Question about Sharper Image Power Tower Motorized DVD Storage Organizer (SI797TNM) Shelf System
S1797 dvd power tower motor runsbut does not movethe rack.how do i check the motor area for a disconnect?
3 Suggested Answers
cardenderek
  • 783 Answers
SOURCE: Where can I get another
You are going to install it yourself?
FixYa Support
Posted on Aug 30, 2011
gopakumarg43
  • 74887 Answers
Hello
Silicon rubber belts for CD mechanisms can be bought from most of the electronic spare part shops at your town. It will come as kit form. You have to give them the exact model number of your Shaper Image device. Belts are shipped in packeges having the the model number of the device to which it is intedned to use. If not; you have to go with the belt of your device, as sample for its size. To replace the belt, you have to open your device and take out its mechanism. If you have enough knoledge and expereince, you can do it by yoursef at home. OK.
Posted on Aug 31, 2011
Hard to turn and fluid is black
You need fresh fluid for one thing, but you may be trying to turn parts which are worn out.
The pressure needs to be checked in the rack and pinion unit. If the rack and pinion are working properly, the Strut tower bearings are probably shot. The rods from the rack should be disconnected and each Strut checked separately.
You can also believe that Alignment plays a factor in steering effort. You model may need all four wheels aligned.
Please rate my info.
Feb 27, 2013 | 2003 Ford Taurus
How much do wakeboard racks cost?
Wakeboard racks cost between $100-$650. For a complete list of tower racks for sale, check out this website: http://www.onlyinboards.com/AccessoryShop/Products/Racks/Wakeboard-Racks.aspx
Feb 06, 2013 | Water Sport
Wont power up
My wont turn on too, There is a orange light on the tower, Green on the left, Battery ovel, If I push the restart button, also switch the power supply switch in the back, also unplug from it, Sometimes does it, Do ou know whats causing this to happen, Please let me know Thanks
Jan 26, 2013 | Asrock K10N78M Motherboard
How to remove the pump from the motor on a Kenmore dish washer model 363.14572000
Steps:
1)Shut off power to the dishwasher at the circuit breaker and turn off the water line to the dishwasher by locating the shut-off valve, which is typically inside the cabinet beneath the kitchen sink.
2)Remove the four screws that hold the dishwasher kick plate in place.
3)Locate the motor,which is typically centered beneath the bottom spray arm.
4)Lower the dishwasher door and take out the bottom dish rack.
5)Remove the spray tower and spray arm assembly by unscrewing the bolt through its center.
6)Take out the filter immediately beneath the spray tower.
7)Disconnect the motor wires from the wiring harness,making a note of which wire connects to which terminal.
8)Disconnect the pump assembly and drain hose from the motor.
9)Remove the motor from the base of the dishwasher by unscrewing the four bolts holding it in place.
10)Repair or replace the motor and reinstall,taking care to reconnect the wires the same was as they were attached to the old motor.
11)Attach the pump and drain hose to the motor.
12)Replace the filter,spray tower and lower spray arm assembly.Reattach the center bolt in the spray tower.
13)Restore electrical power and turn on the water supply valve.
14)Run a test cycle to check for leaks underneath the appliance.
15)Replace the kick panel in front of the dishwasher.
Jul 31, 2010 | Kenmore Dishwashers
New computer tower motherboard(Intel D945GCPE), Processor(Intel Celeron 430 LGA775), memory, hard-drive(ATA), & dvd-rom(ATA). Got it all installed in new tower(ATX,I have green light on the motherboard...
First try to clear CMOS
Turn off the system and disconnect power cables
Locate the CMOS battery on the motherboard and take out the battery
Wait for about 15 minutes
Reconnect battery and try to turn it on.
If it remain same, disconnect power cables
Disconnect hard drive and CD/DVD drives
Try to turn on again.
Also check if the front panel connectors (Power SW, Reset, HDD connector) are properly connected.
Mar 09, 2010 | Intel Computers & Internet
Motor runsbut drum very slow to spin in spin cycle
The motor could be on its last leg of working. You can also check to make sure that the belt is not binding against anything under the drum. You may also want to make sure that the conterbalance weight is not hitting the belt. Make sure that your machine is lever and that it does not walk during spining.
Nov 28, 2009 | GE Washing Machines
Sharper image power tower 200
There is a small 1 1/2 inch O ring style belt that connects the motor to a set of gears. This belt is most likely broken and needs to be replaced.
May 17, 2009 | Sharper Image Power Tower Motorized DVD...
51 people viewed this question
Top Sharper Image Audio Players & Recorders Experts
Tom Chichester
Yoav Shilon
Yoav Shilon
Are you a Sharper Image Audio Player and Recorder Expert? Answer questions, earn points and help others
