/White black
Car Radio Illumination Wire: Brown/White none
Car Stereo Dimmer Wire: Gray none
Car Stereo Antenna Trigger Wire: Gray blue/white
Car Stereo Amp Trigger Wire: Green blue/white (same as above)
Left Front Speaker Positive Wire (+): Yellow white
Left Front Speaker Negative Wire (-): Black white/black
Right Front Speaker Positive Wire (+): Blue gray
Right Front Speaker Negative Wire (-): Red gray/black
Left Rear Speaker Positive Wire (+): White green
Left Rear Speaker Negative Wire (-): Brown green/black
Right Rear Speaker Positive Wire (+): Orange violet
Right Rear Speaker Negative Wire (-): Green violet black
Apr 10, 2011 | Pioneer DEH-P4000UB CD Player
My pioneer deh-p840mp powers on and flips open, and seems to function fine with the exception of no sound going to all my door speakers and the bass to my subwoofers is a far sounding muffle even as I turn...
Un hook all your speakers that the deck is powering and hook them up one by one sounds like u have a shorted speaker or wire and the unit is going into protection.The best way to chk the speakers and wires is with an ohm meter . Check each speaker wire to ground and across the speaker and see iof you have any shorts. The next step woulk be to remove the unit and have it bench tested.
Jul 30, 2010 | Pioneer DEH-P840MP CD Player
No sound out of the deck
yes , also u may want to check ur connection
Apr 14, 2010 | Pioneer DEH-P4100
Installing my deh 2300
Heres all the radio wiring colors for your car:
2002 Oldsmobile Alero Car Radio Stereo Audio Wiring Diagram
Car Radio Constant 12v+ Wire: Orange
Car Radio Switched 12v+ Wire: Yellow
Car Stereo Antenna Trigger: Dark Green
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
window.google_render_ad();
Jun 02, 2009 | Pioneer DEH-2300 CD Player
Wire colours for my pioneer deh 2300
here are the wiring for the deck and the car:
Deck:
12v - red
ignition: yellow
blk - ground
orange - dimmer
white - frt left +
white /blk - frt left -
gray - frt right +
gray /blk - frt right -
green - left rear +
green /blk - left rear _
Purple - right rear +
Purple w/blk right rear -
Car:
Jun 02, 2009 | Pioneer DEH-P4100
DEH-P360 Won't output to rear channels/Sub
Make sure that the FIE (front image enhancement) is off. If it is on, the rear outputs are muted.
Oct 01, 2008 | Pioneer DEH-P3600 CD Player
Pioneer GM-X372 Car Audio Amplifier Logo
222 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
