Question about Palit Microsystems GeForce 9600 GT, PCI Express Video Card
Twin dvi geforce 9600 gt 1gb - need installation instructions
I bought it second hand but with no manual or CD
It comes with a power lead which connects 2 standard 12v male sockets to a single connector which fits on the graphics card. Is there any reason I should not connect both power inputs to a single output with a splitter?
There is also a small soundcard? type twin core connector- What for?
I am unsure of the manufacturer- there is a pb monogram on the card and the fan is marked xpertvision. Any help with identification or installation would be gratefully received. Thanks
    Sergeant:
  • 197 Answers
Ok well the soundcard is seperate - you can install it if you want but that would cut out room in the case as you have twin graphics cards going in... Main power lead to card should be an 8 pin connector - then they connect together using SLI joiner cable (joins the two cards together)
Minimum system power requirement is 400W Get your drivers from here http://www.geforce.com/drivers Hope this helps
Posted on May 06, 2017
5 Suggested Answers
SOURCE: The Palit Daytona Geforce 4 ti 4200 solution?
asdfsdf
Posted on Feb 24, 2008
  • 63 Answers
SOURCE: Driver don't work with Palit 9600 GT 1GB
this can be an cooling issue with 2 graphics cards in your system or it could be caused by your SMPS, it should be 700w or above to handle such a system efficiently.
Posted on Aug 03, 2009
dDex
  • 145 Answers
SOURCE: Hello.
Intall the correct driver. Check again the other connection.
Posted on Aug 14, 2009
  • 10 Answers
SOURCE: Blue screen of death.
You might try setting the display adapter in the bios to PCI-X,
You could also try going into safe mode to see if you can install the new drivers and fix the problem.
Other than that you would need to stick the card in another computer and confirm whether it is functional.
I have the exact same card with Vista and had no issues, and have been very happy with it.
Posted on May 12, 2010
Driver download
you can have its driver at nvidia website..click at driver download and juz select your model..and download it.
Oct 04, 2013 | Nvidia Geforce 9600gt 9600 Gt 1gb Ddr3...
I lost my cd driver of inno3d gf 9600 gt dvi hdcp ddr2 512mb, i will make to transfer in my other pc. thanks
Hello and Welcome to FixYa!
If you need a copy of the installation files for your inno3d GEForce 9600, all you have to do is to visit this link :
Driver Download-NVIDIA
You will then encounter this screen :
Make sure to choose your operating system and that all entries are correct, before clicking on "Search".  Afterwards, you can just choose download to get a copy of the installation files.  Wait for it to complete then, you can go to the folder where it was downloaded to run the installation.
I would highly recommend to restart your computer after completing the installation.
Hope this helps, Thank you for using FixYa.
Mar 11, 2011 | Computers & Internet
Jul 03, 2009 | Palit Microsystems GeForce 9600 GT, PCI...
Palit 9600 1gb ddr2
pls see that yur cpu or gpu is not heating. the power supply may be the culprit. if u have less than 450 watt psu u may consider upgrading to a 600 wall psu.
Mar 05, 2009 | Palit Microsystems GeForce 9600 GT, PCI...
Screen not starting after installing graphics card
Hi rohit1987,
The XFX NVIDIA GeForce 8600 GT 256MB DDR3 PCI Express card uses two DVI ports on the back of the card. Display is most likely coming from the second port. Try moving your monitor cable to the next DVI port. You can do this while your system is running.
If you still do not receive display, post that here & we'll go over some other possibilities.
Good luck rohit1987!
Thank you for using fixya.
Mike
Jan 13, 2009 | XFX NVIDIA GeForce 8600 Graphics Card
Graphics card problem
I have the 9600 GT - great card. You have to plug a 6 pin power supply directly into card (on the right hand side when it's installed), it can go AGP or PCI express, but PCI is better. Also NVidia released a new driver for it yesterday (nov 20th) which fixed some bugs in mine (dreamscene WAS a problem for the old drivers), so get that from the Nvidia site- support tab (driver is version 180.48). Also, if the card is allowing you OS to boot it should be fine (if no boot, you prob need to get newer mobo). Uninstall your old drivers, run a reg cleaner, driver cleaner, manually delete c:\nvidia, non-windows defrag and chdsk.....If thats no help to you then I suggest you directly ask beni-muer or world-vet, they are absolutely 1000 more times knowledgable than me when it comes to these probs.. GOOD LUCK.
Nov 21, 2008 | Foxconn 6627MA-RS2H Motherboard
Choosing a GPU
SAPPHIRE 100256L Radeon HD 4670 1GB
  • Chipset Manufacturer: ATI
  • Core clock: 750MHz
  • Stream Processors: 320 Stream Processing Units
  • Memory Clock: 2000MHz
  • DirectX: DirectX 10.1
  • OpenGL: OpenGL 2.0
  • HDMI: 1 via Adapter
  • DVI: 2
Although it only has a 128bit memory interface it makes up for this by the large amount of stream processors and the high core clock. It's cheaper than the 9600 and better.
Nov 02, 2008 | Computers & Internet
Palit Microsystems GeForce 9600 GT,  PCI Express Video Card Logo
54 people viewed this question
Top Palit Microsystems Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Pavel Pranovich
Pavel Pranovich
Tom Chichester
Are you a Palit Microsystems Computer and Internet Expert? Answer questions, earn points and help others
