Question about Frigidaire FAC107P1A Wall/Window Air Conditioner
My AC unit is blowing moist, not cold air...
I can't figure out why my AC unit it blowing moist/humid air. It feels like every few minutes it's actually blowing straight AC but for the most part it's very damp. I checked the filter the other day which was extremely dirty so I cleaned it, replaced it and now the "Check Filter" light is on. Help! I can't stand how humid my room is!!!
  • Frigidaire Master
  • 43,501 Answers
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Posted on Jul 19, 2010
Sometimes it blows out warm air warm enough to warm an entire room, yet at other times is blows cool air that can kkep a room cool. I want it to blow cold at all times. how do i do that?
dry air feels cool on the skin
moist air feels warm on the skin
this is why the perceived temperature of air from unit changes
Apr 14, 2015 | Dehumidifiers
Windows fog up
There is too much moisture inside the cabin. Either something is leaking water into the car, or your fresh air setting is not working on the hvac system. You can not run the system on recirculate and get rid of the moisture.
Feb 05, 2014 | 2003 Pontiac Sunfire
My 2010 Chrysler 300's front side and rear windows fog up really bad when its cold outside
fogging up occurs when the water vapour ( Humidity) in the cab air hits the cold windows Remove the humidity by running the ac in conjunction with the heater . AC units to make the air feel cold by removing the humidity in the cab air allowing you to perspire more easily and you feel cooler. By running to two together ( climate control in some cars) the fog will quickly disappear.
Dec 15, 2013 | 2008 Chrysler 300
Icing up windows
try running the ac as well as the heater. The ac removes the humidity (water vapour) in the air in the car which is causing the fogging up . Hot moist air on glass creates fog ( same as clouds). You will get a comfortable temperature inside without the fog
Dec 07, 2013 | 2007 Chrysler 300
Air conditioner not blowing cold air intermittently
you need a ac charge or the heater control valve is bad also check the compressor
May 30, 2012 | 2001 Ford Taurus
There is what appears to be "steam" blowing from my airconditioner into my room. What should I do?
Due to high humidity and perhaps, an air intake filter that needs to be removed and cleaned. That "steam" is actually a misty fog and is harmless. Window & Thru the Wall AC units often do this when the outside humidity and temperatures are high. Keeping the air intake filter clean will help to lessen this mist.
Hope this helped to allay your concern. Thanks fo choosing FixYa.
Aug 04, 2011 | Haier HWF05XC7 Thru-Wall/Window Air...
Why is mist blowing out of my window unit AC? it is odorless and still blowing cold air from one side. Its just like a mist but not wet.
nicki - That's normal. It happens when the humidity level is high. It's actually removing the humidity from your house. There's nothing to worry about, unless it's blowing into the house. In which case, turn the unit OFF and allow it to thaw. The humidity must be high enough to form ice crystals on the condensing coils. While the unit is OFF, remove the air intake filter and clean it. Make sure it's thoroughly dry, before reinstalling it.
That should solve take care of it.
Jun 13, 2011 | Heating & Cooling
Why doesnt my ac through cold air
mcdevito75 here, It could be 3 reasons, First the lower the outside humidity the less cool air your A/C will blow out, 2 Turn off your unit for 10 minutes and re-start with fan only for the first 3--4 minutes then adjust for A/C. 3 Your unit needs serviceing, Freon charge.
Aug 19, 2010 | Goodman CKL24AR24 Air Conditioner
Heating & Cooling Logo
1,301 people viewed this question
Top Frigidaire Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
